  2. Announcements
  3. Sensebender Micro
Sensebender Micro
584 Posts 84 Posters 635.1k Views 35 Watching
  • tekkaT tekka
    @hek said:
    @jeylites
    Yes, have a look at the bootloader here:
    https://github.com/mysensors/Arduino/tree/master/MYSBootloader
    You can test OTA updates using the MYSController. It overwrites program memory in-place during boot. If communication goes down or fails during this process the node won't boot up again (you have to upload a new sketch while connected to you computer).
    If the communication fails, the bootloader will remain "bootloading", i.e. will try to fetch a new firmware from the controller until the CRC matches - no need to upload a sketch via computer.
    MYSBootloader 2.0 will have SHA signing implemented: for those nodes without ATSHA204 which need signed OTA updates :)
    jeylitesJ
    jeylitesJ
    jeylites
    Do I have to include those files into my sketch or just install MYS on windows and it will auto detect? In other words, do I have to make any changes to the sketch?
    Is there any tutorial on MYS implementation?
    hekH 1 Reply Last reply
    • jeylitesJ jeylites
      @jeylites
      You should read up on what a bootloader is and how to install it.
      http://www.arduino.cc/en/Hacking/Bootloader?from=Tutorial.Bootloader
      Might be good to start another thread if you have more MYSController/bootloader questions,
        @jeylites
        marceltrapmanM
        marceltrapmanM
        marceltrapman
        Nicely put :)
        I would say 'please start another thread because this will never be found again and will help other as well'...
        Just my 2 cents.
        Fulltime Servoy Developer
        • rvendrameR
          rvendrameR
          rvendrame
          is 3V the absolute maximum or 3.3V is acceptable to power it? For non-battery operated sensors, it may be easier to find a 3.3V regulators instead 3V (at least in my country).
          ESP8266 GW + mySensors 2.3.2
          Alexa / Google Home
          • tbowmoT
            tbowmoT
            tbowmo
            @rvendrame
            absolute maximum voltage is 3.6V, above that you'll let the magic smoke out of the following components:
            • Si7021
            • external flash
            • radio module.
            Only the atmega328 and atsha204 will survive.
            korttomaK 1 Reply Last reply
            • rvendrameR
              rvendrameR
              rvendrame
              But will all components work properly on 3.3V?
              Alexa / Google Home
              • tbowmoT
                tbowmoT
                tbowmo
                @rvendrame
                Yes they would
                • rvendrameR
                  rvendrameR
                  rvendrame
                  @tbowmo thx a lot!
                  Alexa / Google Home
                  • D
                    doblanch
                    I didn't find mention of it. What is the expected battery life ?
                    I was going to replace AA by CR123 to gain in space.
                    thkx
                      I posted some measurements above. Hard to say a definite battery life expectation. Depends on many factors such as battery quality, send frequency and what external sensors you attach.
                      D 1 Reply Last reply
                        @gol
                        It was measured by @blacey to 0.05 mA while sleeping and 0.95 mA during transmit. @tbowmo got some higher figures but they were most probably related to running a NRF24L01+ clone.
                        @jeylites
                        The sensbender has a external flash which means we can safely store the OTA firmware while normal sketch is running. When everything has been downloaded the DualOptiboot moves new firmware from flash to program memory during bootup. The code for this has been written (in development branch) but has not been tested yet (I failed handsoldering them :() .
                        doblanch
                        wrote on last edited by doblanch
                        #38
                        @hek I computed that sending a value every minute with a 10 seconds of communication every minute (wakeup), the autonomy for a single 3V 1500mA CR123 lithium battery is around 1 year (312 Days). Around 2 year for a dual Lithium AA, I guess.
                        If there is 5 second of wakeup every minute, it's 500 days for a single cell CR123.
                        Purely theorical... but it gives an order of magnetude.
                          doblanch
                          @hek Of course it's difficult to predict, it's just to have an order of magnitude, specially if I want to use a CRV123 3V battery. I don't want to change it every 2 months. One year should be good.
                          • H
                            H
                            Hausner
                            wrote on last edited by Hausner
                            #40
                            Would this work with a 3,7V Li-Ion 18650 cell? Because I've got a S... load from old laptops
                            • tbowmoT tbowmo
                              @rvendrame
                              • Si7021
                              • external flash
                              • radio module.
                              korttomaK
                              korttomaK
                              korttoma
                              • Si7021
                              • external flash
                              • radio module.
                              Refering to what @tbowmo said and if you measure your batteries you will find that they will give more than 4V when fully charged I came to the conclusion that this is not a good idea.
                              However if someone has a good proposal for how these kind of batteries are best used with the Sensebender Micro I would like to know also.
                              • Tomas
                                Mickey
                                wrote on last edited by Mickey
                                #42
                                mcp1702 for example...
                                • greglG
                                  greglG
                                  gregl
                                  Really nice board!
                                  I think it would be good to have ( ver 2? ) a space for a voltage reg. Perhaps as an option, just put the pads on the pcb and user can add regulator if they need to.
                                  This way larger batteries such as the 18650 cells could be used.
                                  jeylitesJ 1 Reply Last reply
                                  • greglG gregl
                                    Really nice board!
                                    jeylitesJ
                                    jeylitesJ
                                    jeylites
                                    I think version 2 should have a voltage regulator and about the same number of outputs as Arduino Nano.
                                    • tbowmoT
                                      tbowmoT
                                      tbowmo
                                      @jeylites
                                      It's designed to be a simple, minimal, small sensor node.. Operating from 2xAA batteries. So there is no need for voltage regulator onboard, I know this both simpilfies the circuit, but also makes some limitations on the powersource.
                                      What you are asking for, is an Arduino Nano, this has voltage regulator, and the number of IOs that you want :)
                                      • tbowmoT tbowmo
                                        @jeylites
                                        jeylitesJ
                                        jeylitesJ
                                        jeylites
                                        @tbowmo I have nothing against Sensebender Micro. I just feel there should be Sensebender full size version to facilitate the number of I/O one may need.
                                        • G
                                          G
                                          gloob
                                          So the shipment will start today for the preorders? I'm really excited to receive the new sensors.
                                          tbowmoT 1 Reply Last reply
