  2. Announcements
  3. Sensebender Micro
Sensebender Micro
584 Posts 84 Posters 658.0k Views 35 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    @FotoFieber
    It depends, if you are supplying the board from the ISP programmer, then Si7021 and the external flash will die very quickly, as they are not 5V tolerant..
    you can read more here
    • axillentA
      axillentA
      axillent
      My congratulation! It is very cool stuff!
      Why not to post this thread http://forum.mysensors.org/topic/510/minimal-design-thoughts to the useful links on iteadstudio product page?
      sense and drive
      • nutcrackerN
        nutcrackerN
        nutcracker
        Great stuff! Boards ordered....!
        • FotoFieberF
          FotoFieberF
          FotoFieber
          Yes, great stuff, ordered 6... wish they were available 4 weeks ago: I wouldn't have designed a minimal PCB/NRF based on the DIL version of the 328,,,,
            Just ordered 6 for myself. I wouldn't want to miss out on the first batch. Only around 100 left.
            Talked to Itead today. They had to source the ATSHA204A from overseas and will start production when they arrive.
            K 1 Reply Last reply
            • RJ_MakeR
              RJ_MakeR
              RJ_Make
              Picked up 5 myself
              RJ_Make
              • korttomaK
                korttomaK
                korttoma
                What would be the best option to add an external temperature sensor to the Sensbender Micro?
                Another Si7021? Any thoughts?
                I could not find any other I2C temperature sensor with the same voltage range to a reasonable price.
                • Tomas
                  K
                  K
                  kalle
                  bought also 3 pieces :-)
                    mvader
                    I picked up 3 and 5 radios
                    • hetbeestH
                      hetbeestH
                      hetbeest
                      wrote on last edited by hetbeest
                      Just ordered two to start with ;)
                      • D
                        Dean
                        Hope this isn't too silly a question.... The temp/humidity sensing, that works 'out of the box' without requiring me actually connecting these sensors, right?
                        And another question, would it be possible to turn the temp/hum function off and just have a motion sensor connected which would never do anything unless it sensed movement and then send a message to the gateway?
                        I've been flat out at work for a couple months so I've been away from this for a while... :-)
                        • tbowmoT
                          tbowmoT
                          tbowmo
                          @Dean
                          It will be programmed by the factory, with the "Sensebender micro" sketch, https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/examples/SensebenderMicro/SensebenderMicro.ino
                          So it's plug'n'play as a sensor with temperature and humidity. You could always dump another sketch to the unit, if you want to use it for something else.
                          • G
                            G
                            gol
                            I have also ordered a couple of boards to be able to evaulate them as soon as possible.
                            Just a question:
                            • What is the expected lifetime of the batteries if you use 2 AA batteries, the default preloaded sketch and reports the temp and humidity values once per minute?
                            • jeylitesJ
                              jeylitesJ
                              jeylites
                              wrote on last edited by jeylites
                              #24
                              Out of curiosity, can over the air updates be implemented on Arduino Nano? I'm going to get 3 to put Sense to the test. :smiley:
                                @gol
                                It was measured by @blacey to 0.05 mA while sleeping and 0.95 mA during transmit. @tbowmo got some higher figures but they were most probably related to running a NRF24L01+ clone.
                                @jeylites
                                Yes, have a look at the bootloader here:
                                https://github.com/mysensors/Arduino/tree/master/MYSBootloader
                                You can test OTA updates using the MYSController. It overwrites program memory in-place during boot. If communication goes down or fails during this process the node won't boot up again (you have to upload a new sketch while connected to you computer).
                                The sensbender has a external flash which means we can safely store the OTA firmware while normal sketch is running. When everything has been downloaded the DualOptiboot moves new firmware from flash to program memory during bootup. The code for this has been written (in development branch) but has not been tested yet (I failed handsoldering them :() .
                                tekkaT D 2 Replies Last reply
                                • D
                                  Dean
                                  Thankyou @tbowmo
                                    @gol
                                    @jeylites
                                    tekkaT
                                    tekkaT
                                    tekka
                                    wrote on last edited by tekka
                                    #27
                                    @hek said:
                                    @jeylites
                                    If the communication fails, the bootloader will remain "bootloading", i.e. will try to fetch a new firmware from the controller until the CRC matches - no need to upload a sketch via computer.
                                    MYSBootloader 2.0 will have SHA signing implemented: for those nodes without ATSHA204 which need signed OTA updates :)
                                    jeylitesJ 1 Reply Last reply
                                    • tekkaT tekka
                                      @hek said:
                                      @jeylites
                                      jeylitesJ
                                      jeylitesJ
                                      jeylites
                                      Do I have to include those files into my sketch or just install MYS on windows and it will auto detect? In other words, do I have to make any changes to the sketch?
                                      Is there any tutorial on MYS implementation?
                                      hekH 1 Reply Last reply
                                      • jeylitesJ jeylites
                                        @jeylites
                                        You should read up on what a bootloader is and how to install it.
                                        http://www.arduino.cc/en/Hacking/Bootloader?from=Tutorial.Bootloader
                                        Might be good to start another thread if you have more MYSController/bootloader questions,
                                          @jeylites
                                          marceltrapmanM
                                          marceltrapmanM
                                          marceltrapman
                                          Nicely put :)
                                          I would say 'please start another thread because this will never be found again and will help other as well'...
                                          Just my 2 cents.
                                          Fulltime Servoy Developer
