  3. Gateway device
Gateway device
151 Posts 19 Posters 155.2k Views 21 Watching
  • pliniosenioreP
    pliniosenioreP
    plinioseniore
    this is my first post and I've pointed here by @hek while discussing of MySensor and Souliss (that is a project similar and different at same time from MySensor).
    Just yesterday we got Souliss running on ESP8266 thanks to the porting of the Arduino cores on that MCU, this is an option that in my opinion you should take in account. The use of ESP8266 (and generally of all other) as WiFi to USART isn't impressive, I've never been in love with AT commands and I prefer binary communication compared to ASCII, but generally your AVR USART became your bottleneck.
    Compared to SPI, USART isn't a master/slave protocol and the communication is driven by the transceiver, this is a really mess. When you use SPI, your low-RAM AVR decide when read data and this allow you to use the RAM of the transceiver as an external buffer, the tranceiver has mostly more RAM than the AVR.
    While running over USART, the transceiver send data when want, so you should care on the AVR of buffering and process the frame only once is complete.
    More, the ESP8266 has multiple firmware release that doesn't provide a consistent behavior, so you end-up with a your own firmware to bridge data to USART. But once you need to program the ESP8266, you are just a step away to load on it the whole code.
    Hope that this can help.
    Regards,
    Dario.
    Souliss, Arduino and Android based SmartHome and IoT
    http://www.souliss.net
    @soulissteam
    • tbowmoT
      tbowmoT
      tbowmo
      @plinioseniore
      You got a couple of good points there.. So your advice is to find a SPI device for WiFi instead of the ESP8266 module?
      Been looking for it, and only found CC3000 module, which (if I remember right) have problems with stability. Is there anything else out there that is affordable for WiFi connection, and usable from Arduino?
      What I want in this device, is to have multiple connection methods, that is you can have nrf24l01+ for 2g4 sensor networks, rfm69 for sub 1Ghz sensor networks, and then choose between wired or wireless LAN connectivity to your controller (or serial, if that is wanted).
      At the same time, we need to have security in mind, and support the standard authentication methods that is available for mysensors by now (using ATSHA204 chips).
      I haven't looked that much at the ESP8266 as a platform thing, but it might be limited as a target platform, if we want to have all the different technologies connected.
      • pliniosenioreP
        pliniosenioreP
        plinioseniore
        @tbowmo
        Actually there is really no reason to still use AVR, while there are good reason to use Arduino. I mean, ESP8266 is a SoC that contains both MCU and WiFi radio, you can program the MCU directly and run on it what you need.
        Actually there is a porting of Arduino (as core of libraries and methods) to the ESP8266 that is very stable and let you run your own code on the module itself, without have an AVR in between. The ESP8266 has also SPI hardware support, that can give you the way to interact to common radio like nRF24 or RFM69, even if some porting will be required to get the goal. Actually we have just ported Souliss and running over ESP8266 and is really working smoothly.
        In terms of hardware there is no one good answer, mostly depends on your (and MySensor) architecture. The Souliss architecture support multiple bridge and routers, with RF and RS485 communication, so it makes sense for us to have nodes based on microcontrollers, this keep power usage and complexity low.
        But if you have a start architecture (and probably MySensor has, correct me if I'm wrong) it may also make sense to move to OS based devices with an RF radio to join small and cheap microcontroller nodes.
        I know that design need a full stop, otherwise ideas storm far away from the goal. I'm just here to say that use a WiFi to USART device as transceiver for a 2Kbyte or 8 Kbyte RAM microcontroller is a bad design, and in my opinion non-WiFi RF may have short life in smarthome solutions.
        What I saw in the three years running Souliss, is that further you try to automate, more likely you end up into a central point of decision, that is an OS based device. So you likely will be into a native WiFi or Ethernet device and this lead to use those technology widely, this is likely if you cannot run new cables. If you can run cables, RS485 looks still a good solution.
        Regards,
        Dario.
        @soulissteam
          Thanks for the feedback @plinioseniore .
          Yes, but still, isn't power consumption a bit too high on these puppies to use them for battery operated devices?
          Last time I checked they were like 10x NRF. And I imagine powerup/reconnect time to a wifi network is much longer than the parts of a second we see for NRF24L01.
          Still it it would be very interesting to get the MySensors library up and running in an ESP! The more options the better. There isn't really any platform quirks or libraries used in the development branch.
          For a ESP <-> NRF/RF69 gateway device, power consumption is not an issue. And I agree that it is bad that the USART communication is slow (and non consistent between versions) but it should still be able to shuffle around 70 (MySensors) messages per second at a moderate 19200 bps.
          • pliniosenioreP
            pliniosenioreP
            plinioseniore
            @hek
            It mostly depends on what you need, as pointed before, my problem wasn't the USART speed it self.
            But that I was no longer able to use the transceiver as a buffer, because is the transceiver to decide when send data over the USART, rather SPI as master allow the MCU to decide when get data.
            This is a problem with ATmega328 that has much less RAM that the transceiver that is attached to, but of course depends also on the average lenght of the frames that you over the air.
            Dario.
            @soulissteam
            • tbowmoT
              tbowmoT
              tbowmo
              Ok guys, I need some feedback before I start routing PCB again (for the 10th time :))
              Could some of you please look at the schematics, and see if I have missed something? Also, I have made some design decisions lately, where I removed LEDs / buttons, and placed a pinheader for MMI. I have also added an extra pinheader for the unused GPIOs
              MySensorsGW-schematic.pdf
              Also, for refference, here are a 3d drawing of the current component layout.
