  3. Gateway device
Gateway device
151 Posts 19 Posters 155.2k Views 21 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    @plinioseniore
    Problem is space on the pcb :) as I see it Grove connectors are big and bulky. I have placed a couple of pinheaders (one 8 pin, and one 12 pins) for external devices right now..
    • AnticimexA
      AnticimexA
      Anticimex
      I think a header for daughterboards will go far in terms of flexibility.
      • tbowmoT
        tbowmoT
        tbowmo
        updated the first post in the thread, with links to github project, and pdf of schematics (on github). So it will always point at the latest available one, so I don't have to remember that there is a forum thread to keep updated :)
        AnticimexA 1 Reply Last reply
        • AnticimexA
          AnticimexA
          Anticimex
          Nice nice. I am very interested in this as I have more or less decided to swap to RF69 from RF24. Both for range and because I like the concept of having the radio handle the encryption on my signed packets (yep, I am paranoid as hell). Unfortunately, it means my current gateway has to go but I have made a "sensor evaluation board" (got the PCBs, still waiting for components). Once I get the components and can verify all the features I put on it I will publish it in this forum for those interested. It will still rely on Arduino modules and such so it is not the hard-core approach like the Sensebender Micro though.
          • tbowmoT tbowmo
            AnticimexA
            AnticimexA
            Anticimex
            @tbowmo
            I believe you previously had the interrupt for RF69 connected. But it does not seem to be anymore. Any particular reason for skipping that?
            • tbowmoT
              tbowmoT
              tbowmo
              @Anticimex
              I'm still rearranging things in the schematics, in order to get the best board layout :).
              Could we go with one combined irq for both radio modules? (rfm69/Nrf24)?
              / Thomas
              • AnticimexA
                AnticimexA
                Anticimex
                I see no reason why that would not work. I sure hope so as I did that on my board :)
                Both radios will never be connected (or at least in use) simultaneously so it should be ok.
                • tbowmoT
                  tbowmoT
                  tbowmo
                  @Anticimex
                  could be someone got brainfreeze and decided to go with both radios at once in one setup.. On the other hand, we're not using IRQ for the nrf24 at the moment..
                  • tbowmoT tbowmo
                    @Anticimex
                    AnticimexA
                    AnticimexA
                    Anticimex
                    @tbowmo
                    Even so, the electrical properties of the interrupt outputs on the module should ensure no meltdown occurs. And I think the user would get bigger problems than just having to figure out the origin of the interrupt :)
                    • AnticimexA
                      AnticimexA
                      Anticimex
                      On the other hand, is there a usecase to provide HW interrupt functionality for a dagughterboard on the gateway? Since it will "by definition" have a solid power supply, any sensors using interrupts should be fine with the soft-interrupt options (have not looked into those myself though) or simply use polling. Power saving makes little sense in this case. The radios are probably better off with "real" interrupts (if we ever use them).
                      • tbowmoT
                        tbowmoT
                        tbowmo
                        been fiddling with layout, and schematics changes..
                        Added a couple of MAX3002E for level conversion between 5V and 3V3 domains on the board. (Links to the schematic are in the first post of this thread)
                        Waiting for samples of the ESP8266, and W5100 modules, so I can make some last measurements before ordering boards.
                        • pliniosenioreP
                          pliniosenioreP
                          plinioseniore
                          just want to share with you some of our progress in a board similar to the one that you are designing.
                          This is based on Atmega32U4 and has socket for nRF24L01 and ESP8266 and is designed to be battery operated and support Grove connector. The board has mosfet to switch off the sensor while sleeping and keep low the consumption, this should stand a year on battery.
                          We just received the PCB, picture at the link below,
                          http://www.souliss.net/2015/06/sensor-battery-board-pcb-arrived.html
                          The schematic and layout are open-source and hope that this board may fit some needs also in the MySensor community
                          https://github.com/souliss/boards/tree/master/Battery_Operated_Board/Ver1
                          Regards,
                          Dario.
                          Souliss, Arduino and Android based SmartHome and IoT
                          @soulissteam
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            @plinioseniore
                            Looks like a nice board you have created... Only problem is, that we run out of memory on atmega328, if we want to run with signing and have MQTT client on board.
                            So that is why we have bumped the processor to a atmega1284 instead, having 4 times the memory, than atmega328. Also, with this board, we have the posibility to use both RFM69 and NRF24L01 on the sensor network..
                            • tbowmoT
                              tbowmoT
                              tbowmo
                              Tried to make a concept drawing, of NRF module placement
                              the esp8266 is placed in a similar way, on the right edge of the board, also hanging over the edge with the antenna part.
                              the W5100 board (which is similar to this one from itead studio) is turned 180 degrees, which makes the ethernet jack placement above the large "empty" space on the board (there is a 2x3 pinheader in the concept drawing)
                              The micro usb connector will be just beside the ethernet jack. between the ether jack, and the single pinheader pin (this is the antenna connection point for the rfm69 you can put on the bottom of the board)
                              Things are still a bit conceptual, trying to visualize it for my self :)
                              • R
                                R
                                rickmontana83
                                I'll second (third? fourth? whatever...) the suggestion to design this to fit a cheap and readily available enclosure. Something like:
                                http://www.aliexpress.com/item/Free-Shipping-Plastic-Waterproof-Clear-Cover-Electronic-Project-Box-Enclosure-Case-85-58-33MM/2025247551.html
                                (Not saying that's ideal; just an example.)
                                • tbowmoT
                                  tbowmoT
                                  tbowmo
                                  @rickmontana83
                                  the board is 50x50 mm, and with the radio / wifi protruding over the edge, this box should fit nicely.
                                  The reason why I chose 50x50mm for the board size, is that it's either 50x50mm, or 100x100mm board when we order prototypes, which is more expensive. (And I like to make things small :))
                                  • R
                                    R
                                    rickmontana83
                                    Agree about smaller. Everything looks classier with less wasted space.
                                    Probably too late now, but if the board had mounting holes that lined up with the enclosure that would be sweet. I'm always at a loss for how to keep my boards stable inside their plastic homes. Would love to hear peoples' solutions for mounting when the holes don't line up.
                                    • tbowmoT
                                      tbowmoT
                                      tbowmo
                                      @rickmontana83
                                      nothing's too late (yet). I haven't even ordered the first prototype batch yet. Still ironing out some details, and routing the PCB (I have only scratched the routing for the 10th time or so :s ). Actually I had thought about adding a couple of mounting holes in the board..
                                      I'll see if the boxes that I have, resembles the one that I just linked to.. (I've talked with @hek about finding some enclosures a couple of days ago, when we suddenly found a seller on ali express, that only had enclosures of various kinds).
                                      RJ_MakeR 1 Reply Last reply
                                      • pliniosenioreP
                                        pliniosenioreP
                                        plinioseniore
                                        @tbowmo
                                        Yes the Atmega32U4 and Atmega328 has in the RAM their main problem, in our case we run smoothly in the 2KBytes available because we don't use ASCII in the protocol, but binary only.
                                        Then the board is for as a remote sensor node, running on battery, not a main gateway board.
                                        In any case, the board that you are designing will work nicely also with Souliss.battery_board-1.jpg
                                        @soulissteam
                                        • tbowmoT tbowmo
                                          @rickmontana83
                                          RJ_MakeR
                                          RJ_MakeR
                                          RJ_Make
                                          @tbowmo Mounting holes would be very good. :flushed:
                                          RJ_Make
