  3. Gateway device
Gateway device
151 Posts 19 Posters 155.2k Views 21 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    #66
    @ServiceXp
    It could be used as serial gateway, there's a ftdi chip onboard. But also place for Ethernet and WiFi connections, together with both nrf24 module and a rfm69 module.
    Made to be as versatile as possible.
    @phil-pritchard
    Ethernet is an add-on module, so a bit hard to implement Poe circuitry on this board. If we could find w5100 module with Poe, it might work.
    • tbowmoT
      tbowmoT
      tbowmo
      Btw. Would it be an idea to include a sensor onboard? (Si7021)
      • AnticimexA
        AnticimexA
        Anticimex
        I see no reason not to (depending on available space) add footprints for various "standard" sensors in addition to a IO header on the board. I have no idea on what impact it has on the sw to have a gateway report sensor values to "itself" but I see no reason for why that could not be supported (if it isn't already).
        End of double-negations ;)
        • tbowmoT
          tbowmoT
          tbowmo
          @Anticimex
          What do you define as "standard" sensors?
          AnticimexA 1 Reply Last reply
          • tbowmoT tbowmo
            @Anticimex
            AnticimexA
            AnticimexA
            Anticimex
            @tbowmo
            Perhaps an unfortunate label. I guess standard footprints would be a better word. I mean footprints for the most commonly used sensor cases. TO-92, DFN and etc. connected such as the typical sensors (1-wire temps and Si7021 like) will "fit".
            • tbowmoT
              tbowmoT
              tbowmo
              #71
              @Anticimex
              Problem is that each sensor has its own pinout, so you can't make generic footprints.
              There already is a GPIO header, with 8 pins (4 analog and 4 digital) plus power. So people can make their own daughterboards with sensors. Might convert 2 of them to i2c bus with pull up, and then have si7021 onboard.
              • pliniosenioreP
                pliniosenioreP
                plinioseniore
                Have you considered Grove plugs for sensors? This can give flexibility and a large enough number of sensors at a reasonable price.
                Souliss, Arduino and Android based SmartHome and IoT
                http://www.souliss.net
                @soulissteam
                • tbowmoT
                  tbowmoT
                  tbowmo
                  @plinioseniore
                  Problem is space on the pcb :) as I see it Grove connectors are big and bulky. I have placed a couple of pinheaders (one 8 pin, and one 12 pins) for external devices right now..
                  • AnticimexA
                    AnticimexA
                    Anticimex
                    I think a header for daughterboards will go far in terms of flexibility.
                    • tbowmoT
                      tbowmoT
                      tbowmo
                      updated the first post in the thread, with links to github project, and pdf of schematics (on github). So it will always point at the latest available one, so I don't have to remember that there is a forum thread to keep updated :)
                      • AnticimexA
                        AnticimexA
                        Anticimex
                        Nice nice. I am very interested in this as I have more or less decided to swap to RF69 from RF24. Both for range and because I like the concept of having the radio handle the encryption on my signed packets (yep, I am paranoid as hell). Unfortunately, it means my current gateway has to go but I have made a "sensor evaluation board" (got the PCBs, still waiting for components). Once I get the components and can verify all the features I put on it I will publish it in this forum for those interested. It will still rely on Arduino modules and such so it is not the hard-core approach like the Sensebender Micro though.
                        • tbowmoT tbowmo
                          AnticimexA
                          AnticimexA
                          Anticimex
                          @tbowmo
                          I believe you previously had the interrupt for RF69 connected. But it does not seem to be anymore. Any particular reason for skipping that?
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            @Anticimex
                            I'm still rearranging things in the schematics, in order to get the best board layout :).
                            Could we go with one combined irq for both radio modules? (rfm69/Nrf24)?
                            / Thomas
                            • AnticimexA
                              AnticimexA
                              Anticimex
                              I see no reason why that would not work. I sure hope so as I did that on my board :)
                              Both radios will never be connected (or at least in use) simultaneously so it should be ok.
                              • tbowmoT
                                tbowmoT
                                tbowmo
                                @Anticimex
                                could be someone got brainfreeze and decided to go with both radios at once in one setup.. On the other hand, we're not using IRQ for the nrf24 at the moment..
                                • tbowmoT tbowmo
                                  @Anticimex
                                  AnticimexA
                                  AnticimexA
                                  Anticimex
                                  @tbowmo
                                  Even so, the electrical properties of the interrupt outputs on the module should ensure no meltdown occurs. And I think the user would get bigger problems than just having to figure out the origin of the interrupt :)
                                  • AnticimexA
                                    AnticimexA
                                    Anticimex
                                    On the other hand, is there a usecase to provide HW interrupt functionality for a dagughterboard on the gateway? Since it will "by definition" have a solid power supply, any sensors using interrupts should be fine with the soft-interrupt options (have not looked into those myself though) or simply use polling. Power saving makes little sense in this case. The radios are probably better off with "real" interrupts (if we ever use them).
                                    • tbowmoT
                                      tbowmoT
                                      tbowmo
                                      been fiddling with layout, and schematics changes..
                                      Added a couple of MAX3002E for level conversion between 5V and 3V3 domains on the board. (Links to the schematic are in the first post of this thread)
                                      Waiting for samples of the ESP8266, and W5100 modules, so I can make some last measurements before ordering boards.
                                      • pliniosenioreP
                                        pliniosenioreP
                                        plinioseniore
                                        just want to share with you some of our progress in a board similar to the one that you are designing.
                                        This is based on Atmega32U4 and has socket for nRF24L01 and ESP8266 and is designed to be battery operated and support Grove connector. The board has mosfet to switch off the sensor while sleeping and keep low the consumption, this should stand a year on battery.
                                        We just received the PCB, picture at the link below,
                                        http://www.souliss.net/2015/06/sensor-battery-board-pcb-arrived.html
                                        The schematic and layout are open-source and hope that this board may fit some needs also in the MySensor community
                                        https://github.com/souliss/boards/tree/master/Battery_Operated_Board/Ver1
                                        Regards,
                                        Dario.
                                        @soulissteam
                                        • tbowmoT
                                          tbowmoT
                                          tbowmo
                                          @plinioseniore
                                          Looks like a nice board you have created... Only problem is, that we run out of memory on atmega328, if we want to run with signing and have MQTT client on board.
                                          So that is why we have bumped the processor to a atmega1284 instead, having 4 times the memory, than atmega328. Also, with this board, we have the posibility to use both RFM69 and NRF24L01 on the sensor network..
