  3. Camera as a sensor
Camera as a sensor
42 Posts 5 Posters 26.1k Views 1 Watching
    Definitely possible (we're transmitting firmware updates today) but it would require some programming to chop up the images and send them pice by pice. There is no functionality in the library that does this automatically.
    We're using the command type STREAM for firmware data today. Would probably be good to use that for images as well.
    • Moshe LivneM Moshe Livne
      Hi all,
      Another question that might have been answered elsewhere but I couldn;t find the answer. There are 3 cameras in the shop but no project that uses them. question is, is it even possible to use a sensor as a security camera? Again, I know next to nothing about realtime programming. can the mysensor protocol support that? nothing fancy like a streaming video - just a photo every now and then triggered by motion sensors
      axillentA
      axillentA
      axillent
      @Moshe-Livne what you want to trigger on mysensors side? motion event or sending picture?
      most of IP cameras are able to send pictures by themselves, you do not need mysensors for this
      but you can integrate camera with my sensors to trigger motion event like PIR sensor can do
      motion event is definitely supported by mysensors
      you need to look at camera integration possibilities to see how you can integrate
      the possible scenarios:
      • camera is configured to upload pictures to FTP at motion event, do setup of FTP server on RPI or even arduino to initiate mysensors event on any upload. Or you can connect many cameras and can differentiate by their IP
      • camera is configured to send email using SMTP - do similar as for FTP
      • camera has a special API to report motion events. Integrate it according to API
      • camera has a wired output of a motion event. connect regular mysensors sensor to it
      sense and drive
      • axillentA axillent
        Moshe LivneM
        Moshe LivneM
        Moshe Livne
        @axillent I was asking about the tiny camera modules that appear in the mysensors store. good and reliable IP cameras are not cheap and they are (sometimes) very awkward to set up and integrate with your wifi (and I actually don't like it so much that my WLAN password reside on a device outside my house). My dream sensor would be a cheap motion event with a photo as a doorbell, for example using the VGA camera you would end up (if rpi is not needed) with a 15$ device.. I am million miles from doing anything like that, was hoping that someone else already done that....
        axillentA 1 Reply Last reply
          axillentA
          axillentA
          axillent
          @Moshe-Livne IP cameras are starting from $50. they have a processor able to process images at a good speed for you to trigger a motion event in a second after real motion starts. Using camera module you will have to do the same - processing images one by one to detect changes and this will trigger event. You will need at least a RAM to store a series of images at your camera resolution. RPI should be sufficient for this, but the cost of RPI + wifi + camear module + power supply is becoming higher comparing to IP camera.
          regarding security. many modern routers allows to setup isolated WIFI spot with separate password
          sense and drive
          • axillentA
            axillentA
            axillent
            this one could be sufficient indoor http://foscam.us/products/foscam-fi8918w-white-wireless-ip-camera-21.html
            and this outdoor http://foscam.us/outdoor-cameras/fi9803p-plug-play-1-0-megapixel-1280x720p-h-264-outdoor-wireless-ip-camera.html
            sense and drive
              Moshe LivneM
              Moshe LivneM
              Moshe Livne
              @axillent i was thinking using PIR for detecting motion, snapping a shot and sending it. you are right about the ram - i would need sd card reader probably
                axillentA
                axillentA
                axillent
                PIR? it is something different. You need a clear view on what you want. From you first post I realized that you want to detect motion by analyzing camera output etc by analyzing images. Using PIR is very different
                sense and drive
                  Moshe LivneM
                  Moshe LivneM
                  Moshe Livne
                  @axillent I live in NZ.... 45$ shipping....
                    axillentA
                    axillentA
                    axillent
                    there are many foscam clones shipping free from China starting at $50
                    sense and drive
                      Moshe LivneM
                      Moshe LivneM
                      Moshe Livne
                      @axillent no, no.... as I said, i want to use it as cheap entrance device. PIR is good enough to trigger the response
                        Moshe LivneM
                        Moshe LivneM
                        Moshe Livne
                        wrote on last edited by Moshe Livne
                        @axillent I have one of these, skyeyes. It is not foscam replica, just looks like it. has no snapshot url so completely useless. annoying....
