  3. IR Blaster (progress)
99 Posts 32 Posters 89.6k Views 24 Watching
  • tbowmoT tbowmo
    I would be interested in at least one of them. (I'm thinking if we should add repeater mode into the firmware as a default?)
    blaceyB
    blaceyB
    blacey
    Cool and I'll sign-up for 4 Gateway Devices ;) I'm dead serious!
    In my 1st gen one-off IR Blaster, I found that I need to repeat some IR Signals if that is what you mean by "repeater mode". I am using the HA Controller to repeat after some delay but it would make more sense to integrate the repeating logic directly into the firmware. I am planning pretty extensive IR reliability testing with the IR Sensor Array that I mentioned and I hope that repeating won't be necessary but some environments may have sufficient "noise" to require repeating. Perhaps it should be configurable (number of repeats and delay)??
    I'm also thinking that a single IR Blaster should be able to control multiple devices in a given room so I'm planning to provide that as out-of-the-box functionality in the firmware. I don't know how I will do that yet but something akin to an array of child-devices that contains the child device type, manufacturer and IR code. The MySensor's library limit is 255 child devices per node so that should be sufficient ;)
    I also think it makes sense to "lift" the self-tests that you developed for the Micro Sensor (flash and crypto chip).
    Finally, I would love your expert review of the design before I order some boards for verification. I owe you a review of the Gateway Device that I will complete this weekend now that I am back on my home turf.
    • tbowmoT
      tbowmoT
      tbowmo
      @blacey
      With the "repeater mode" I actually meant it to be a repeater for the mysensor network, so it double as both repeater and IR blaster.
      Or maybe I would make a dimmer module, that could act as a repeater as well (I would add a couple of network repeaters around the house, as I have discovered some partially dead spots around here, where sensors are just on the edge of the reach of the RF signals)
      • blaceyB blacey
        @ServiceXp said:
        @blacey Really lovin this.. You plan to sell?
        If there is enough community interest and demand, we (@hek et. al.) will offer the IR Blaster in the same fashion as @tbowmo's pioneering and very successful Sensebender Micro and hopefully in-development Gateway Device that I am personally jazzed about. Any proceeds from IR Blaster hardware sales will go directly to supporting the MySensors.org project (monthly hosting fees, etc.). So to answer that question we need to know who else would buy one if we make it available so we can estimate the batch size for an initial run. Anyone interested is encouraged to weigh in here.
        Moshe LivneM
        Moshe LivneM
        Moshe Livne
        @blacey i would buy 6 of these if they can reproduce my heatpump/hvac codes....
        • DwaltD
          DwaltD
          Dwalt
          I would be in for one, possibly two for media control.
          • 5546dug5
            5546dug5
            5546dug
            I would be good for two.
            Great idea
            • H
              H
              hitosnap
              I would like to buy at least one for TV/Dishtv
                I want to buy one as well.
                • Justin PontiusJ
                  Justin PontiusJ
                  Justin Pontius
                  I would be in for at least 3, probably 5!
                  • sundberg84S
                    sundberg84S
                    I also wants to buy 1-3 depending on price.
                    • DidiD
                      DidiD
                      Didi
                      I want to buy one
                      • korttomaK
                        korttomaK
                        korttoma
                        I am interested allso.
                        • Tomas
                        • RJ_MakeR
                          RJ_MakeR
                          RJ_Make
                          I'm in for at LEAST 1, but most likely ... MORE... :stuck_out_tongue:
                          RJ_Make
                            mscott
                            3 to 5 here
                            • BulldogLowellB
                              BulldogLowellB
                              BulldogLowell
                              I'm in for a couple too...
                              • F
                                F
                                filipq
                                Two for me please.
                                • DrJeffD
                                  DrJeffD
                                  DrJeff
                                  Mark me down for 1!
                                  • rvendrameR
                                    rvendrameR
                                    rvendrame
                                    one for me!
                                    ESP8266 GW + mySensors 2.3.2
                                    Alexa / Google Home
                                    • G
                                      G
                                      gloob
                                      I would also take 5
                                      • jheacockJ
                                        jheacockJ
                                        jheacock
                                        I am interested in at least one, maybe two depending on area coverage.
                                        • blaceyB
                                          blaceyB
                                          blacey
                                          Placed an order for the first prototype boards today... Sourcing from China to U.S. so it will take a while for them to arrive from the fab but I will keep everyone apprised of the progress. That said, here is a render of the protoboard (v0.5) with NRF24L01+ attached to provide a sense of the board's physical size/footprint (thanks to @tbowmo for the NRF24L01+ 3d-shape).
