  3. Plotting graphs with plot.ly service with luup scene using REST API
plot.lygraphluupplot
56 Posts 10 Posters 34.6k Views 2 Watching
  • korttomaK korttoma
    I sent them some feedback to but have not heard anything yet. Maybe we should try the "Streaming API" instead?
    samppa
    wrote on last edited by samppa
    #24
    @korttoma
    Now plot.ly is back up again.
    Apparently they upgraded the infrastructure and broke something. Hopefully that does not happen too often..
    • korttomaK
      korttomaK
      korttoma
      Yes, now it is working again. Maybe you should try again @Dwalt ?
      • Tomas
      DwaltD 1 Reply Last reply
        DwaltD
        DwaltD
        Dwalt
        @korttoma
        I noticed it back online right after I posted my Thingspeak scene. I had not deleted my Plot.ly scenes and they continued to send http requests during the outage and when Plot.ly came back online, my data resumed plotting.
        I have both services running right now plotting similar data and I will leave them both running to test reliability and quirks. It seems the time reporting drifts a little in Plot.ly. I am also going to test Beebotte.
        • korttomaK
          korttomaK
          korttoma
          There was an outage again last night. No data uploaded for 3h. Was it just me or plot.ly?
          • Tomas
            DwaltD
            DwaltD
            Dwalt
            @korttoma I got it too.
            • D
              derrij
              • korttomaK
                korttomaK
                korttoma
                Did plot.ly change something or did I brake my own ploting somehow? Anyone else having problems?
                • Tomas
                  DwaltD
                  DwaltD
                  Dwalt
                  @korttoma
                  My plots are still working.
                  • korttomaK
                    korttomaK
                    korttoma
                    @Dwalt would you mind charing your lua? Remember to remove your username and api key ;)
                    Here is a nexample of what I'm using and it stoped working on 9th of this month.
                    local OutTemp = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature", 229)
                    local TankTopp = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature", 174)
                    local TankMitten = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature", 179)
                    local TankBotten = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature", 175)
                    local Solpanel = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature", 28)
                    local Solpump = luup.variable_get("urn:micasaverde-com:serviceId:SecuritySensor1", "Tripped", 212) * 50
                    local CirkPump = luup.variable_get("urn:micasaverde-com:serviceId:EnergyMetering1", "Watts", 98)
                    local ts = os.date("%Y-%m-%d %X")
                    local http = require("socket.http")
                    http.TIMEOUT = 8
                    result, status = http.request("https://plot.ly/clientresp", 'un=useruser&key=keykeyszx&origin=plot&platform=lisp&args=[{"x":["'..ts..'"],"y":['..OutTemp..'],"name":"Ute Temp"},{"x":["'..ts..'"],"y":['..TankTopp..'],"name":"Tank Topp"},{"x":["'..ts..'"],"y":['..TankMitten..'],"name":"Tank Mitten"},{"x":["'..ts..'"],"y":['..TankBotten..'],"name":"Tank Botten"},{"x":["'..ts..'"],"y":['..Solpanel..'],"name":"Solpanel Temp"},{"x":["'..ts..'"],"y":['..Solpump..'],"name":"Sol Pump"},{"x":["'..ts..'"],"y":['..CirkPump..'],"name":"Cirkulationspump"}]&kwargs={"filename":"Varme","fileopt":"extend","style":{"type":"scatter"},"traces":[0,1,2,3,4,5,6],"layout":{"title":"Värme Systemet"},"world_readable":false}')```
                    I get 2 values correct to the graph but after this it somehow screws up the time axis of the graph.
                    • Tomas
                      http.TIMEOUT = 8
                      DwaltD
                      DwaltD
                      Dwalt
                      wrote on last edited by Dwalt
                      #33
                      @korttoma
                      Here is my code.
                      This only tracks light level from one sensor. I did have a data outage that lasted 3 days last month (5/24 - 5/27) and I did not notice it at the time so I am unable to determine exact cause. It resumed plotting after 3 days and I assume the error was on plotly's side. Plotly had some 'offline' issues last year as well.
                      local Light_level = luup.variable_get("urn:micasaverde-com:serviceId:LightSensor1", "CurrentLevel", 47)
                      http.TIMEOUT = 5
                      result, status = http.request("https://plot.ly/clientresp",'un=XXXXX&key=XXXXX&origin=plot&platform=lisp&args=[{"x":["'..ts..'"],"y":['..Light_level..']}]&kwargs={"filename":"MHLux","fileopt":"extend","style":{"type":"scatter"},"traces":[0],"layout":{"title":"MHLux_Test"},"world_readable":false}')```
                      • korttomaK
                        korttomaK
                        korttoma
                        Bingo. You only have one data source. That I can get to work also. I had over 10 different data in one graph and it was working fine but it is not anymore.
                        • Tomas
                        • 5546dug5
                          5546dug5
                          5546dug
                          @samppa just wondering what the numbers at the end of the luup code refers to is 83. 347 etc?
                          I am reading and what to try to graph my temp/hum.
                          • 5546dug5 5546dug
                            DwaltD
                            DwaltD
                            Dwalt
                            @5546dug
                            The numbers are the device id numbers within Vera. They tell the 'Get' command exactly which sensors/devices to pull the data from. They can be found under the 'Advanced' tab under each devices' 'settings'.
                            • korttomaK
                              korttomaK
                              korttoma
                              I gave up on plot.ly. I can no longer send many data to one graph using their API so I started looking in to ThingSpeak.com that @Dwalt mentioned. I seems like you can use plugins to create graphs with multiple series, seems to work nicely.
                              • Tomas
                              BulldogLowellB NeverDieN 2 Replies Last reply
                                BulldogLowellB
                                BulldogLowellB
                                BulldogLowell
                                @korttoma
                                maybe try the new Maker channel on IFTTT and send data to google spreadsheet.
                                then just feed your plotting software (or excel) from the data on your google drive.
                                  Did you get it to work?
                                  korttomaK 1 Reply Last reply
                                    korttomaK
                                    korttomaK
                                    korttoma
                                    @NeverDie ThingSpeak is workin but not plot.ly
                                    • Tomas
                                      Here Plot.Ly has been working:
                                      https://plot.ly/~WhiteRabbit/997
                                      About 6 months or so ago it seemed to stop plotting, and it wouldn't resume even if I rebooted the Arduino. So, I requested all new stream tokens, plugged those into the Arduino program, rebooted, and it has been working since. What I like about Plot.ly is that I can both pan and zoom the data.
                                      I'm presently driving Plot.ly using just the Arduino API. I get the impression I'd have finer grained control if I were to drive it using Python instead.
                                      • korttomaK
                                        korttomaK
                                        korttoma
                                        @NeverDie Thanks for posting, I created a new API key and deleted my old plot and so far so good, it is working again.
                                        Like you I also prefer the UI and plots produced by plot.ly but I'm not convinced by the reliability so far.
                                        • Tomas
                                        • HoffanH
                                          HoffanH
                                          Hoffan
                                          Hi Guys
                                          How much work is it in Plot.ly to get in to work
                                          Becuase i test to Copy the examples upper here and put my INFO in the text
                                          But nothing happens, Must i change a lot of thing on the Plot.ly page