                          axillentA
                          axillentA
                          axillent
                          can you explain exactly what do you want?
                          PIR is triggering event and someone is taking picture at this moment?
                          sense and drive
                            Moshe LivneM
                            Moshe LivneM
                            Moshe Livne
                            @axillent yes. just a door or hall sensor that will be triggered by the PIR, take a snapshot (or maybe several in 10 sec increment) and send them to the home automation system.
                              axillentA
                              axillentA
                              axillent
                              OK, I see. Do you want both PIR and camera module been connected to the same device? If yes this could have not much todo with mysensors. It can be regular arduino or rpi sketch sending pictures by FTP or email.
                              If you want to have PIR on other device you can use mysensor to sens PIR and trigger other device to take pictures using mysensors radio
                              sense and drive
                              • bjornhallbergB
                                bjornhallbergB
                                bjornhallberg
                                I have one (soon two) RPi with camera modules that take pictures and store / send to Pushbullet when a certain MySensors PIR is triggered. Has worked pretty well for the past year. and a Pi + Camera is still reasonably cheap plus it's a "real" computer so it can do anything with the camera and images. And the Pi camera is still pretty good, unless you happen to get a real bad clone from Ebay or something. Hardly worth it. I don't know how good these cameras in the store are, but I doubt they come anywhere near the simplicity and guaranteed quality of the Pi camera module.
                                If you like, you can also use the "motion" package on the Pi, but that will be a real hassle with false triggers and all. The cheap PIR motion sensors have worked surprisingly well. It's more a question of positioning them right so you don't have problems with sunlight, fireworks, curious magpies etc.
                                I have my RPi inside camera housings I got from AliExpress. There are a couple there that are pretty good. I think finding a bracket can be more of a challenge. I have J-brackets that fit under the eaves.
                                I have the raspimjpeg script running on the Pi btw. You could just use raspistill I suppose but it's nice to be able to manually view the camera feed from the browser and have remote control at your fingertips. Hell, you could even get one of those motorized RPi things that are able to turn the camera.
                                I have a sort of Power Over Ethernet going for my cameras btw.
                                Moshe LivneM axillentA 2 Replies Last reply
                                  Moshe LivneM
                                  Moshe LivneM
                                  Moshe Livne
                                  @bjornhallberg That is a very cool setup although i suspect its not very economical. the pi+camera would cost ~80$ i think. plus casing and bracket would get you very close to foscam if not higher. I was aiming at cheapest possible solution. maybe even one that can run on battery.
                                    Mickey
                                    wrote on last edited by Mickey
                                    http://www.aliexpress.com/item/LYNEW-Portable-Mini-Wireless-wifi-Router-3G-4G-Hotspot-Wifi-Hotspot-support-3G-USB-modems/32257312139.html
                                    Today there are openwrt enable modules on aliexpress that start from below 8$ that can be attached to mjpg usb camera and can take pictures and streams with less than 10$ price tag.
                                    • M Mickey
                                      Moshe LivneM
                                      Moshe LivneM
                                      Moshe Livne
                                      @Mickey this device is a gsm hotspot generator. it connects to a USB GSM dongle and allows you to connect to it either wired or wirelessly. I have never seen devices like the ones you mention. they could be a good solution
                                        axillentA
                                        axillentA
                                        axillent
                                        #22
                                        do not stick to it's original application
                                        the idea is that open-wrt can run on this small things. Open-wrt is a linux type system, you can program it very similar to RPI
                                        it is very cool if any camera working example exists for open-wrt
                                        sense and drive
                                          axillentA
                                          axillentA
                                          axillent
                                          @bjornhallberg very nice setup! my congratulations!
                                          for DIY you did it pretty well
                                          but cost vise I do not see how this can be more efficient comparing to foscam
                                          sense and drive
