  3. Windows GUI/Controller for MySensors
myscontrollermysbootloader
486 Posts 101 Posters 514.7k Views 73 Watching
  • J JoergP
    I'm new to MySensors and playing around with this implementation since some weeks. I implemented an interface from serial to MQTT per python and everything is running fine so far. The last days I spend some time with the bootloader (it is a great feature!!!). I created also a python mqtt client that will take care on that.
    I got really crazy the last 2 days with the CRC calculation. I always got a different CRC as as the MYSController. Now I found out, that it seems that the last byte within the HEX file is interpreted as 0xFF instead of the real data. I flashed now one sensor with the MYSController and as I can see in the log-file -> the last byte is read from the HEX as wrong value (0xFF instead of 0x14) -> therefore the HEX file is not flashed correctly (last byte is wrong) -> it seems that this is a bug in MYSController. (I'm using version 0.1.2.278)
    Can you check that please?
    tekkaT
    tekkaT
    tekka
    wrote on last edited by tekka
    #119
    @JoergP Indeed, bug confirmed. There is an error in the block padding code. I will push the update soon. Thanks for reporting!
    • C
      C
      cdr
      First of all, thanks Tekka for the great MYScontroller!
      I want to get started with the MYSbootloader but I can't get it to work. I've followed each step securely but I never "see" my arduino in MYScontroller after flashing the bootloader. Perhaps I misunderstand the theory behind the bootloader? Maybe the fuses are wrong, I don't know.
      Perhaps someone can reply to the following;
      • Can I just attach a radio module to an Arduino Nano as instructed on the site, clear the eeprom and then burn the bootloader using usbasp? (as instructed in this thread) Or do I need to upload the gateway sketch before burning the bootloader?
      • I have a hard time understanding what the bootloader does, I think it enables low level nrf functionality for OTA and Myscontroller instructions like reboot and clear eeprom etc. But when I upload a sketch does that mean the bootloader inits the nrf first and then the uploaded sketch will just re-init the nrf again?
      • Is there a way to debug the bootloader?
      Have a good laugh if you will at these noob questions, but any help is appreciated :)
      tekkaT 1 Reply Last reply
      • C cdr
        tekkaT
        tekkaT
        tekka
        Yes, simply attach the radio and burn the bootloader with the correct fuse settings (see the fuses.txt file in the bootloader directory). If you intend to use MYSController, set AutoID to automatically assign IDs to the nodes.
        Yes, that's correct. The bootloader is a small piece of code located at the end of the flash area that is (if the fuses are set accordingly) executed first upon rebooting and allows for low-level OTA updates.
        Yes, there are several ways (e.g. visual with LED, serial output, or AVR DebugWire)...you may want to google these topics for further information..
        no problem :)
        • C
          C
          cdr
          Hi tekka,
          Thanks for the response and clarification. I think I need more knowledge about fuses and bootloaders, it could be that the arduino clones are giving me sh&t.
          Looking forward to my success and MYSloader 2.0 ofcourse!
          Thanks again for all your work.
          • tekkaT
            tekkaT
            tekka
            MYSController Version 0.1.2.280 released
            Changelog:
            • Bugfix FW padding (thanks @JoergP)
            • Handler rework
            • Logging format rework
            • Support battery-powered/sleeping nodes
            • Refactoring
            Update via update button in MYSController or download here.
              Mickey
              This is the most helpful tool I used since I started messing around with mysensors.
              I hate to nag but this tool source code would be a giant step to someone looking to create a new controller by himself.
              • R
                R
                robosensor
                Hello, how to verify right bootloader is uploaded to arduino?
                I'm using two Arduino Pro Mini 328 5.0V 16Mhz, one as ArduinoISP programmer and one as sensor node to upload bootloader and firmware.
                I followed manual (http://forum.mysensors.org/topic/838/windows-gui-controller-for-mysensors/76) step by step.
                I have tried MYSBootloader.hex coming from latest MYSController 0.1.2.280 and MYSBootloader.hex (1.1) from github with same results.
