  3. Open Source Home Automation (Raspberry)
automationopen sourceraspberrycontroller
111 Posts 30 Posters 185.4k Views 15 Watching
  • jendrushJ
    jendrushJ
    jendrush
    We could add this for the list http://www.opensourceautomation.com/
    • T toni
      @epierre Where can I find more info on mySensor bindings for openhab? Cant find anything on openhab.
      epierreE
      epierreE
      epierre
      @toni see @wanabee post above
      z-wave - Vera -> Domoticz
      • jendrushJ jendrush
        bjornhallbergB
        bjornhallbergB
        bjornhallberg
        wrote on last edited by bjornhallberg
        @jendrush Hmm. It IS open source, but does it run on the RPi? Seems to be Windows only?
        Can OSA run on other operating system besides Windows such as Linux and OS X?
        OSA is based upon Microsoft .NET which only runs on Windows. There is an open source clone of .NET called Mono which could allow OSA to run on other operating system. Our goal is to have OSA run on Linux but we are not there yet.
        • added: DomotiGa and Freedomotic.
        jendrushJ 1 Reply Last reply
          jendrushJ
          jendrushJ
          jendrush
          You are right. It looks like it is only for Windows now.
          • bjornhallbergB
            bjornhallbergB
            bjornhallberg
            Perhaps this discussion should be taken to a more rudimentary level, trying to figure out which automation software we actually want to bet on. And what software will actually run WELL on the resource limited RPi. It would take some convincing before I ever installed java-based solutions for instance, like openHab.
            Has anyone actually tried Ago Control? Is it any good? Does it work well with the Pi? The installation is 130MB no less. A ton of dependencies. Makes you wonder about RAM and CPU usage.
            It feels like this entire market is a bit premature at the moment.
            AnticimexA G 2 Replies Last reply
              AnticimexA
              AnticimexA
              Anticimex
              @bjornhallberg
              I am running Domoticz on my rPi and I think it runs well. I have only added my 1-wire temp and light sensors currently (light sensors not working very well, but that is not Domotcz fault). I have also plugged a Tellstick to the rPi and managed to get it working as well, so I am going to stick with Domoticz for now on the rPi.
              I have a Vera as well, which I plan to use to make sure my sensor nodes work as intended (since Vera is "officially" supported). But for "the future", the rPi is to me more interesting, and can be extended with zWave support as well. So I would love to see MySensors support on Domoticz eventually.
              I have a pathological hatred for anything Java related, and especially on resource-limited devices so any HA solution based on that is ruled out by me. I tried openHab but could not get it to work properly, and it was s.l.o.w.
              axillentA jendrushJ 2 Replies Last reply
              • AnticimexA Anticimex
                @bjornhallberg
                axillentA
                axillentA
                axillent
                @Anticimex I will prefer to not limit smart home by RPI
                RPI is good to be a bridge between mysensors network and smart home controller
                and also a bridge from mysensors devices to mysensors cloud
                but smart home controller is something else
                I have vera running for 4 years
                vera3 is much more powerful comparing to RPI but still there is lack of performance and resources
                may be RPI can handle 5-10 devices but if you intend to automate more the RPI will became a bottleneck
                I will be looking for nettop PC based computers running UNIX or windows
                sense and drive
                AnticimexA bjornhallbergB 2 Replies Last reply
                • axillentA axillent
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @axillent A PC based solution is probably the best from a performance point of view.
                  However, I currently has absolutely no sensors interfaced to my VeraLite and 7 temp and 7 light sensors connected by 1-Wire (and the tellstick) on my rPi, and my rPi totally wips the ass of Vera when it comes to performance and responsiveness. It all depends on the back-end and how fancy the frontend needs to be.
                  But when in doubt, use PC. That is by far the most flexible option.
                  But to not hijack the topic too much, the question here is limited to SW that works well on rPi :)
                    bjornhallbergB
                    bjornhallbergB
                    bjornhallberg
                    @axillent Sure, a more powerful solution wouldn't go amiss, but it comes down to cost and power consumption. The RPi SHOULD be enough to power home automation if it was was done right. A lot of the resource consumption for Domoticz (which is still a lot faster than openhab but is nevertheless accused of being slow sometimes) seems to be Apache handling the web interface. Lighttpd might be something I should look into if at all possible. Personally I'd like a really light-weight front-end and then some Android app to control and check the automation server.
                    But I'm always open to suggestions. The RPi is only great because of its software support / developers, its peripherals and its gpu. There should be a lot faster chips these days, ARM or preferably x86, that could manage the same power consumption as the Pi but with a lot better performance. If you're only looking for CPU cycles. Personally I was hell bent on cramming as much stuff as possible into the Pi, including the camera module. That is basically £6 of electricity, running it 24/7 for a year. Yes, I'm the ultimate cheapskate ;-)
                    AnticimexA 1 Reply Last reply
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @bjornhallberg I installed Domoticz on my Pi using an image, and it seem to run nginx, and not Apache. So far, I have not experienced any particular lag. Fingers crossed...
