  2. Announcements
  3. Sensebender Micro
Sensebender Micro
584 Posts 84 Posters 655.6k Views 35 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    @hetbeest
    Just want to add a note about the ftdi usb to TTL, it should be capable of 3.3V, as this is the operating voltage of the board.
    • G
      G
      gloob
      Is there any idea when the pre-order phase will be over and the production and shipping will start?
      • tbowmoT
        tbowmoT
        tbowmo
        @gloob
        According to itead they would start shipping 20th of may.
        • G
          G
          gloob
          Will it be preloaded with the temperature/humidity functionality, that I only have to attach the NRF24L01 module and the gateway will automatically detect it?
          Currently I don't own a programmer to upload programs. I did only work with arduino nanos with a USB Interface.
          hekH 1 Reply Last reply
          • G gloob
            @gloob
            Yes, it will be preloaded with a sketch reporting temperature and humidity level using the auto assigned id from controller.
            https://codebender.cc/sketch:110812
            • FotoFieberF
              FotoFieberF
              FotoFieber
              My ISP programmer uses 5V. Is it compatible, if I remove the NRF24L01+?
              • tbowmoT
                tbowmoT
                tbowmo
                @FotoFieber
                It depends, if you are supplying the board from the ISP programmer, then Si7021 and the external flash will die very quickly, as they are not 5V tolerant..
                you can read more here
                • axillentA
                  axillentA
                  axillent
                  My congratulation! It is very cool stuff!
                  Why not to post this thread http://forum.mysensors.org/topic/510/minimal-design-thoughts to the useful links on iteadstudio product page?
                  sense and drive
                  • nutcrackerN
                    nutcrackerN
                    nutcracker
                    Great stuff! Boards ordered....!
                    • FotoFieberF
                      FotoFieberF
                      FotoFieber
                      Yes, great stuff, ordered 6... wish they were available 4 weeks ago: I wouldn't have designed a minimal PCB/NRF based on the DIL version of the 328,,,,
                        Just ordered 6 for myself. I wouldn't want to miss out on the first batch. Only around 100 left.
                        Talked to Itead today. They had to source the ATSHA204A from overseas and will start production when they arrive.
                        K 1 Reply Last reply
                        • RJ_MakeR
                          RJ_MakeR
                          RJ_Make
                          Picked up 5 myself
                          RJ_Make
                          • korttomaK
                            korttomaK
                            korttoma
                            What would be the best option to add an external temperature sensor to the Sensbender Micro?
                            Another Si7021? Any thoughts?
                            I could not find any other I2C temperature sensor with the same voltage range to a reasonable price.
                            • Tomas
                              K
                              K
                              kalle
                              bought also 3 pieces :-)
                                mvader
                                I picked up 3 and 5 radios
                                • hetbeestH
                                  hetbeestH
                                  hetbeest
                                  wrote on last edited by hetbeest
                                  Just ordered two to start with ;)
                                  • D
                                    Dean
                                    Hope this isn't too silly a question.... The temp/humidity sensing, that works 'out of the box' without requiring me actually connecting these sensors, right?
                                    And another question, would it be possible to turn the temp/hum function off and just have a motion sensor connected which would never do anything unless it sensed movement and then send a message to the gateway?
                                    I've been flat out at work for a couple months so I've been away from this for a while... :-)
                                    • tbowmoT
                                      tbowmoT
                                      tbowmo
                                      @Dean
                                      It will be programmed by the factory, with the "Sensebender micro" sketch, https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/examples/SensebenderMicro/SensebenderMicro.ino
                                      So it's plug'n'play as a sensor with temperature and humidity. You could always dump another sketch to the unit, if you want to use it for something else.
                                      • G
                                        G
                                        gol
                                        I have also ordered a couple of boards to be able to evaulate them as soon as possible.
                                        Just a question:
                                        • What is the expected lifetime of the batteries if you use 2 AA batteries, the default preloaded sketch and reports the temp and humidity values once per minute?
                                        • jeylitesJ
                                          jeylitesJ
                                          jeylites
                                          wrote on last edited by jeylites
                                          #24
                                          Out of curiosity, can over the air updates be implemented on Arduino Nano? I'm going to get 3 to put Sense to the test. :smiley:
