  3. Plotting graphs with plot.ly service with luup scene using REST API
plot.lygraphluupplot
56 Posts 10 Posters 34.5k Views 2 Watching
  • korttomaK
    korttomaK
    korttoma
    Did plot.ly change something or did I brake my own ploting somehow? Anyone else having problems?
    • Tomas
    DwaltD 1 Reply Last reply
    • korttomaK korttoma
      DwaltD
      DwaltD
      Dwalt
      @korttoma
      My plots are still working.
      • korttomaK
        korttomaK
        korttoma
        @Dwalt would you mind charing your lua? Remember to remove your username and api key ;)
        Here is a nexample of what I'm using and it stoped working on 9th of this month.
        local OutTemp = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature", 229)
        local TankTopp = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature", 174)
        local TankMitten = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature", 179)
        local TankBotten = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature", 175)
        local Solpanel = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature", 28)
        local Solpump = luup.variable_get("urn:micasaverde-com:serviceId:SecuritySensor1", "Tripped", 212) * 50
        local CirkPump = luup.variable_get("urn:micasaverde-com:serviceId:EnergyMetering1", "Watts", 98)
        local ts = os.date("%Y-%m-%d %X")
        local http = require("socket.http")
        http.TIMEOUT = 8
        result, status = http.request("https://plot.ly/clientresp", 'un=useruser&key=keykeyszx&origin=plot&platform=lisp&args=[{"x":["'..ts..'"],"y":['..OutTemp..'],"name":"Ute Temp"},{"x":["'..ts..'"],"y":['..TankTopp..'],"name":"Tank Topp"},{"x":["'..ts..'"],"y":['..TankMitten..'],"name":"Tank Mitten"},{"x":["'..ts..'"],"y":['..TankBotten..'],"name":"Tank Botten"},{"x":["'..ts..'"],"y":['..Solpanel..'],"name":"Solpanel Temp"},{"x":["'..ts..'"],"y":['..Solpump..'],"name":"Sol Pump"},{"x":["'..ts..'"],"y":['..CirkPump..'],"name":"Cirkulationspump"}]&kwargs={"filename":"Varme","fileopt":"extend","style":{"type":"scatter"},"traces":[0,1,2,3,4,5,6],"layout":{"title":"Värme Systemet"},"world_readable":false}')```
        I get 2 values correct to the graph but after this it somehow screws up the time axis of the graph.
        • Tomas
          http.TIMEOUT = 8
          DwaltD
          DwaltD
          Dwalt
          wrote on last edited by Dwalt
          #33
          @korttoma
          Here is my code.
          This only tracks light level from one sensor. I did have a data outage that lasted 3 days last month (5/24 - 5/27) and I did not notice it at the time so I am unable to determine exact cause. It resumed plotting after 3 days and I assume the error was on plotly's side. Plotly had some 'offline' issues last year as well.
          local Light_level = luup.variable_get("urn:micasaverde-com:serviceId:LightSensor1", "CurrentLevel", 47)
          http.TIMEOUT = 5
          result, status = http.request("https://plot.ly/clientresp",'un=XXXXX&key=XXXXX&origin=plot&platform=lisp&args=[{"x":["'..ts..'"],"y":['..Light_level..']}]&kwargs={"filename":"MHLux","fileopt":"extend","style":{"type":"scatter"},"traces":[0],"layout":{"title":"MHLux_Test"},"world_readable":false}')```
          • korttomaK
            korttomaK
            korttoma
            Bingo. You only have one data source. That I can get to work also. I had over 10 different data in one graph and it was working fine but it is not anymore.
            • Tomas
            • 5546dug5
              5546dug5
              5546dug
              @samppa just wondering what the numbers at the end of the luup code refers to is 83. 347 etc?
              I am reading and what to try to graph my temp/hum.
              • 5546dug5 5546dug
                DwaltD
                DwaltD
                Dwalt
                @5546dug
                The numbers are the device id numbers within Vera. They tell the 'Get' command exactly which sensors/devices to pull the data from. They can be found under the 'Advanced' tab under each devices' 'settings'.
                • korttomaK
                  korttomaK
                  korttoma
                  I gave up on plot.ly. I can no longer send many data to one graph using their API so I started looking in to ThingSpeak.com that @Dwalt mentioned. I seems like you can use plugins to create graphs with multiple series, seems to work nicely.
                  • Tomas
                  BulldogLowellB NeverDieN 2 Replies Last reply
                    BulldogLowellB
                    BulldogLowellB
                    BulldogLowell
                    @korttoma
                    maybe try the new Maker channel on IFTTT and send data to google spreadsheet.
                    then just feed your plotting software (or excel) from the data on your google drive.
                      Did you get it to work?
                      korttomaK 1 Reply Last reply
                        korttomaK
                        korttomaK
                        korttoma
                        @NeverDie ThingSpeak is workin but not plot.ly
                        • Tomas
                          Here Plot.Ly has been working:
                          https://plot.ly/~WhiteRabbit/997
                          About 6 months or so ago it seemed to stop plotting, and it wouldn't resume even if I rebooted the Arduino. So, I requested all new stream tokens, plugged those into the Arduino program, rebooted, and it has been working since. What I like about Plot.ly is that I can both pan and zoom the data.
                          I'm presently driving Plot.ly using just the Arduino API. I get the impression I'd have finer grained control if I were to drive it using Python instead.
                          • korttomaK
                            korttomaK
                            korttoma
                            @NeverDie Thanks for posting, I created a new API key and deleted my old plot and so far so good, it is working again.
                            Like you I also prefer the UI and plots produced by plot.ly but I'm not convinced by the reliability so far.
                            • Tomas
                            • HoffanH
                              HoffanH
                              Hoffan
                              Hi Guys
                              How much work is it in Plot.ly to get in to work
                              Becuase i test to Copy the examples upper here and put my INFO in the text
                              But nothing happens, Must i change a lot of thing on the Plot.ly page
                                I share your concern. It has been a bumpy ride. If it weren't for the pan and zoom UI, I would have tried switching to another free service.
                                • HoffanH
                                  HoffanH
                                  Hoffan
                                  Any one that can explain for me how to get plot.ly to work, I really don't get it :(
                                  • korttomaK
                                    korttomaK
                                    korttoma
                                    @Hoffan if you have an APIKey and username from plot.ly all you need to do is to change the following from the first post in this thread:
                                    ("urn:micasaverde-com:serviceId:HumiditySensor1", "CurrentLevel", 83) If you don't know what this should be let me know so I can explain further.
                                    <username>
                                    <APIKey>
                                    <nameForGraph>
                                    <graphTitle>
                                    You should make sure you remove all the < >
                                    Also I noticed that you can only have one private graph so if you already have one the second one will not get created.
                                    Try changing "world_readable":false to "world_readable":true
                                    Now test your lua code from apps -> develop apps -> test loop code (lua). Do you get any errors?
                                    • Tomas
                                    • HoffanH
                                      HoffanH
                                      Hoffan
                                      @korttoma
                                      So if i understand this right, If i have a User and a APIKey, i dont need to do
                                      anything on plot.ly page
                                      I will test to change false to True when i get back home tonight :)
                                      • korttomaK
                                        korttomaK
                                        korttoma
                                        @Hoffan no you should not need to change anything at plot.ly your graph should just appear among "YOUR RECENT FILES" on the right when you go to "https://plot.ly/".
                                        • Tomas
                                        • HoffanH
                                          HoffanH
                                          Hoffan
                                          @korttoma
                                          Big thanks. Now its working :)
