  3. Rotary dimmer switch and mysensors?
16 Posts 6 Posters 7.1k Views 3 Watching
  • O
    O
    otto001
    Yes, thank you. Unfortunately this is not really useable. I have one wall rotary switch and connected it to an arduino directly. But the analogue in does not detect anything I am trying on the switch. I think the rotary encoder is working absolutely different to usual wall switches :-(
    • rvendrameR
      rvendrameR
      rvendrame
      I'm not sure if I understood. Do you have an analog dimmer , connected somehow to arduino? Maybe if you post the circuit + sketch here someone can help...
      ESP8266 GW + mySensors 2.3.2
      Alexa / Google Home
      • O
        O
        otto001
        yes, I have a REV Dimmer Typ 13623 (http://www.rev.de/dzo/artikel/201/0077494_201.pdf?t=1342180610)
        Just connected it to an arduino with some "configurable firmata" and as controller I am using fhem. This sketch is just reporting the status of the pins directly to the controller. I am using pin A0 for instance - if I connect it directly to GND, this is immediately reported to the controller. If I am connecting the dimmer, nothing happens. I hope I could explain what I am trying to do...
        • AWIA
          AWIA
          AWI
          The link is not working for me. Is the dimmer a potentiometer ie variable resistor type? Can you share the schematic of the dimmer and connection?
          • J
            J
            jemish
            I want to control ceiling fan using Rottery dimmer switch using arduino.
            How can i use?
            • O
              O
              otto001
              Sorry, this should work:
              http://www.rev.de/dzo/artikel/201/007/7494_201.pdf?t=1342180610
              Unfortunately it is German only...
              AWIA 1 Reply Last reply
              • O otto001
                AWIA
                AWIA
                AWI
                @otto001 it looks like you are using a 230 volt thyristor/triac dimmer. These do not act as a resistor and therefore cannot be used to connect to the Arduino....
                Maybe if you tell what you want to accomplish there is some help available
                  The knob could possibly be reused with a rotary encoder if you disassemble your dimmer. But it will be hard to squeeze in the necessary AC stuff + Arduino and radion behind the faceplate.
                  • O
                    O
                    otto001
                    What I want to do is pretty simple: Just have a rotary dimmer connected to an arduino - the controller should get the values and dim the lights (connected to different devices) according to the rotary switch. But it should be a wall switch (to get a reliable WAF)....
                    • O otto001
                      AWIA
                      AWIA
                      AWI
                      @otto001 The "waf" of constructions is low... What works for me is momentary switch button dims with a "long press". These are widely available in all kinds of designs. Another option is to combine it with a touch sensor..
                      • O
                        O
                        otto001
                        @AWI: Thanks for your hint. I am also thinking about switch buttons with long press. BTW: how did you implement the long press in mysensors?
                        • O otto001
                          AWIA
                          AWIA
                          AWI
                          @otto001 You can find an example in the "bounce2" library. Below an excerpt from a windowcover routine (nothing special for MySensors)
                          if ( buttonUp.update()){					// change in Up button
                          		if (buttonUp.read() == HIGH){			// release button
                          			buttUpstate = 0 ;
                          			Serial.println("Button UP released");
                          			if (calibrateCover != A_STOP){  	// calibrate end, set value
                          				calibrateCover = A_STOP;
                          				curPos = setPos = lastPos = 0 ; // Set the "UP" position (store in EEPROM and send to controller)
                          		else{									// press button, cover up
                          			buttUpstate = 1 ;
                          			Serial.println("Button UP pressed");
                          			buttUptime = millis(); 				// register change time
                          			if (curAction != A_STOP){			// cover is running, stop at current position and make "set"
                          				setPos = curPos;
                          				setPos = 0;
                          • O
                            O
                            otto001
                            @AWI: thanks! will have a look at it!
                            vladimirV 1 Reply Last reply
                            • O otto001
                              vladimirV
                              vladimirV
                              vladimir
                              @otto001 Hello!
                              Did you manage to implement this node?