                Upload log is here:
                C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -cstk500v1 -PCOM10 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0x06:m -Uhfuse:w:0xDA:m -Ulfuse:w:0xF7:m
                         Using Port                    : COM10
                         Programmer Type : STK500
                         Hardware Version: 2
                         Firmware Version: 1.18
                         Topcard         : Unknown
                         Vtarget         : 0.0 V
                         Varef           : 0.0 V
                         Oscillator      : Off
                         SCK period      : 0.1 us
                Reading | ################################################## | 100% 0.05s
                avrdude: erasing chip
                Writing | ################################################## | 100% 0.03s
                avrdude: verifying ...
                Writing | ################################################## | 100% 0.02s
                avrdude: reading input file "0xF7"
                C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -cstk500v1 -PCOM10 -b19200 -Uflash:w:C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/MySensors/MYSBootloader.hex:i -Ulock:w:0x0F:m
                         Copyright (c) 2007-2009 Joerg Writing | ################################################## | 100% 0.02s
                avrdude: verifying lfuse memory against 0xF7:
                avrdude: load data lfuse data from input file 0xF7:
                avrdude: input file 0xF7 contains 1 bytes
                avrdude done.  Thank you.
                Wunsch
                         Using Port                    : COM10
                         Hardware Version: 2
                         Topcard         : Unknown
                         Vtarget         : 0.0 V
                         Varef           : 0.0 V
                         Oscillator      : Off
                         SCK period      : 0.1 us
                Reading | ################################################## | 100% 0.06s
                avrdude: reading input file "C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/MySensors/MYSBootloader.hex"
                Writing | ################################################## | 100% -0.00s
                avrdude: verifying flash memory against C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/MySensors/MYSBootloader.hex:
                avrdude: load data flash data from input file C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/MySensors/MYSBootloader.hex:
                avrdude: input file C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/MySensors/MYSBootloader.hex contains 32722 bytes
                avrdude: reading input file "0x0F"
                Writing | ################################################## | 100% 0.05s
                avrdude: verifying lock memory against 0x0F:
                avrdude: load data lock data from input file 0x0F:
                avrdude: input file 0x0F contains 1 bytes
                Fuses looks like right:
                avrdude: safemode: lfuse reads as F7
                avrdude: safemode: hfuse reads as DA
                avrdude: safemode: efuse reads as 6
                MYSController log after node with new bootloader start:
                14.06.2015 10:14:46	STARTUP	Initialize message logging
                14.06.2015 10:14:46	STARTUP	MYSController 0.1.2.280
                14.06.2015 10:14:46	STARTUP	FPC 2.6.4 / Lazarus 1.4
                14.06.2015 10:14:46	STARTUP	still under development :) tekka 2015
                14.06.2015 10:14:46	STARTUP	Load INI file...
                14.06.2015 10:14:46	STARTUP	INI version 0.1.2.280
                14.06.2015 10:14:46	INFO	*** Logging START ***
                14.06.2015 10:14:46	VERSION	MYSController 0.1.2.280
                14.06.2015 10:14:46	STARTUP	INI file loaded
                14.06.2015 10:14:46	STARTUP	Loading FW repository...
                14.06.2015 10:14:46	REPO	FW "Blink" loaded. t=10, v=1, blocks=72, crc=0xD098
                14.06.2015 10:14:46	REPO	FW "TimeReporter" loaded. t=20, v=1, blocks=840, crc=0x4AC5
                14.06.2015 10:14:46	REPO	FW repository loaded. Items=2
                14.06.2015 10:14:46	STARTUP	Initialize message types
                14.06.2015 10:14:46	NODE	New node discovered, node id=0
