  3. Camera as a sensor
Camera as a sensor
42 Posts 5 Posters 26.1k Views 1 Watching
  • axillentA
    axillentA
    axillent
    this one could be sufficient indoor http://foscam.us/products/foscam-fi8918w-white-wireless-ip-camera-21.html
    and this outdoor http://foscam.us/outdoor-cameras/fi9803p-plug-play-1-0-megapixel-1280x720p-h-264-outdoor-wireless-ip-camera.html
    sense and drive
    • axillentA axillent
      @Moshe-Livne IP cameras are starting from $50. they have a processor able to process images at a good speed for you to trigger a motion event in a second after real motion starts. Using camera module you will have to do the same - processing images one by one to detect changes and this will trigger event. You will need at least a RAM to store a series of images at your camera resolution. RPI should be sufficient for this, but the cost of RPI + wifi + camear module + power supply is becoming higher comparing to IP camera.
      regarding security. many modern routers allows to setup isolated WIFI spot with separate password
      Moshe LivneM
      Moshe LivneM
      Moshe Livne
      @axillent i was thinking using PIR for detecting motion, snapping a shot and sending it. you are right about the ram - i would need sd card reader probably
      axillentA 1 Reply Last reply
      • Moshe LivneM Moshe Livne
        axillentA
        axillentA
        axillent
        PIR? it is something different. You need a clear view on what you want. From you first post I realized that you want to detect motion by analyzing camera output etc by analyzing images. Using PIR is very different
        sense and drive
          Moshe LivneM
          Moshe LivneM
          Moshe Livne
          @axillent I live in NZ.... 45$ shipping....
            axillentA
            axillentA
            axillent
            there are many foscam clones shipping free from China starting at $50
            sense and drive
              Moshe LivneM
              Moshe LivneM
              Moshe Livne
              @axillent no, no.... as I said, i want to use it as cheap entrance device. PIR is good enough to trigger the response
                Moshe LivneM
                Moshe LivneM
                Moshe Livne
                wrote on last edited by Moshe Livne
                @axillent I have one of these, skyeyes. It is not foscam replica, just looks like it. has no snapshot url so completely useless. annoying....
                  axillentA
                  axillentA
                  axillent
                  can you explain exactly what do you want?
                  PIR is triggering event and someone is taking picture at this moment?
                  sense and drive
                    Moshe LivneM
                    Moshe LivneM
                    Moshe Livne
                    @axillent yes. just a door or hall sensor that will be triggered by the PIR, take a snapshot (or maybe several in 10 sec increment) and send them to the home automation system.
                      axillentA
                      axillentA
                      axillent
                      OK, I see. Do you want both PIR and camera module been connected to the same device? If yes this could have not much todo with mysensors. It can be regular arduino or rpi sketch sending pictures by FTP or email.
                      If you want to have PIR on other device you can use mysensor to sens PIR and trigger other device to take pictures using mysensors radio
                      sense and drive
                      • bjornhallbergB
                        bjornhallbergB
                        bjornhallberg
                        I have one (soon two) RPi with camera modules that take pictures and store / send to Pushbullet when a certain MySensors PIR is triggered. Has worked pretty well for the past year. and a Pi + Camera is still reasonably cheap plus it's a "real" computer so it can do anything with the camera and images. And the Pi camera is still pretty good, unless you happen to get a real bad clone from Ebay or something. Hardly worth it. I don't know how good these cameras in the store are, but I doubt they come anywhere near the simplicity and guaranteed quality of the Pi camera module.
                        If you like, you can also use the "motion" package on the Pi, but that will be a real hassle with false triggers and all. The cheap PIR motion sensors have worked surprisingly well. It's more a question of positioning them right so you don't have problems with sunlight, fireworks, curious magpies etc.
                        I have my RPi inside camera housings I got from AliExpress. There are a couple there that are pretty good. I think finding a bracket can be more of a challenge. I have J-brackets that fit under the eaves.
                        I have the raspimjpeg script running on the Pi btw. You could just use raspistill I suppose but it's nice to be able to manually view the camera feed from the browser and have remote control at your fingertips. Hell, you could even get one of those motorized RPi things that are able to turn the camera.
                        I have a sort of Power Over Ethernet going for my cameras btw.
                        Moshe LivneM axillentA 2 Replies Last reply
                          Moshe LivneM
                          Moshe LivneM
                          Moshe Livne
                          @bjornhallberg That is a very cool setup although i suspect its not very economical. the pi+camera would cost ~80$ i think. plus casing and bracket would get you very close to foscam if not higher. I was aiming at cheapest possible solution. maybe even one that can run on battery.
                            Mickey
                            wrote on last edited by Mickey
                            http://www.aliexpress.com/item/LYNEW-Portable-Mini-Wireless-wifi-Router-3G-4G-Hotspot-Wifi-Hotspot-support-3G-USB-modems/32257312139.html
                            Today there are openwrt enable modules on aliexpress that start from below 8$ that can be attached to mjpg usb camera and can take pictures and streams with less than 10$ price tag.
                            • M Mickey
                              Moshe LivneM
                              Moshe LivneM
                              Moshe Livne
                              @Mickey this device is a gsm hotspot generator. it connects to a USB GSM dongle and allows you to connect to it either wired or wirelessly. I have never seen devices like the ones you mention. they could be a good solution
                                axillentA
                                axillentA
                                axillent
                                #22
                                do not stick to it's original application
                                the idea is that open-wrt can run on this small things. Open-wrt is a linux type system, you can program it very similar to RPI
                                it is very cool if any camera working example exists for open-wrt
                                sense and drive
                                  axillentA
                                  axillentA
                                  axillent
                                  @bjornhallberg very nice setup! my congratulations!
                                  for DIY you did it pretty well
                                  but cost vise I do not see how this can be more efficient comparing to foscam
                                  sense and drive
                                    Moshe LivneM
                                    Moshe LivneM
                                    Moshe Livne
                                    @axillent Oh, still not used to thinking this way. This is beyond the (very limited) limits of my knowledge.... can be great.... total setup fee of ~15$
                                      Mickey
                                      I have an example of this just with tl-wr703n but the one I posted from aliexpress is just the same:
                                      openwrt webcam
                                      • M Mickey
                                        openwrt webcam
                                        Moshe LivneM
                                        Moshe LivneM
                                        Moshe Livne
                                        @Mickey very good and detailed article. I have several of the GSM modems (that I now understand are not GSM modems at all) somewhere so i'll see if they can be flashed with openwrt. should be fuuuunnnn.
                                          Mickey
                                          #27
                                          Notice that the one I posted from aliexpress have its own procedure to flash openwrt on. Be careful not to brick your module...
