  3. $8 Lamp (Outlet) "Smart Plug" Module
109 Posts 34 Posters 121.7k Views 13 Watching
    Excellent @petewill.
    Your video has been added to relay build page and in the news section.
    Great work!
    • petewillP
      petewillP
      petewill
      @Francois great question! To be honest, it's on the list but not very high. I have a few other projects I wanted to do and hopefully create videos for.
      @hek Thanks! You have created something awesome and I am excited to give back just a little when I can. Thanks for all you've done (and continue to do)!!
      • J
        J
        johnr
        Nice project.
        I will build some plugs myself, but I would like to exclude the charger, we should be able to power the arduino directly from the ac plug.
        I am thinking to use something like this
        https://www.elfa.se/elfa3~tr_en/elfa/init.do?item=69-065-19&toc=19413
        What do you think about it?
        tbowmoT 1 Reply Last reply
        • J johnr
          Nice project.
          tbowmoT
          tbowmoT
          tbowmo
          @johnr said:
          Nice project.
          That looks like an "charger" just in another package :) in my opinion it's a bit over the top, with a 10W power supply, to a device that uses arround 0,5W (0.1mA @ 5V) in peaks.
          / Thomas
          • J
            J
            johnr
            wrote on last edited by johnr
            Sorry I Think I expressed myself to short and incorrect on my way to work.
            I really like this Project. My personal problem is that when you have many sensors, sooner or later you run out of old chargers ;)
            Therefore for the relay (wallplug) it would be nice to find a small ac/dc power supply, which is easy to integrate into the breadboard/pcb.
            The Meanwell that I linked to i also availible in 5w, but personally I had some problems in the past, with the current consumption of the relays, using sub wall-warts. This is why I am thinking 10w.
            Mean well have nice quality but pricing is quite high. Would be nice to find an alternative with enough quality that you can trust that it wont burst into flames.
            Edit: Mybe this tread is the correct one to discuss ac/dc converters. http://forum.mysensors.org/topic/687/230v-power-supply-to-arduino
            RJ_MakeR 1 Reply Last reply
            • J johnr
              RJ_MakeR
              RJ_MakeR
              RJ_Make
              @johnr It doesn't look like that series has any temperature protection??
              RJ_Make
              • J
                J
                johnr
                servicexp, no I guess it have only over current protection.
                I am going to test a smaller 5w converter. MW irm-05-5 which I was able to get for a ok price through work. It has also smaller physical dimensions.
                petewillP 1 Reply Last reply
                • J johnr
                  petewillP
                  petewillP
                  petewill
                  Nice, let us know how it works! I also find I run out of chargers. Thankfully I can get them from work occasionally when people recycle their old phone chargers.
                  • petewillP petewill
                    BulldogLowellB
                    BulldogLowellB
                    BulldogLowell
                    @petewill
                    Or hotel lost and found...
                    • petewillP
                      petewillP
                      petewill
                      @BulldogLowell yeah, good idea! I wonder if electronics stores may have them too. I know Best Buy has a electronics recycling program. Maybe they get them there too? I just got a fresh supply from work so I should be good for a little while :)
                      • Mohsin HassanM
                        Mohsin HassanM
                        Mohsin Hassan
                        Hey Hi. Awesome project.
                        Just a quick though, could i just a Pro mini 5V and skip the whole voltage regulator part? or would that need some additional changes to the project?
                        Thank :+1:
                        • Mohsin HassanM Mohsin Hassan
                          Thank :+1:
                          petewillP
                          petewillP
                          petewill
                          @Mohsin-Hassan Do you mean a 3.3v pro mini? If so, then you should be able to. The radio requires 3.3v to work. You would need to take the 5v from the phone charger to power the relay.
                          • D
                            DanielD
                            @petewill
                            Hello, how are you?
                            Man, I understood how you do this project, but Have one thing I doesn't understand, How you sync the plug with your cellphone?
                            Because intro the plug have a Arduino and RF Module.
                            Could you explain me?
                            Thx :)
                            • petewillP
                              petewillP
                              petewill
                              I use a Vera for my home automation controller. MySensors has a plugin for Vera so the cellphone app is actually for Vera. I can issue a command through my phone to Vera which will then send the command to the MySensors device.
                              Hopefully that makes sense.
                              Pete
                              • D
                                DanielD
                                @petewill
                                Okay, I thought that you create a device smilar to Vera.
                                Because I thinking do this.
                                Do you have any ideia how I do this?
                                Thx
                                • petewillP
                                  petewillP
                                  petewill
                                  No, sorry. It would probably be easier for you to use an existing controller that already works with MySensors though. Check out the list here: http://www.mysensors.org/controller/
                                  I'm sure some of them already have phone apps but I'm not sure which ones. I haven't looked at anything other than Vera.
                                  • D
                                    DanielD
                                    wrote on last edited by DanielD
                                    #27
                                    @petewill
                                    mm, I will install one of these in my PC and I will buy a ethernet bord, and make a gateway ethernet.
                                    But what I do not understand is How the Web Site will send a rf signal from arduino
                                    Okay I know I should connect the ethernet bord in arduino and rf transmisor, but how do
                                    sensor received this signal I know I will put rf receiver inside.
                                    But the code of ethernet gateway doesn't have nothing about the transmissor.
                                    If you don't understand something ask me.
                                    Thx
                                    • petewillP
                                      petewillP
                                      petewill
                                      Right. That's where the controller comes in. I use Vera so when I press the on button in the Vera interface it sends the command through the gateway to the sensor (smart outlet).
                                      If you are try do it cheaply you may want to look into openhab. I haven't used it but I know it runs on a raspberry pi.
                                      • D
                                        DanielD
                                        @petewill
                                        Hmm,Okay
                                        I will try make a device type Vera because,in my country doesn't exists.
                                        If I buy at site and ask to ship me Will cost very expensive, therefore I try make a device similar to vera :/
                                        Could you help me?
                                        Thx
                                        A 1 Reply Last reply
                                        • D DanielD
                                          @petewill
                                          Hmm,Okay
                                          Could you help me?
                                          Thx
                                          andriej
                                          @DanielD just get yourself an raspberry.
                                          12.5k