                14.06.2015 10:14:46	NODE	New node discovered, node id=255
                14.06.2015 10:14:49	INFO	Connected to 192.168.0.1:12345
                14.06.2015 10:14:59	UPDATE	4295098648
                14.06.2015 10:21:26	CHILD	New child discovered, node id=0, child id=0
                14.06.2015 10:21:26	RX	0;0;3;0;9;read: 255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                14.06.2015 10:21:26	RX	0;0;3;0;9;send: 0-0-255-255 s=255,c=3,t=8,pt=1,l=1,sg=0,st=bc:0
                14.06.2015 10:21:28	RX	0;0;3;0;9;read: 3-3-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                14.06.2015 10:21:28	RX	0;0;3;0;9;send: 0-0-3-3 s=255,c=3,t=8,pt=1,l=1,sg=0,st=ok:0
                14.06.2015 10:21:30	RX	0;0;3;0;9;read: 3-3-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                14.06.2015 10:21:30	NODE	New node discovered, node id=3
                14.06.2015 10:21:30	CHILD	New child discovered, node id=3, child id=internal
                14.06.2015 10:21:30	TX	3;255;3;0;6;M
                14.06.2015 10:21:30	RX	3;255;3;0;6;0
                14.06.2015 10:21:30	RX	0;0;3;0;9;send: 0-0-3-3 s=255,c=3,t=6,pt=0,l=1,sg=0,st=ok:M
                14.06.2015 10:21:32	RX	0;0;3;0;9;read: 3-3-0 s=255,c=3,t=11,pt=0,l=7,sg=0:Balcony
                14.06.2015 10:21:32	RX	3;255;3;0;11;Balcony
                14.06.2015 10:21:32	RX	0;0;3;0;9;read: 3-3-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
                14.06.2015 10:21:32	RX	3;255;3;0;12;1.0
                14.06.2015 10:21:32	RX	0;0;3;0;9;read: 3-3-0 s=1,c=0,t=16,pt=0,l=20,sg=0:Photoconductive Cel
                14.06.2015 10:21:32	CHILD	New child discovered, node id=3, child id=1
                14.06.2015 10:21:32	DEBUG	Update child id=1, type=LIGHT_LEVEL
                14.06.2015 10:21:32	RX	3;1;0;0;16;Photoconductive Cell
                14.06.2015 10:21:32	RX	0;0;3;0;9;read: 3-3-0 s=2,c=0,t=6,pt=0,l=3,sg=0:ds0
                14.06.2015 10:21:32	CHILD	New child discovered, node id=3, child id=2
                14.06.2015 10:21:32	DEBUG	Update child id=2, type=TEMP
                14.06.2015 10:21:32	RX	3;2;0;0;6;ds0
                14.06.2015 10:21:32	RX	0;0;3;0;9;read: 3-3-0 s=3,c=0,t=6,pt=0,l=3,sg=0:ds1
                14.06.2015 10:21:32	CHILD	New child discovered, node id=3, child id=3
                14.06.2015 10:21:32	DEBUG	Update child id=3, type=TEMP
                14.06.2015 10:21:32	RX	3;3;0;0;6;ds1
                14.06.2015 10:21:32	RX	0;0;3;0;9;read: 3-3-0 s=4,c=0,t=6,pt=0,l=3,sg=0:ds2
                14.06.2015 10:21:32	CHILD	New child discovered, node id=3, child id=4
                14.06.2015 10:21:32	DEBUG	Update child id=4, type=TEMP
                14.06.2015 10:21:32	RX	3;4;0;0;6;ds2
                14.06.2015 10:21:32	RX	0;0;3;0;9;read: 3-3-0 s=5,c=0,t=6,pt=0,l=3,sg=0:ds3
                14.06.2015 10:21:32	CHILD	New child discovered, node id=3, child id=5
                14.06.2015 10:21:32	DEBUG	Update child id=5, type=TEMP
                14.06.2015 10:21:32	RX	3;5;0;0;6;ds3
                14.06.2015 10:21:33	RX	0;0;3;0;9;read: 3-3-0 s=6,c=0,t=6,pt=0,l=3,sg=0:ds4
                14.06.2015 10:21:33	CHILD	New child discovered, node id=3, child id=6
                14.06.2015 10:21:33	DEBUG	Update child id=6, type=TEMP
                14.06.2015 10:21:33	RX	3;6;0;0;6;ds4
                14.06.2015 10:21:33	RX	0;0;3;0;9;read: 3-3-0 s=7,c=0,t=6,pt=0,l=3,sg=0:ds5
                14.06.2015 10:21:33	CHILD	New child discovered, node id=3, child id=7
                14.06.2015 10:21:33	DEBUG	Update child id=7, type=TEMP
                14.06.2015 10:21:33	RX	3;7;0;0;6;ds5
                14.06.2015 10:21:33	RX	0;0;3;0;9;read: 3-3-0 s=8,c=0,t=6,pt=0,l=3,sg=0:ds6
                14.06.2015 10:21:33	CHILD	New child discovered, node id=3, child id=8
                14.06.2015 10:21:33	DEBUG	Update child id=8, type=TEMP
                14.06.2015 10:21:33	RX	3;8;0;0;6;ds6
                14.06.2015 10:21:33	RX	0;0;3;0;9;read: 3-3-0 s=9,c=0,t=6,pt=0,l=3,sg=0:ds7
                14.06.2015 10:21:33	CHILD	New child discovered, node id=3, child id=9
                14.06.2015 10:21:33	DEBUG	Update child id=9, type=TEMP
                14.06.2015 10:21:33	RX	3;9;0;0;6;ds7
                14.06.2015 10:21:33	RX	0;0;3;0;9;read: 3-3-0 s=10,c=0,t=6,pt=0,l=3,sg=0:ds8
