  3. water level for pool
12 Posts 10 Posters 9.1k Views 2 Watching
  • M Offline
    M Offline
    madmax
    Hello
    i want to make a water level sensor for my pool
    i have a sensor
    it's this
    but i don't find a sketch for this
    it's analog imput
    thanks to share if you have
    best regards
    • hekH Offline
      hekH Offline
      Looks like it gives an analog output. Just hook it up to one of the analog inputs (e.g. A0) and read out the value.
      int value = analogRead(A0);
      • greglG Offline
        greglG Offline
        gregl
        You will likely find this sensor will not last very long in a swimming pool environment. The chemicals and water itself will give it a hard time.
        Try it though first and then look to make it more robust by building your own sensor based off this design.
        See if you can scavenge/ebay some titanium coated wire, or plates from an old salt cell. mount them in some pvc pipe and run cable back to a IP65 sealed project box with your Mysensors sender and powersupply.
        Let us know how it goes too!
        B 1 Reply Last reply
        • greglG gregl
          B Offline
          B Offline
          BulldogLowell
          and exposure to prolonged electrical current will only accelerate the corrosion.
          I've been testing a float sensor (that I use in fuel tanks) that may be good in a salt/chlorine environment. I'll post a photo whenI get the chance.
          • N Offline
            N Offline
            notforyou23
            There is a great liquid level sensor that I have been using in a number of sump pump wells (I use to track volume, and trigger the pump).
            The sensor is called eTape, check it out: http://www.milonetech.com/Home_Page.html
            • P Offline
              P Offline
              phil pritchard
              wrote on last edited by phil pritchard
              Try http://www.ebay.com.au/itm/Hot-Ultrasonic-Module-Distance-Measuring-Transducer-Sensor-Waterproof-/121627918430?pt=LH_DefaultDomain_15&hash=item1c5196c05e you would need to be able to mount above the water.
              • P phil pritchard
                B Offline
                B Offline
                BulldogLowell
                @phil-pritchard
                I'm working with this:
                D 1 Reply Last reply
                • B BulldogLowell
                  @phil-pritchard
                  Dwalt
                  @BulldogLowell
                  It that a float switch or does it return water level?
                  • B Offline
                    B Offline
                    BulldogLowell
                    returns level, not a switch.
                    • DNKROZD Offline
                      DNKROZD Offline
                      DNKROZ
                      I currently have a functioning fuel level sensor for my fuel tank built with an ultrasonic hc-sr04 device and it works pretty ok.
                      Before installing that on the top of the tank (hot-glued to the cap actually) all my tests were done on a water tank, so I know beforehand that this works well with water.
                      There some things you'll want to consider though:
                      • This does NOT work well on moist environments, you'll have wrong readings, I recommend the "water proof" version for that (it's not waterproof, it simply works better with higher humidity levels)
                      • If the water is moving you'll have different readings (as with ALL water level meters) I've modified the sketch to read the distance several times at random intervals (for example 6 times with intervals at 1 sec, 3, 5.5, 6,7, 9.2 secs) and then give the average distance, this flattens false readings and gives a more realistic value.
                      Hope that it works for you.
                      Regards.
                      • A Offline
                        A Offline
                        Andreas Maurer
                        Perhaps my following sketch can help you: https://codebender.cc/sketch:98928
                        I use the same Setup to meassure the Level of the pellet store. There is a lot of dust in the Air and no even Surface. So a lot of "noise".
                        The digitalSmooth function tries to find the relevant values. My graph looks much better with it :)
                        • boanjoB Offline
                          boanjoB Offline
                          boanjo
                          I agree with "notforyou23", the eTape is a great product (although a bit pricy). I use it in this project where i easily keep my pond water level +-5mm. And i rever overfill the pond anymore...
                          https://github.com/epkboan/pc
