  3. Camera as a sensor
Camera as a sensor
42 Posts 5 Posters 26.1k Views 1 Watching
  • Moshe LivneM Moshe Livne
    @axillent I was asking about the tiny camera modules that appear in the mysensors store. good and reliable IP cameras are not cheap and they are (sometimes) very awkward to set up and integrate with your wifi (and I actually don't like it so much that my WLAN password reside on a device outside my house). My dream sensor would be a cheap motion event with a photo as a doorbell, for example using the VGA camera you would end up (if rpi is not needed) with a 15$ device.. I am million miles from doing anything like that, was hoping that someone else already done that....
    axillentA
    axillentA
    axillent
    @Moshe-Livne IP cameras are starting from $50. they have a processor able to process images at a good speed for you to trigger a motion event in a second after real motion starts. Using camera module you will have to do the same - processing images one by one to detect changes and this will trigger event. You will need at least a RAM to store a series of images at your camera resolution. RPI should be sufficient for this, but the cost of RPI + wifi + camear module + power supply is becoming higher comparing to IP camera.
    regarding security. many modern routers allows to setup isolated WIFI spot with separate password
    sense and drive
    • axillentA
      axillentA
      axillent
      this one could be sufficient indoor http://foscam.us/products/foscam-fi8918w-white-wireless-ip-camera-21.html
      and this outdoor http://foscam.us/outdoor-cameras/fi9803p-plug-play-1-0-megapixel-1280x720p-h-264-outdoor-wireless-ip-camera.html
      sense and drive
      • axillentA axillent
        Moshe LivneM
        Moshe LivneM
        Moshe Livne
        @axillent i was thinking using PIR for detecting motion, snapping a shot and sending it. you are right about the ram - i would need sd card reader probably
        axillentA 1 Reply Last reply
          axillentA
          axillentA
          axillent
          PIR? it is something different. You need a clear view on what you want. From you first post I realized that you want to detect motion by analyzing camera output etc by analyzing images. Using PIR is very different
          sense and drive
            Moshe LivneM
            Moshe LivneM
            Moshe Livne
            @axillent I live in NZ.... 45$ shipping....
              axillentA
              axillentA
              axillent
              there are many foscam clones shipping free from China starting at $50
              sense and drive
                Moshe LivneM
                Moshe LivneM
                Moshe Livne
                @axillent no, no.... as I said, i want to use it as cheap entrance device. PIR is good enough to trigger the response
                  Moshe LivneM
                  Moshe LivneM
                  Moshe Livne
                  wrote on last edited by Moshe Livne
                  @axillent I have one of these, skyeyes. It is not foscam replica, just looks like it. has no snapshot url so completely useless. annoying....
                    axillentA
                    axillentA
                    axillent
                    can you explain exactly what do you want?
                    PIR is triggering event and someone is taking picture at this moment?
                    sense and drive
                      Moshe LivneM
                      Moshe LivneM
                      Moshe Livne
                      @axillent yes. just a door or hall sensor that will be triggered by the PIR, take a snapshot (or maybe several in 10 sec increment) and send them to the home automation system.
                        axillentA
                        axillentA
                        axillent
                        OK, I see. Do you want both PIR and camera module been connected to the same device? If yes this could have not much todo with mysensors. It can be regular arduino or rpi sketch sending pictures by FTP or email.
                        If you want to have PIR on other device you can use mysensor to sens PIR and trigger other device to take pictures using mysensors radio
                        sense and drive
                        • bjornhallbergB
                          bjornhallbergB
                          bjornhallberg
                          I have one (soon two) RPi with camera modules that take pictures and store / send to Pushbullet when a certain MySensors PIR is triggered. Has worked pretty well for the past year. and a Pi + Camera is still reasonably cheap plus it's a "real" computer so it can do anything with the camera and images. And the Pi camera is still pretty good, unless you happen to get a real bad clone from Ebay or something. Hardly worth it. I don't know how good these cameras in the store are, but I doubt they come anywhere near the simplicity and guaranteed quality of the Pi camera module.
                          If you like, you can also use the "motion" package on the Pi, but that will be a real hassle with false triggers and all. The cheap PIR motion sensors have worked surprisingly well. It's more a question of positioning them right so you don't have problems with sunlight, fireworks, curious magpies etc.
                          I have my RPi inside camera housings I got from AliExpress. There are a couple there that are pretty good. I think finding a bracket can be more of a challenge. I have J-brackets that fit under the eaves.
                          I have the raspimjpeg script running on the Pi btw. You could just use raspistill I suppose but it's nice to be able to manually view the camera feed from the browser and have remote control at your fingertips. Hell, you could even get one of those motorized RPi things that are able to turn the camera.
                          I have a sort of Power Over Ethernet going for my cameras btw.
                          Moshe LivneM axillentA 2 Replies Last reply
                            Moshe LivneM
                            Moshe LivneM
                            Moshe Livne
                            @bjornhallberg That is a very cool setup although i suspect its not very economical. the pi+camera would cost ~80$ i think. plus casing and bracket would get you very close to foscam if not higher. I was aiming at cheapest possible solution. maybe even one that can run on battery.
                              Mickey
                              wrote on last edited by Mickey
                              http://www.aliexpress.com/item/LYNEW-Portable-Mini-Wireless-wifi-Router-3G-4G-Hotspot-Wifi-Hotspot-support-3G-USB-modems/32257312139.html
                              Today there are openwrt enable modules on aliexpress that start from below 8$ that can be attached to mjpg usb camera and can take pictures and streams with less than 10$ price tag.
                              • M Mickey
                                Moshe LivneM
                                Moshe LivneM
                                Moshe Livne
                                @Mickey this device is a gsm hotspot generator. it connects to a USB GSM dongle and allows you to connect to it either wired or wirelessly. I have never seen devices like the ones you mention. they could be a good solution
                                  axillentA
                                  axillentA
                                  axillent
                                  #22
                                  do not stick to it's original application
                                  the idea is that open-wrt can run on this small things. Open-wrt is a linux type system, you can program it very similar to RPI
                                  it is very cool if any camera working example exists for open-wrt
                                  sense and drive
                                    axillentA
                                    axillentA
                                    axillent
                                    @bjornhallberg very nice setup! my congratulations!
                                    for DIY you did it pretty well
                                    but cost vise I do not see how this can be more efficient comparing to foscam
                                    sense and drive
                                      Moshe LivneM
                                      Moshe LivneM
                                      Moshe Livne
                                      @axillent Oh, still not used to thinking this way. This is beyond the (very limited) limits of my knowledge.... can be great.... total setup fee of ~15$
                                        Mickey
                                        I have an example of this just with tl-wr703n but the one I posted from aliexpress is just the same:
                                        openwrt webcam
                                        • M Mickey
                                          openwrt webcam
                                          Moshe LivneM
                                          Moshe LivneM
                                          Moshe Livne
                                          @Mickey very good and detailed article. I have several of the GSM modems (that I now understand are not GSM modems at all) somewhere so i'll see if they can be flashed with openwrt. should be fuuuunnnn.
