  3. $8 Lamp (Outlet) "Smart Plug" Module
109 Posts 34 Posters 121.1k Views 13 Watching
  • J
    J
    johnr
    servicexp, no I guess it have only over current protection.
    I am going to test a smaller 5w converter. MW irm-05-5 which I was able to get for a ok price through work. It has also smaller physical dimensions.
    petewillP 1 Reply Last reply
    • J johnr
      petewillP
      petewillP
      petewill
      Nice, let us know how it works! I also find I run out of chargers. Thankfully I can get them from work occasionally when people recycle their old phone chargers.
      • petewillP petewill
        BulldogLowellB
        BulldogLowellB
        BulldogLowell
        @petewill
        Or hotel lost and found...
        • petewillP
          petewillP
          petewill
          @BulldogLowell yeah, good idea! I wonder if electronics stores may have them too. I know Best Buy has a electronics recycling program. Maybe they get them there too? I just got a fresh supply from work so I should be good for a little while :)
          • Mohsin HassanM
            Mohsin HassanM
            Mohsin Hassan
            Hey Hi. Awesome project.
            Just a quick though, could i just a Pro mini 5V and skip the whole voltage regulator part? or would that need some additional changes to the project?
            Thank :+1:
            • Mohsin HassanM Mohsin Hassan
              Thank :+1:
              petewillP
              petewillP
              petewill
              @Mohsin-Hassan Do you mean a 3.3v pro mini? If so, then you should be able to. The radio requires 3.3v to work. You would need to take the 5v from the phone charger to power the relay.
              • D
                DanielD
                @petewill
                Hello, how are you?
                Man, I understood how you do this project, but Have one thing I doesn't understand, How you sync the plug with your cellphone?
                Because intro the plug have a Arduino and RF Module.
                Could you explain me?
                Thx :)
                • petewillP
                  petewillP
                  petewill
                  I use a Vera for my home automation controller. MySensors has a plugin for Vera so the cellphone app is actually for Vera. I can issue a command through my phone to Vera which will then send the command to the MySensors device.
                  Hopefully that makes sense.
                  Pete
                  • D
                    DanielD
                    @petewill
                    Okay, I thought that you create a device smilar to Vera.
                    Because I thinking do this.
                    Do you have any ideia how I do this?
                    Thx
                    • petewillP
                      petewillP
                      petewill
                      No, sorry. It would probably be easier for you to use an existing controller that already works with MySensors though. Check out the list here: http://www.mysensors.org/controller/
                      I'm sure some of them already have phone apps but I'm not sure which ones. I haven't looked at anything other than Vera.
                      • D
                        DanielD
                        wrote on last edited by DanielD
                        #27
                        @petewill
                        mm, I will install one of these in my PC and I will buy a ethernet bord, and make a gateway ethernet.
                        But what I do not understand is How the Web Site will send a rf signal from arduino
                        Okay I know I should connect the ethernet bord in arduino and rf transmisor, but how do
                        sensor received this signal I know I will put rf receiver inside.
                        But the code of ethernet gateway doesn't have nothing about the transmissor.
                        If you don't understand something ask me.
                        Thx
                        • petewillP
                          petewillP
                          petewill
                          Right. That's where the controller comes in. I use Vera so when I press the on button in the Vera interface it sends the command through the gateway to the sensor (smart outlet).
                          If you are try do it cheaply you may want to look into openhab. I haven't used it but I know it runs on a raspberry pi.
                          • D
                            DanielD
                            @petewill
                            Hmm,Okay
                            I will try make a device type Vera because,in my country doesn't exists.
                            If I buy at site and ask to ship me Will cost very expensive, therefore I try make a device similar to vera :/
                            Could you help me?
                            Thx
                            A 1 Reply Last reply
                            • D DanielD
                              @petewill
                              Hmm,Okay
                              Could you help me?
                              Thx
                              andriej
                              @DanielD just get yourself an raspberry.
                              • D
                                DanielD
                                @andriej
                                I have a raspberry, but I think use only arudino.
                                • petewillP
                                  petewillP
                                  petewill
                                  Could you help me?
                                  Unfortunately I don't know how to do that. The best thing I can suggest is to use one of the existing controllers. If you already have a raspberry pi there is free software for it. Try one of those. That way you don't have to recreate anything.
                                  • D
                                    DanielD
                                    @petewill
                                    Hmm,
                                    Okay, but I think I don't understand is how I will do the communication between getway ethernet and another device.
                                    • petewillP
                                      petewillP
                                      petewill
                                      You probably want to check out this: http://www.mysensors.org/about/ and this: http://www.openhab.org/
                                      It will will take some learning and I suggest you start out small. See if you can get OpenHab up and running first. When you understand that you can start using MySensors. I had my Vera for a few months before I started learning MySensors. It was helpful to learn the controller before MySensors.
                                      • A
                                        almj
                                        Thank you very much for detailed description!
                                        But I cannot understand how to send commands from OpenHab to turn relay on and off. Please direct me.
                                        After a long time I can finally get the messages from sensors via serial connection, but not the other way.
                                        Cheers!
                                        • A almj
                                          Cheers!
                                          petewillP
                                          petewillP
                                          petewill
                                          @almj I use Vera as my controller so I'm not sure how to set up OpenHab. I know there are some instructions for setting it up here on the forum. If you're still stuck you may get better responses by posting to a new topic. Sorry I can't be more help.
