  3. Power strip with 4 sockets
10 Posts 6 Posters 6.0k Views 3 Watching
  • M Offline
    M Offline
    miremi
    wrote on last edited by miremi
    Hi everyone,
    I have decided to make power strip where i can control each socket independently.
    Parts needed:
    1x Power strip from local shop €18
    1x usb charger 500mah from aliexpress €1,30
    1x arduino nano aliexpress €2,80
    4x relays aliexpress €4
    1x radio aliexpress €0,70
    And some cables €2 +-
    Sketch:
    // Example sketch showing how to control physical relays.
    // This example will remember relay state even after power failure.
      gw.sendSketchInfo("Stekkerdoos", "1.0");
      // Fetch relay status
        gw.present(sensor, S_LIGHT);
        pinMode(pin, OUTPUT);
        digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
      if (message.type==V_LIGHT) {
         // Change relay state
         // Store state in eeprom
    Next step is add led to each socket so that i know which one is on and maybe add buttons for manually control
    Moshe LivneM H 2 Replies Last reply
    • M miremi
      Hi everyone,
      Parts needed:
      Sketch:
      Moshe LivneM Offline
      Moshe Livne
      @miremi if the sockets are on for long periods i would recommend you to switch to bistable relays. The downside is that they are more expensive and need two pins. However, unlike these relays the do not consume electricity while on and do not heat up.
      • M Offline
        M Offline
        miremi
        @ Moshe Livne this one is only for some lights in garden with total consumption of 200w.
        I'm using it now for about a week with no problem and temperature of relays is about 30c even tested it with load of 2100w for about six hours with no heating problems.
        • A Offline
          A Offline
          activemind
          I havent added up your cost but I have one of these from Ubiquity...works like a charm..
          http://www.amazon.com/Ubiquiti-Networks-Power-8Port-MPOWER-PRO/dp/B00HXT8IN2/ref=sr_1_1?ie=UTF8&qid=1434926738&sr=8-1&keywords=ubiquiti+power+strip
          -AM
          • M miremi
            Moshe Livne
            @miremi so all is good.... I had a feeling that mine gets closer to 40c (touch warm, like feverish child....) and would be concerned about heat buildup of so many in closed enclosure
            • Mohsin HassanM Offline
              Mohsin Hassan
              Awesome project man,
              If you can add Buttons for manual control and an LED it would make it complete.
              Looking forward to that.
              • M miremi
                Hi everyone,
                Parts needed:
                Sketch:
                H Offline
                H Offline
                @miremi
                Nice project! Interesting that the "dumb" power strip is about 2/3 of the project cost.
                • S Offline
                  Nice project!
                  I wanted to build one myself - but have now visited three stores, and all have these power strips with special security screws! :rage: Dont want to wait for china delivery. Any ideas?
                  Br
                  • S sundberg84
                    Nice project!
                    Br
                    Moshe Livne
                    @sundberg84 Ha! Mine had one way screws! You can only tighten them, not untighten. A friend of mine lookef at it said no problem and just ignored the fact that it shouldn't work and opened it.
                    There must be a moral there somewhere.
                    If its star ir triangular you can buy bits for next to nothing
                      Mohsin Hassan
                      Hey Man!
                      any progress on the buttons?
                      Really looking forward to that so that i can start making one for myself as well.
                      Cheers.
                      12.2k