                      • BSoftB
                        BSoftB
                        BSoft
                        I think the intent of rPI as a mysensor controller is an easy open customizable/semi-universal database service delivery to cloud, and in that department there is no reason to consider it as a bottleneck. And as a mysensor network controller should not be a problem also, i mean, controlling nodes does not require an horsepower machine.
                          @bjornhallberg
                          jendrushJ
                          jendrushJ
                          jendrush
                          I can confirm that. I've tried OpenHub Demo, and it was very slow on RPi. Idea for OpenHUB is nice, but Java kills this idea on slower machines.
                          • YveauxY
                            Anyone familiar with MQTT (Mqtt.org)? This is not a home automation system but functions as middleware that stores data. Clients can subscribe to topics or publish topics.
                            Topics are ordered in a directory-like structure, e.g /mysensors/node123/sensor6/temperature.
                            I built a simple software gateway that routes sensor readings from a mysensors network to an MQTT broker, and routes actuator values from a MQTT broker back to the mysensors nodes.
                            Powerful rules can be created easily, like subscribe to a light sensor and a motion sensor and publish a light-switch-on when it is dark and motion is detected.
                            It might sound complex, but in reality is quite simple, super lightweight (runs easy peasy on RPI, see mosquito.org) and very scalable (brokers can be publish/subscribe to other brokers).
                            Only thing I still need is some UI to manually control sensors/actuators and edit rules ;-)
                              mikeones
                              I have been using agocontrol on my RPI with pretty good results. The few issues I posted about in the agocontrol form are likely user error on my part. I think ago is written in C and runs well on my PI. I am currently running 4 nodes with about 22 child devices. They have implemented just about all the device types which is a plus. I am running temperature, humidity and distance sensors along with relays and reed switches. Communication and stability have been solid so far.
                              I recommend agocontrol to anyone wanting to get some sensor nodes up and talking to a control that don't have a vera. They have x86 packages also so you are not limited to only running on a PI.
                              • M mikeones
                                bjornhallbergB
                                bjornhallbergB
                                bjornhallberg
                                @mikeones I managed to get agocontrol installed and running after much grief. Can't really make heads or tails of the interface yet, and I get mysensors errors ("mysensorscontroller is not responding. Unable to execute action.") when going to the mysensors configuration. I did apt-get the agocontrol-mysensor package and it seems to start perfectly. Perhaps it has to do with the beta gateway code. Do you need to configure the serial port in the settings? Because I can't seem to save any changes made? /dev/ttyACM0 doesn't normally work when opening a serial monitor for me. I need to use /dev/ttyUSB0.
                                Overall I'm not sure agocontrol looks like my cup of tea. Seems the scope is just too ambitious and not as streamlined and user friendly as it could be. It is however pretty snappy (at least with no sensors configured). I'd still put my money on Domoticz.
                                • edited the list above to denote applications that have difficult requirements or requirements that may impede performance (Java ...).
                                YveauxY M 2 Replies Last reply
                                  @bjornhallberg are you running the 1.4 code on the gateway & sensors? The serial protocol has changed with 1.4 which could cause the issue...
                                  • DammeD
                                    DammeD
                                    Damme
                                    Code Contributor
                                    wrote on last edited by Damme
                                    #22
                                    I tried Agocontrol my self and don't really like it..
                                    maybe its time for a new project "Yet Another Home Automation System" ... =(
                                    Edit;
                                    Any of the one's listed someone like? Me myself will be running the server on a linux-server so RPi is not really necessary.. I've been looking through them all now and didnt really fall for any of them.
                                    Android-client would be good too
                                      mikeones
                                      @bjornhallberg Did you add the mysensors config file?
                                      $ cat /etc/opt/agocontrol/conf.d/mysensors.conf
                                      [mysensors]
                                      device=/dev/ttyUSB0
                                      • M mikeones
                                        [mysensors]
                                        device=/dev/ttyUSB0
                                        bjornhallbergB
                                        bjornhallbergB
                                        bjornhallberg
                                        [mysensors]
                                        device=/dev/ttyUSB0
                                        That seems to have done it, thanks! I wonder why the webui/ago couldn't create that file itself.
                                        • DammeD
                                          DammeD
                                          Damme
                                          Code Contributor
                                          #25
                                          I cant decide which software I want to run. I dont really like any of them :(
                                          I was thinking about openhab and use the ethernet + arduino and make a new gateway software for openhab. (openhab can utilize UDP)
                                          But I think openhab is a bit complex in the configuration. Or me just stupid.. :)
                                          hekH bjornhallbergB 2 Replies Last reply
