  3. Plotting graphs with plot.ly service with luup scene using REST API
plot.lygraphluupplot
56 Posts 10 Posters 34.5k Views 2 Watching
  • korttomaK korttoma
    Yes, now it is working again. Maybe you should try again @Dwalt ?
    DwaltD
    DwaltD
    Dwalt
    @korttoma
    I noticed it back online right after I posted my Thingspeak scene. I had not deleted my Plot.ly scenes and they continued to send http requests during the outage and when Plot.ly came back online, my data resumed plotting.
    I have both services running right now plotting similar data and I will leave them both running to test reliability and quirks. It seems the time reporting drifts a little in Plot.ly. I am also going to test Beebotte.
    • korttomaK
      korttomaK
      korttoma
      There was an outage again last night. No data uploaded for 3h. Was it just me or plot.ly?
      • Tomas
      DwaltD 1 Reply Last reply
        DwaltD
        DwaltD
        Dwalt
        @korttoma I got it too.
        • D
          derrij
          • korttomaK
            korttomaK
            korttoma
            Did plot.ly change something or did I brake my own ploting somehow? Anyone else having problems?
            • Tomas
              DwaltD
              DwaltD
              Dwalt
              @korttoma
              My plots are still working.
              • korttomaK
                korttomaK
                korttoma
                @Dwalt would you mind charing your lua? Remember to remove your username and api key ;)
                Here is a nexample of what I'm using and it stoped working on 9th of this month.
                local OutTemp = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature", 229)
                local TankTopp = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature", 174)
                local TankMitten = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature", 179)
                local TankBotten = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature", 175)
                local Solpanel = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature", 28)
                local Solpump = luup.variable_get("urn:micasaverde-com:serviceId:SecuritySensor1", "Tripped", 212) * 50
                local CirkPump = luup.variable_get("urn:micasaverde-com:serviceId:EnergyMetering1", "Watts", 98)
                local ts = os.date("%Y-%m-%d %X")
                local http = require("socket.http")
                http.TIMEOUT = 8
                result, status = http.request("https://plot.ly/clientresp", 'un=useruser&key=keykeyszx&origin=plot&platform=lisp&args=[{"x":["'..ts..'"],"y":['..OutTemp..'],"name":"Ute Temp"},{"x":["'..ts..'"],"y":['..TankTopp..'],"name":"Tank Topp"},{"x":["'..ts..'"],"y":['..TankMitten..'],"name":"Tank Mitten"},{"x":["'..ts..'"],"y":['..TankBotten..'],"name":"Tank Botten"},{"x":["'..ts..'"],"y":['..Solpanel..'],"name":"Solpanel Temp"},{"x":["'..ts..'"],"y":['..Solpump..'],"name":"Sol Pump"},{"x":["'..ts..'"],"y":['..CirkPump..'],"name":"Cirkulationspump"}]&kwargs={"filename":"Varme","fileopt":"extend","style":{"type":"scatter"},"traces":[0,1,2,3,4,5,6],"layout":{"title":"Värme Systemet"},"world_readable":false}')```
                I get 2 values correct to the graph but after this it somehow screws up the time axis of the graph.
                • Tomas
                  http.TIMEOUT = 8
                  DwaltD
                  DwaltD
                  Dwalt
                  wrote on last edited by Dwalt
                  #33
                  @korttoma
                  Here is my code.
                  This only tracks light level from one sensor. I did have a data outage that lasted 3 days last month (5/24 - 5/27) and I did not notice it at the time so I am unable to determine exact cause. It resumed plotting after 3 days and I assume the error was on plotly's side. Plotly had some 'offline' issues last year as well.
                  local Light_level = luup.variable_get("urn:micasaverde-com:serviceId:LightSensor1", "CurrentLevel", 47)
                  http.TIMEOUT = 5
                  result, status = http.request("https://plot.ly/clientresp",'un=XXXXX&key=XXXXX&origin=plot&platform=lisp&args=[{"x":["'..ts..'"],"y":['..Light_level..']}]&kwargs={"filename":"MHLux","fileopt":"extend","style":{"type":"scatter"},"traces":[0],"layout":{"title":"MHLux_Test"},"world_readable":false}')```
                  • korttomaK
                    korttomaK
                    korttoma
                    Bingo. You only have one data source. That I can get to work also. I had over 10 different data in one graph and it was working fine but it is not anymore.
                    • Tomas
                    • 5546dug5
                      5546dug5
                      5546dug
                      @samppa just wondering what the numbers at the end of the luup code refers to is 83. 347 etc?
                      I am reading and what to try to graph my temp/hum.
                      • 5546dug5 5546dug
                        DwaltD
                        DwaltD
                        Dwalt
                        @5546dug
                        The numbers are the device id numbers within Vera. They tell the 'Get' command exactly which sensors/devices to pull the data from. They can be found under the 'Advanced' tab under each devices' 'settings'.
                        • korttomaK
                          korttomaK
                          korttoma
                          I gave up on plot.ly. I can no longer send many data to one graph using their API so I started looking in to ThingSpeak.com that @Dwalt mentioned. I seems like you can use plugins to create graphs with multiple series, seems to work nicely.
                          • Tomas
                          BulldogLowellB NeverDieN 2 Replies Last reply
                            BulldogLowellB
                            BulldogLowellB
                            BulldogLowell
                            @korttoma
                            maybe try the new Maker channel on IFTTT and send data to google spreadsheet.
                            then just feed your plotting software (or excel) from the data on your google drive.
                              Did you get it to work?
                              korttomaK 1 Reply Last reply
                                korttomaK
                                korttomaK
                                korttoma
                                @NeverDie ThingSpeak is workin but not plot.ly
                                • Tomas
                                  Here Plot.Ly has been working:
                                  https://plot.ly/~WhiteRabbit/997
                                  About 6 months or so ago it seemed to stop plotting, and it wouldn't resume even if I rebooted the Arduino. So, I requested all new stream tokens, plugged those into the Arduino program, rebooted, and it has been working since. What I like about Plot.ly is that I can both pan and zoom the data.
                                  I'm presently driving Plot.ly using just the Arduino API. I get the impression I'd have finer grained control if I were to drive it using Python instead.
                                  • korttomaK
                                    korttomaK
                                    korttoma
                                    @NeverDie Thanks for posting, I created a new API key and deleted my old plot and so far so good, it is working again.
                                    Like you I also prefer the UI and plots produced by plot.ly but I'm not convinced by the reliability so far.
                                    • Tomas
                                    • HoffanH
                                      HoffanH
                                      Hoffan
                                      Hi Guys
                                      How much work is it in Plot.ly to get in to work
                                      Becuase i test to Copy the examples upper here and put my INFO in the text
                                      But nothing happens, Must i change a lot of thing on the Plot.ly page
                                        I share your concern. It has been a bumpy ride. If it weren't for the pan and zoom UI, I would have tried switching to another free service.
                                        • HoffanH
                                          HoffanH
                                          Hoffan
                                          Any one that can explain for me how to get plot.ly to work, I really don't get it :(