              It's designed so that antennas for NRF module / ESP8266 is hanging over the edge on the board (in the bottom of the picture), and W5100 board is having the ethernet connector besides the micro usb connector (which is top right of the picture). ISP programming header is located on the bottom side of the PCB, as it's only needed for initial development.
              This is still a conceptual thing though..
              So any comments, please? :)
              • AnticimexA
                AnticimexA
                Anticimex
                KiCad FTW! :)
                Looks good to me. I have been able to run the ATSHA SDA pin without a pull without problems but I do know Atmel recommends it so I guess it might be good to have. It should not need to be of any high precision so it ought to be cheap.
                • tbowmoT
                  tbowmoT
                  tbowmo
                  @Anticimex
                  It doesn't cost anything to add footprints for extra pullup resistors, or decoupling caps. (Other than some time placing them). So I am throwing it in wherever I can..
                  I have sticked with 0603 components btw. So it should be easier to hand solder the first prototypes :)
                  The board is still 5x5 cm, probably being 4 layer so I can get room for all the wiring.
                  AnticimexA 1 Reply Last reply
                  • tbowmoT tbowmo
                    @Anticimex
                    AnticimexA
                    AnticimexA
                    Anticimex
                    @tbowmo
                    Ah, did not see a no-mount indicator for it so I assumed it would be mounted by default. I agree on keeping all options open if space allows for it.
                    Yes, you probably have to go 4-layer on that. I had some trouble fitting the routs on my sensorboard in that space. And it has less components.
                    • tbowmoT
                      tbowmoT
                      tbowmo
                      @Anticimex
                      Havent set any components as NM yet ;) just throwing components iñ at the moment
                      • RJ_MakeR
                        RJ_MakeR
                        RJ_Make
                        I'm sure I missed it but..... as it stands this can be used as a serial gateway correct?
                        RJ_Make
                        • tbowmoT tbowmo
                          @Salmoides
                          I don't own a 3d printer either. it's a secondary thing for me (I'm not that much into mechanical design, I let others do that part :))
                          @Anticimex
                          It should be able to have both radios connected, yes.. But what about available codespace? (Ok, we've got 4 times as much space as in the 328p).
                          The 1284p exist in DIP style, http://dk.mouser.com/ProductDetail/Atmel/ATMEGA1284P-PU/?qs=K8BHR703ZXgaD0L1rKdwiQ%3D%3D Can't be any more breadboard friendly than that :)
                          The wifi option is actually @hek's idea. And if we are going to make a pcb, it wouldn't hurt to make it possible, if someone wants to use it.
                          I had briefly looked at PoE, but got scared away by the specifications for it :) Think that it's around 48V, and using special magnetics (if you are going to be standards compliant). So need a good switchmode stepdown converter from 48V to 5V. But as it's still on the conceptual state in my head, we might be able to find something that makes it "easy to implement".
                          Of course size is not that big an issue here.. But 5x5 is standard for small batch pcb's from many of the cheap china board houses. that's why I would aim at that size.
                          Prototyping area could be an option. Also was thinking about throwing in a sensors or two. Again, it's a concept that has to evolve a bit.. Getting inputs and let it sink in, in order to make an awesome board :)
                          P
                          P
                          phil pritchard
                          @tbowmo
                          re: PoE supply
                          http://www.freetronics.com.au/products/power-over-ethernet-regulator-8023af#.VWCsPLmqqko
                          is cheap and easy you may be able to piggy back it on the board.
                          hope it helps
                          phil
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            #66
                            @ServiceXp
                            It could be used as serial gateway, there's a ftdi chip onboard. But also place for Ethernet and WiFi connections, together with both nrf24 module and a rfm69 module.
                            Made to be as versatile as possible.
                            @phil-pritchard
                            Ethernet is an add-on module, so a bit hard to implement Poe circuitry on this board. If we could find w5100 module with Poe, it might work.
                            • tbowmoT
                              tbowmoT
                              tbowmo
                              Btw. Would it be an idea to include a sensor onboard? (Si7021)
                              • AnticimexA
                                AnticimexA
                                Anticimex
                                I see no reason not to (depending on available space) add footprints for various "standard" sensors in addition to a IO header on the board. I have no idea on what impact it has on the sw to have a gateway report sensor values to "itself" but I see no reason for why that could not be supported (if it isn't already).
                                End of double-negations ;)
                                • tbowmoT
                                  tbowmoT
                                  tbowmo
                                  @Anticimex
                                  What do you define as "standard" sensors?
                                  • tbowmoT tbowmo
                                    @Anticimex
                                    AnticimexA
                                    AnticimexA
                                    Anticimex
                                    @tbowmo
                                    Perhaps an unfortunate label. I guess standard footprints would be a better word. I mean footprints for the most commonly used sensor cases. TO-92, DFN and etc. connected such as the typical sensors (1-wire temps and Si7021 like) will "fit".
                                    • tbowmoT
                                      tbowmoT
                                      tbowmo
                                      #71
                                      @Anticimex
                                      Problem is that each sensor has its own pinout, so you can't make generic footprints.
                                      There already is a GPIO header, with 8 pins (4 analog and 4 digital) plus power. So people can make their own daughterboards with sensors. Might convert 2 of them to i2c bus with pull up, and then have si7021 onboard.
                                      • pliniosenioreP
                                        pliniosenioreP
                                        plinioseniore
                                        Have you considered Grove plugs for sensors? This can give flexibility and a large enough number of sensors at a reasonable price.
                                        @soulissteam
                                        • tbowmoT
                                          tbowmoT
                                          tbowmo
                                          @plinioseniore
                                          Problem is space on the pcb :) as I see it Grove connectors are big and bulky. I have placed a couple of pinheaders (one 8 pin, and one 12 pins) for external devices right now..