                14.06.2015 10:21:33	CHILD	New child discovered, node id=3, child id=10
                14.06.2015 10:21:33	DEBUG	Update child id=10, type=TEMP
                14.06.2015 10:21:33	RX	3;10;0;0;6;ds8
                14.06.2015 10:21:33	RX	0;0;3;0;9;read: 3-3-0 s=11,c=0,t=6,pt=0,l=3,sg=0:ds9
                14.06.2015 10:21:33	CHILD	New child discovered, node id=3, child id=11
                14.06.2015 10:21:33	DEBUG	Update child id=11, type=TEMP
                14.06.2015 10:21:33	RX	3;11;0;0;6;ds9
                14.06.2015 10:21:33	RX	0;0;3;0;9;read: 3-3-0 s=1,c=1,t=23,pt=2,l=2,sg=0:49
                14.06.2015 10:21:33	RX	3;1;1;0;23;49
                14.06.2015 10:21:36	RX	0;0;3;0;9;read: 3-3-0 s=3,c=1,t=0,pt=7,l=5,sg=0:26.5625
                14.06.2015 10:21:36	RX	3;3;1;0;0;26.5625
                14.06.2015 10:21:37	RX	0;0;3;0;9;read: 3-3-0 s=1,c=1,t=23,pt=2,l=2,sg=0:49
                14.06.2015 10:21:37	RX	3;1;1;0;23;49
                Node successfully start and connecting to gateway with new bootloader, but then I issue reboot command in MYSController, node hangs up completely, even reset button isn't working. Only power off, then power on helps. Assign firmware isn't working also (nothing happens).
                • R robosensor
                  Upload log is here:
                           Using Port                    : COM10
                           Hardware Version: 2
                           Topcard         : Unknown
                           Vtarget         : 0.0 V
                           Varef           : 0.0 V
                           Oscillator      : Off
                           SCK period      : 0.1 us
                  Wunsch
                           Using Port                    : COM10
                           Hardware Version: 2
                           Topcard         : Unknown
                           Vtarget         : 0.0 V
                           Varef           : 0.0 V
                           Oscillator      : Off
                           SCK period      : 0.1 us
                  tekkaT
                  tekkaT
                  tekka
                  #126
                  @robosensor said:
                  The MYSBootloader.hex file you are flashing has a wrong file size (=32722 bytes) in your post:
                  MYSBootloader 1.1 should have ~2kb
                  From your log I assume, that you flashed the sketch instead of the bootloader.
                  Please pay attention to steps 3 and 13 from the step-by-step manual.
                  R N 3 Replies Last reply
                  • tekkaT tekka
                    R
                    R
                    robosensor
                    @tekka I have noticed this, but I thought that this is due to the peculiarities of bootloader upload process (upper end of memory).
                     Directory of C:\Program Files (x86)\Arduino\hardware\arduino\avr\bootloaders\MySensors
                    14.06.2015  00:08    <DIR>          .
                    14.06.2015  00:08    <DIR>          ..
                    14.06.2015  09:59             5 548 MYSBootloader.hex
                                   1 File(s)          5 548 bytes
                    For sketch size is too big (32722 bytes), real sketch size is 19928 bytes.
                    In any case, thanks for the help, I'll try to figure it out or try to download it manually using avrdude.
                    • tekkaT tekka
                      N
                      N
                      NewFolk
                      @tekka
                      Hello, could you help me with uploading bootloader. I stuck on Step 5 step-by-step manual and get error
                      Arduino: 1.6.4 (Mac OS X), Плата"ATmega328 16Mhz MYSBootloader"
                      avrdude: error: could not find USB device with vid=0x16c0 pid=0x5dc vendor='www.fischl.de' product='USBasp'
                      I`m using 16Mhz pro mini clone and FTDI232
                      • tekkaT tekka
                        R
                        R
                        robosensor
                        wrote on last edited by robosensor
                        #129
                        @tekka I have googled for [avrdude bootloader "bytes of flash written"] and found many answers about big upload size for bootloader (> 32000 bytes). It seems that big size is the way it should be.
