  3. Camera as a sensor
Camera as a sensor
42 Posts 5 Posters 25.8k Views 1 Watching
  • Moshe LivneM Offline
    Moshe Livne
    Hi all,
    Another question that might have been answered elsewhere but I couldn;t find the answer. There are 3 cameras in the shop but no project that uses them. question is, is it even possible to use a sensor as a security camera? Again, I know next to nothing about realtime programming. can the mysensor protocol support that? nothing fancy like a streaming video - just a photo every now and then triggered by motion sensors
    A 1 Reply Last reply
    • hekH Offline
      hekH Offline
      I'm not sure the images can be processed on the node itself (using the low-end ATMegas). But you could probably take a picture and store it on a SSD when movement is detected by a motion sensor.
      The cameras was added mostly for fun wishing someone would play with them and come up with something useful ;)
        Moshe Livne
        assuming an rpi will act as the sensor backend, would it be possible to send it on the rf module and the current mysensors protocol? this would definitely bring the price and power consumption up but can still be an interesting idea IMHO.
        • hekH Offline
          hekH Offline
          Definitely possible (we're transmitting firmware updates today) but it would require some programming to chop up the images and send them pice by pice. There is no functionality in the library that does this automatically.
          We're using the command type STREAM for firmware data today. Would probably be good to use that for images as well.
          • Moshe LivneM Moshe Livne
            Hi all,
            A Offline
            A Offline
            axillent
            @Moshe-Livne what you want to trigger on mysensors side? motion event or sending picture?
            most of IP cameras are able to send pictures by themselves, you do not need mysensors for this
            but you can integrate camera with my sensors to trigger motion event like PIR sensor can do
            motion event is definitely supported by mysensors
            you need to look at camera integration possibilities to see how you can integrate
            the possible scenarios:
            • camera is configured to upload pictures to FTP at motion event, do setup of FTP server on RPI or even arduino to initiate mysensors event on any upload. Or you can connect many cameras and can differentiate by their IP
            • camera is configured to send email using SMTP - do similar as for FTP
            • camera has a special API to report motion events. Integrate it according to API
            • camera has a wired output of a motion event. connect regular mysensors sensor to it
            sense and drive
            • A axillent
              Moshe Livne
              @axillent I was asking about the tiny camera modules that appear in the mysensors store. good and reliable IP cameras are not cheap and they are (sometimes) very awkward to set up and integrate with your wifi (and I actually don't like it so much that my WLAN password reside on a device outside my house). My dream sensor would be a cheap motion event with a photo as a doorbell, for example using the VGA camera you would end up (if rpi is not needed) with a 15$ device.. I am million miles from doing anything like that, was hoping that someone else already done that....
                A Offline
                A Offline
                axillent
                @Moshe-Livne IP cameras are starting from $50. they have a processor able to process images at a good speed for you to trigger a motion event in a second after real motion starts. Using camera module you will have to do the same - processing images one by one to detect changes and this will trigger event. You will need at least a RAM to store a series of images at your camera resolution. RPI should be sufficient for this, but the cost of RPI + wifi + camear module + power supply is becoming higher comparing to IP camera.
                regarding security. many modern routers allows to setup isolated WIFI spot with separate password
                sense and drive
                • A Offline
                  A Offline
                  axillent
                  this one could be sufficient indoor http://foscam.us/products/foscam-fi8918w-white-wireless-ip-camera-21.html
                  and this outdoor http://foscam.us/outdoor-cameras/fi9803p-plug-play-1-0-megapixel-1280x720p-h-264-outdoor-wireless-ip-camera.html
                  sense and drive
                  • A axillent
                    Moshe Livne
                    @axillent i was thinking using PIR for detecting motion, snapping a shot and sending it. you are right about the ram - i would need sd card reader probably
                      A Offline
                      A Offline
                      axillent
                      PIR? it is something different. You need a clear view on what you want. From you first post I realized that you want to detect motion by analyzing camera output etc by analyzing images. Using PIR is very different
                      sense and drive
                      • A axillent
                        Moshe Livne
                        @axillent I live in NZ.... 45$ shipping....
                          A Offline
                          A Offline
                          axillent
                          there are many foscam clones shipping free from China starting at $50
                          sense and drive
                          • A axillent
                            Moshe Livne
                            @axillent no, no.... as I said, i want to use it as cheap entrance device. PIR is good enough to trigger the response
                            • A axillent
                              Moshe Livne
                              wrote on last edited by Moshe Livne
                              @axillent I have one of these, skyeyes. It is not foscam replica, just looks like it. has no snapshot url so completely useless. annoying....
                                A Offline
                                A Offline
                                axillent
                                can you explain exactly what do you want?
                                PIR is triggering event and someone is taking picture at this moment?
                                sense and drive
                                • A axillent
                                  Moshe Livne
                                  @axillent yes. just a door or hall sensor that will be triggered by the PIR, take a snapshot (or maybe several in 10 sec increment) and send them to the home automation system.
                                    A Offline
                                    A Offline
                                    axillent
                                    OK, I see. Do you want both PIR and camera module been connected to the same device? If yes this could have not much todo with mysensors. It can be regular arduino or rpi sketch sending pictures by FTP or email.
                                    If you want to have PIR on other device you can use mysensor to sens PIR and trigger other device to take pictures using mysensors radio
                                    sense and drive
                                    • B Offline
                                      B Offline
                                      bjornhallberg
                                      I have one (soon two) RPi with camera modules that take pictures and store / send to Pushbullet when a certain MySensors PIR is triggered. Has worked pretty well for the past year. and a Pi + Camera is still reasonably cheap plus it's a "real" computer so it can do anything with the camera and images. And the Pi camera is still pretty good, unless you happen to get a real bad clone from Ebay or something. Hardly worth it. I don't know how good these cameras in the store are, but I doubt they come anywhere near the simplicity and guaranteed quality of the Pi camera module.
                                      If you like, you can also use the "motion" package on the Pi, but that will be a real hassle with false triggers and all. The cheap PIR motion sensors have worked surprisingly well. It's more a question of positioning them right so you don't have problems with sunlight, fireworks, curious magpies etc.
                                      I have my RPi inside camera housings I got from AliExpress. There are a couple there that are pretty good. I think finding a bracket can be more of a challenge. I have J-brackets that fit under the eaves.
                                      I have the raspimjpeg script running on the Pi btw. You could just use raspistill I suppose but it's nice to be able to manually view the camera feed from the browser and have remote control at your fingertips. Hell, you could even get one of those motorized RPi things that are able to turn the camera.
                                      I have a sort of Power Over Ethernet going for my cameras btw.
                                      Moshe LivneM A 2 Replies Last reply
                                      • B bjornhallberg
                                        Moshe Livne
                                        @bjornhallberg That is a very cool setup although i suspect its not very economical. the pi+camera would cost ~80$ i think. plus casing and bracket would get you very close to foscam if not higher. I was aiming at cheapest possible solution. maybe even one that can run on battery.
                                        • M Offline
                                          M Offline
                                          Mickey
                                          wrote on last edited by Mickey
                                          http://www.aliexpress.com/item/LYNEW-Portable-Mini-Wireless-wifi-Router-3G-4G-Hotspot-Wifi-Hotspot-support-3G-USB-modems/32257312139.html
                                          Today there are openwrt enable modules on aliexpress that start from below 8$ that can be attached to mjpg usb camera and can take pictures and streams with less than 10$ price tag.
