  3. $8 Lamp (Outlet) "Smart Plug" Module
109 Posts 34 Posters 121.7k Views 13 Watching
  • J johnr
    Nice project.
    I will build some plugs myself, but I would like to exclude the charger, we should be able to power the arduino directly from the ac plug.
    I am thinking to use something like this
    https://www.elfa.se/elfa3~tr_en/elfa/init.do?item=69-065-19&toc=19413
    What do you think about it?
    tbowmoT
    tbowmoT
    tbowmo
    @johnr said:
    Nice project.
    That looks like an "charger" just in another package :) in my opinion it's a bit over the top, with a 10W power supply, to a device that uses arround 0,5W (0.1mA @ 5V) in peaks.
    / Thomas
    • J
      J
      johnr
      wrote on last edited by johnr
      Sorry I Think I expressed myself to short and incorrect on my way to work.
      I really like this Project. My personal problem is that when you have many sensors, sooner or later you run out of old chargers ;)
      Therefore for the relay (wallplug) it would be nice to find a small ac/dc power supply, which is easy to integrate into the breadboard/pcb.
      The Meanwell that I linked to i also availible in 5w, but personally I had some problems in the past, with the current consumption of the relays, using sub wall-warts. This is why I am thinking 10w.
      Mean well have nice quality but pricing is quite high. Would be nice to find an alternative with enough quality that you can trust that it wont burst into flames.
      Edit: Mybe this tread is the correct one to discuss ac/dc converters. http://forum.mysensors.org/topic/687/230v-power-supply-to-arduino
      RJ_MakeR 1 Reply Last reply
      • J johnr
        RJ_MakeR
        RJ_MakeR
        RJ_Make
        @johnr It doesn't look like that series has any temperature protection??
        RJ_Make
        • J
          J
          johnr
          servicexp, no I guess it have only over current protection.
          I am going to test a smaller 5w converter. MW irm-05-5 which I was able to get for a ok price through work. It has also smaller physical dimensions.
          petewillP 1 Reply Last reply
          • J johnr
            petewillP
            petewillP
            petewill
            Nice, let us know how it works! I also find I run out of chargers. Thankfully I can get them from work occasionally when people recycle their old phone chargers.
            • petewillP petewill
              BulldogLowellB
              BulldogLowellB
              BulldogLowell
              @petewill
              Or hotel lost and found...
              • petewillP
                petewillP
                petewill
                @BulldogLowell yeah, good idea! I wonder if electronics stores may have them too. I know Best Buy has a electronics recycling program. Maybe they get them there too? I just got a fresh supply from work so I should be good for a little while :)
                • Mohsin HassanM
                  Mohsin HassanM
                  Mohsin Hassan
                  Hey Hi. Awesome project.
                  Just a quick though, could i just a Pro mini 5V and skip the whole voltage regulator part? or would that need some additional changes to the project?
                  Thank :+1:
                  • Mohsin HassanM Mohsin Hassan
                    Thank :+1:
                    petewillP
                    petewillP
                    petewill
                    @Mohsin-Hassan Do you mean a 3.3v pro mini? If so, then you should be able to. The radio requires 3.3v to work. You would need to take the 5v from the phone charger to power the relay.
                    • D
                      DanielD
                      @petewill
                      Hello, how are you?
                      Man, I understood how you do this project, but Have one thing I doesn't understand, How you sync the plug with your cellphone?
                      Because intro the plug have a Arduino and RF Module.
                      Could you explain me?
                      Thx :)
                      • petewillP
                        petewillP
                        petewill
                        I use a Vera for my home automation controller. MySensors has a plugin for Vera so the cellphone app is actually for Vera. I can issue a command through my phone to Vera which will then send the command to the MySensors device.
                        Hopefully that makes sense.
                        Pete
                        • D
                          DanielD
                          @petewill
                          Okay, I thought that you create a device smilar to Vera.
                          Because I thinking do this.
                          Do you have any ideia how I do this?
                          Thx
                          • petewillP
                            petewillP
                            petewill
                            No, sorry. It would probably be easier for you to use an existing controller that already works with MySensors though. Check out the list here: http://www.mysensors.org/controller/
                            I'm sure some of them already have phone apps but I'm not sure which ones. I haven't looked at anything other than Vera.
                            • D
                              DanielD
                              wrote on last edited by DanielD
                              #27
                              @petewill
                              mm, I will install one of these in my PC and I will buy a ethernet bord, and make a gateway ethernet.
                              But what I do not understand is How the Web Site will send a rf signal from arduino
                              Okay I know I should connect the ethernet bord in arduino and rf transmisor, but how do
                              sensor received this signal I know I will put rf receiver inside.
                              But the code of ethernet gateway doesn't have nothing about the transmissor.
                              If you don't understand something ask me.
                              Thx
                              • petewillP
                                petewillP
                                petewill
                                Right. That's where the controller comes in. I use Vera so when I press the on button in the Vera interface it sends the command through the gateway to the sensor (smart outlet).
                                If you are try do it cheaply you may want to look into openhab. I haven't used it but I know it runs on a raspberry pi.
                                • D
                                  DanielD
                                  @petewill
                                  Hmm,Okay
                                  I will try make a device type Vera because,in my country doesn't exists.
                                  If I buy at site and ask to ship me Will cost very expensive, therefore I try make a device similar to vera :/
                                  Could you help me?
                                  Thx
                                  A 1 Reply Last reply
                                  • D DanielD
                                    @petewill
                                    Hmm,Okay
                                    Could you help me?
                                    Thx
                                    andriej
                                    @DanielD just get yourself an raspberry.
                                    • D
                                      DanielD
                                      @andriej
                                      I have a raspberry, but I think use only arudino.
                                      • petewillP
                                        petewillP
                                        petewill
                                        Could you help me?
                                        Unfortunately I don't know how to do that. The best thing I can suggest is to use one of the existing controllers. If you already have a raspberry pi there is free software for it. Try one of those. That way you don't have to recreate anything.
                                        • D
                                          DanielD
                                          @petewill
                                          Hmm,
                                          Okay, but I think I don't understand is how I will do the communication between getway ethernet and another device.