                        I have solved problem. I must power up node with newly burned bootloader but without sensor node firmware and upload firmware using MYSController
                        Incorrect way is: burn bootloader, burn sensor node firmware, powerup sensor.
                        Thank you for great software! :)
                        • N NewFolk
                          @tekka
                          tekkaT
                          tekkaT
                          tekka
                          @NewFolk You'll need e.g. USBasp or ArduinoISP to flash a new bootloader. If you have a spare Arduino and FTDI232, follow this tutorial to program a new bootloader using the Arduino IDE.
                          Good luck! :)
                          • R robosensor
                            tekkaT
                            tekkaT
                            tekka
                            @robosensor Yes, the sensor firmware is uploaded OTA via MYSController.
                              mvader
                              wrote on last edited by mvader
                              #132
                              Hi - I need some clarification.
                              I have mysensors connected to my vera lite (working)
                              I bought 3 of the sensebender micro boards and got them talking with the gateway (working)
                              loaded up myscontroller it's running and see the gateway and all 3 nodes.
                              yay!
                              the issue is the sensors are reporting in C instead of F, so i modified the sketch, compiled it, found the hex file (66k)
                              and moved it to the correct folder per instructions.
                              when i says "assign FW" nothing happens.
                              am i understanding correctly that "firmware" is just a compiled sketch?
                              if i need to make changes to my device, is this the correct way?
                              modify sketch - > compile -> move hex to myscontroller folder - > edit firmware_config file -> right click assign fw -> pick new firmware
                              is that correct?
                              nothing is happening for me when i do that..
                              please clarify.
                              thanks!
                              edit: file size says 66k in win7
                              but in the compiler it says
                              Sketch uses 23,724 bytes (77%) of program storage space. Maximum is 30,720 bytes.
                              Global variables use 822 bytes (40%) of dynamic memory, leaving 1,226 bytes for local variables. Maximum is 2,048 bytes.
                              the file i grabbed was SensebenderMicro.cpp.hex
                              • M mvader
                                yay!
                                is that correct?
                                please clarify.
                                thanks!
                                tekkaT
                                tekkaT
                                tekka
                                is that correct?
                                For OTA updates you need to burn the MYSBootloader (instructions here). Once done, assign FW, reboot node and wait until FW is transferred.
                                Yup, because the .hex file is not binary but a hex (hence the suffix) format with headers and checksums.
                                • tekkaT tekka
                                  is that correct?
                                  mvader
                                  #134
                                  is that correct?
                                  I thought i read those sensebender boards were going to come pre-burned with the MYSBootloader from the mfg? that why you wouldn't need a programmer. i'll check with those folks..
                                  edit: i found where they said it was pre-programmed..
                                  @hek said:
                                  Yes, FTDI, ISCP or over-the-air updates.
                                  It comes pre-programmed with MySensors variant of the DualOptiboot-bootloader.
                                  https://github.com/mysensors/DualOptiboot
                                  Which can take advantage of the extra flash memory to do a safe over-the-air firmware update.
                                  • M mvader
                                    is that correct?
                                    mvader
                                    • G
                                      G
                                      gigaguy
                                      wrote on last edited by gigaguy
                                      #136
                                      I have a some questions. Couldnt find answer anywhere.
                                      If I am using an arduino connected to the serial port on a Raspberry pi (w/openhab) How do I assign fw, reboot, etc?
                                      Do I need to disconnect the GW and use windows temporarily to reboot, update fw? or can I have 2 GW's?
                                      I updated my nano with the MYS bootloader, and after I power it on, it never shows up in MYSController.
                                      • F
                                        F
                                        Fredrik Carlsson
                                        @tekka Hey, it seems like the downloadlink is broken. Can you check?
                                        • n3roN
                                          n3roN
                                          n3ro
                                          i dont understand how to use this...
                                          Can somebody explain it?
                                          pimatic + MySensors + Homeduino + z-way
                                          https://github.com/n3roGit/MySensors_n3ro
