  3. Plotting graphs with plot.ly service with luup scene using REST API
plot.lygraphluupplot
56 Posts 10 Posters 34.5k Views 2 Watching
  • korttomaK
    korttomaK
    korttoma
    I sent them some feedback to but have not heard anything yet. Maybe we should try the "Streaming API" instead?
    • Tomas
    DwaltD S 2 Replies Last reply
    • korttomaK korttoma
      DwaltD
      DwaltD
      Dwalt
      wrote on last edited by Dwalt
      #23
      @korttoma
      I tried to set up a new graph using the REST API and could not get it to register with Plot.ly. Without any explanation from Plot.ly, I tried sending the same data streams to ThingSpeak.com and it set up with out any trouble. The API is slightly different but just as easy to use. I set up a scene to run every 15 minutes with the following code:
      -- Get Light Levels
      local LR_LIGHT_LEVEL = luup.variable_get("urn:micasaverde-com:serviceId:LightSensor1", "CurrentLevel", 47)
      local BR_LIGHT_LEVEL = luup.variable_get("urn:micasaverde-com:serviceId:LightSensor1", "CurrentLevel", 55)
      - - Get Temps
      local LR_TEMP = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1", "CurrentTemperature", 46)
      local BR_TEMP = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1", "CurrentTemperature", 54)
      local OUT_TEMP = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1", "CurrentTemperature", 23)
      -- Send data to ThingSpeak.com
      local http = require("socket.http")
      http.TIMEOUT = 5
      result, status = http.request("http://api.thingspeak.com/update?key=Insert Your API Key here&field1="..LR_TEMP.."&field2="..BR_TEMP.."&field3="..OUT_TEMP.."&field4="..LR_LIGHT_LEVEL.."&field5="..BR_LIGHT_LEVEL.."", "run=run") ````
      The service has a limited functionality to manipulate your data but the base configuration is easy to tweak and can be made public or private.  See [here for my sample data](https://thingspeak.com/channels/25629).
      ...plus it is free to use.
        samppa
        wrote on last edited by samppa
        #24
        @korttoma
        Now plot.ly is back up again.
        Apparently they upgraded the infrastructure and broke something. Hopefully that does not happen too often..
        • korttomaK
          korttomaK
          korttoma
          Yes, now it is working again. Maybe you should try again @Dwalt ?
          • Tomas
          DwaltD 1 Reply Last reply
            DwaltD
            DwaltD
            Dwalt
            @korttoma
            I noticed it back online right after I posted my Thingspeak scene. I had not deleted my Plot.ly scenes and they continued to send http requests during the outage and when Plot.ly came back online, my data resumed plotting.
            I have both services running right now plotting similar data and I will leave them both running to test reliability and quirks. It seems the time reporting drifts a little in Plot.ly. I am also going to test Beebotte.
            • korttomaK
              korttomaK
              korttoma
              There was an outage again last night. No data uploaded for 3h. Was it just me or plot.ly?
              • Tomas
                DwaltD
                DwaltD
                Dwalt
                @korttoma I got it too.
                • D
                  derrij
                  • korttomaK
                    korttomaK
                    korttoma
                    Did plot.ly change something or did I brake my own ploting somehow? Anyone else having problems?
                    • Tomas
                      DwaltD
                      DwaltD
                      Dwalt
                      @korttoma
                      My plots are still working.
                      • korttomaK
                        korttomaK
                        korttoma
                        @Dwalt would you mind charing your lua? Remember to remove your username and api key ;)
                        Here is a nexample of what I'm using and it stoped working on 9th of this month.
                        local OutTemp = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature", 229)
                        local TankTopp = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature", 174)
                        local TankMitten = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature", 179)
                        local TankBotten = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature", 175)
                        local Solpanel = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature", 28)
                        local Solpump = luup.variable_get("urn:micasaverde-com:serviceId:SecuritySensor1", "Tripped", 212) * 50
                        local CirkPump = luup.variable_get("urn:micasaverde-com:serviceId:EnergyMetering1", "Watts", 98)
                        local ts = os.date("%Y-%m-%d %X")
                        http.TIMEOUT = 8
                        result, status = http.request("https://plot.ly/clientresp", 'un=useruser&key=keykeyszx&origin=plot&platform=lisp&args=[{"x":["'..ts..'"],"y":['..OutTemp..'],"name":"Ute Temp"},{"x":["'..ts..'"],"y":['..TankTopp..'],"name":"Tank Topp"},{"x":["'..ts..'"],"y":['..TankMitten..'],"name":"Tank Mitten"},{"x":["'..ts..'"],"y":['..TankBotten..'],"name":"Tank Botten"},{"x":["'..ts..'"],"y":['..Solpanel..'],"name":"Solpanel Temp"},{"x":["'..ts..'"],"y":['..Solpump..'],"name":"Sol Pump"},{"x":["'..ts..'"],"y":['..CirkPump..'],"name":"Cirkulationspump"}]&kwargs={"filename":"Varme","fileopt":"extend","style":{"type":"scatter"},"traces":[0,1,2,3,4,5,6],"layout":{"title":"Värme Systemet"},"world_readable":false}')```
                        I get 2 values correct to the graph but after this it somehow screws up the time axis of the graph.
                        • Tomas
                          http.TIMEOUT = 8
                          DwaltD
                          DwaltD
                          Dwalt
                          #33
                          @korttoma
                          Here is my code.
                          This only tracks light level from one sensor. I did have a data outage that lasted 3 days last month (5/24 - 5/27) and I did not notice it at the time so I am unable to determine exact cause. It resumed plotting after 3 days and I assume the error was on plotly's side. Plotly had some 'offline' issues last year as well.
                          local Light_level = luup.variable_get("urn:micasaverde-com:serviceId:LightSensor1", "CurrentLevel", 47)
                          http.TIMEOUT = 5
                          result, status = http.request("https://plot.ly/clientresp",'un=XXXXX&key=XXXXX&origin=plot&platform=lisp&args=[{"x":["'..ts..'"],"y":['..Light_level..']}]&kwargs={"filename":"MHLux","fileopt":"extend","style":{"type":"scatter"},"traces":[0],"layout":{"title":"MHLux_Test"},"world_readable":false}')```
                          • korttomaK
                            korttomaK
                            korttoma
                            Bingo. You only have one data source. That I can get to work also. I had over 10 different data in one graph and it was working fine but it is not anymore.
                            • Tomas
                            • 5546dug5
                              5546dug5
                              5546dug
                              @samppa just wondering what the numbers at the end of the luup code refers to is 83. 347 etc?
                              I am reading and what to try to graph my temp/hum.
                              • 5546dug5 5546dug
                                DwaltD
                                DwaltD
                                Dwalt
                                @5546dug
                                The numbers are the device id numbers within Vera. They tell the 'Get' command exactly which sensors/devices to pull the data from. They can be found under the 'Advanced' tab under each devices' 'settings'.
                                • korttomaK
                                  korttomaK
                                  korttoma
                                  I gave up on plot.ly. I can no longer send many data to one graph using their API so I started looking in to ThingSpeak.com that @Dwalt mentioned. I seems like you can use plugins to create graphs with multiple series, seems to work nicely.
                                  • Tomas
                                  BulldogLowellB NeverDieN 2 Replies Last reply
                                    BulldogLowellB
                                    BulldogLowellB
                                    BulldogLowell
                                    @korttoma
                                    maybe try the new Maker channel on IFTTT and send data to google spreadsheet.
                                    then just feed your plotting software (or excel) from the data on your google drive.
                                      Did you get it to work?
                                      korttomaK 1 Reply Last reply
                                        korttomaK
                                        korttomaK
                                        korttoma
                                        @NeverDie ThingSpeak is workin but not plot.ly
                                        • Tomas
                                          Here Plot.Ly has been working:
                                          https://plot.ly/~WhiteRabbit/997
                                          About 6 months or so ago it seemed to stop plotting, and it wouldn't resume even if I rebooted the Arduino. So, I requested all new stream tokens, plugged those into the Arduino program, rebooted, and it has been working since. What I like about Plot.ly is that I can both pan and zoom the data.
                                          I'm presently driving Plot.ly using just the Arduino API. I get the impression I'd have finer grained control if I were to drive it using Python instead.
