  2. Announcements
  3. Sensebender Micro
Sensebender Micro
584 Posts 84 Posters 658.0k Views 35 Watching
  • nutcrackerN
    nutcrackerN
    nutcracker
    wrote on last edited by nutcracker
    #149
    I've received some boards and all working good.
    I'd like to upload a new sketch to the Sensebender Micro board and I'm attempting to do this via the FTDI FT232RL USB to TTL serial converter adapter that I purchased here (http://www.ebay.co.uk/itm/221552218333).
    Could someone kindly confirm the pin to pin mapping between the FTDI board and the Senseboard Micro as when I attempt to upload I receive the message:
       Programmer Type : butterfly
             Description     : Atmel AppNote AVR109 Boot Loader
    Connecting to programmer: .avrdude: butterfly_recv(): programmer is not responding
    I'm using Arduino 1.6.5 running on Windows 8.1 (inside parallels on a Mac).
    Any ideas?
    Thank you
    Nutz
    hekH 1 Reply Last reply
    • nutcrackerN nutcracker
      Any ideas?
      Thank you
      Nutz
      @nutcracker
      I usually use the GND pin as a guide.
      What happens if you run Arduino IDE directly in your native OS?
      • nutcrackerN
        nutcrackerN
        nutcracker
        #151
        Thanks @hek. I've had to run Arduino on Windows before because of compatibility issues with certain chip sets on Arduino boards and I didn't fancy running unsigned drivers on my Mac to resolve... I'm able to upload sketches to other boards with no issues.
        That said, I've updated Arduino to 1.6.5 on my Mac and have attempted to upload the default Sensebendermicro.ino sketch to the micro with a similar error:
        Arduino: 1.6.5 (Mac OS X), Board: "Arduino Micro"
        Sketch uses 26,414 bytes (92%) of program storage space. Maximum is 28,672 bytes.
        Global variables use 799 bytes (31%) of dynamic memory, leaving 1,761 bytes for local variables. Maximum is 2,560 bytes.
        Found programmer: Id = "�d��b�"; type = F
            Software Version = �.�; Hardware Version = �.�
        avrdude: error: buffered memory access not supported. Maybe it isn't
        a butterfly/AVR109 but a AVR910 device?
        With verbose output enabled:
                 User configuration file is "/Users/nutcracker/.avrduderc"
                 Using Port                    : /dev/cu.usbserial-A50285BI
                 Using Programmer              : avr109
                 Overriding Baud Rate          : 57600
                 AVR Part                      : ATmega32U4
                 BS2                           : PA0
                   eeprom        65    20     4    0 no       1024    4      0  9000  9000 0x00 0x00
                   flash         65     6   128    0 yes     32768  128    256  4500  4500 0x00 0x00
                   lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
                   hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
                   efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
                   lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
        Nutz
          @nutcracker said:
          Maybe it isn't
          Is your programmer setting in Arduino IDE set to "USBasp"?
          • nutcrackerN
            nutcrackerN
            nutcracker
            Hi @hek, I've never had to change the programmer setting before... I've changed it to USBasp and re-uploaded but same error. I've always used the menu options Sketch=>Upload to upload a sketch to the board. Should I be using Sketch=>Upload via programmer for this micro board ? If so, that fails too but something to do with it not being able to find the USB device.
                     Using Programmer              : usbasp
            avrdude: error: could not find USB device with vid=0x16c0 pid=0x5dc vendor='www.fischl.de' product='USBasp'
            avrdude done.  Thank you.
            Nutz
              Hmm. I think I understand what the problem is now. You've selected the "Arduino Micro" board. Not our "MySensors/Sensebender Micro" .
              Did you follow the instructions here?
              http://www.mysensors.org/hardware/micro-ide-setup
              • nutcrackerN
                nutcrackerN
                nutcracker
                Thanks @hek, I also realised my mistake once I retraced my steps...I hadn't scrolled down fully on that screenshot that shows the Sensebender Micro board... I think what through me is that screenshot also shows a "dot" against another board - the Arduino Micro board...and I was selecting that... duh! (may be worth changing the screenshot? ;))
                Anyway, thanks for your help...sketch uploaded perfectly after that!
                         Programmer Type : Arduino
                         Description     : Arduino
                         Hardware Version: 3
                         Firmware Version: 5.0
                         Vtarget         : 0.3 V
                         Varef           : 0.3 V
                         Oscillator      : 28.800 kHz
                         SCK period      : 3.3 us
                avrdude: reading input file "/var/folders/r3/_6srq76n0mz4kmh86hsy4y2m0000gn/T/build4750928375396503439.tmp/SensebenderMicro.cpp.hex"
                avrdude: writing flash (23678 bytes):
                Writing | ################################################## | 100% 8.84s
                avrdude: 23678 bytes of flash written
                avrdude: verifying flash memory against /var/folders/r3/_6srq76n0mz4kmh86hsy4y2m0000gn/T/build4750928375396503439.tmp/SensebenderMicro.cpp.hex:
                avrdude: load data flash data from input file /var/folders/r3/_6srq76n0mz4kmh86hsy4y2m0000gn/T/build4750928375396503439.tmp/SensebenderMicro.cpp.hex:
                avrdude: input file /var/folders/r3/_6srq76n0mz4kmh86hsy4y2m0000gn/T/build4750928375396503439.tmp/SensebenderMicro.cpp.hex contains 23678 bytes
                Reading | ################################################## | 100% 9.94s
                avrdude: verifying ...
                avrdude: 23678 bytes of flash verified
                Cheers!
                Nutz
                  Ah... there is a dot in the menu-image. Will update it. Thanks.
                  RJ_MakeR 1 Reply Last reply
                    RJ_MakeR
                    RJ_MakeR
                    RJ_Make
                    @hek Interesting.. I didn't know this.. I used the standard Pro Mini 3v3 and it worked...????
                    RJ_Make
                    • G
                      G
                      gloob
                      Received my Micros today. Luckily there was no custom and a lot of pins to solder. Can't wait to solder them on wednesday on work and test them.
                      Is there any instruction how to solder everything? On which side the radio module needs to be soldered.
                      tbowmoT 1 Reply Last reply
                      • G gloob
                        tbowmoT
                        tbowmoT
                        tbowmo
                        #159
                        @gloob
                        This might help you out :)
                        • G
                          G
                          gbfromhb
                          I hope this question has not been answered already and I did not miss the answer. I was thinking about connecting a motion sensor to this and was hoping that one of the digital pins supports an interrupt. Is there an interrupt available?
                            @gbfromhb
                            • G gbfromhb
                              mvader
                              I'm planning to do the same thing.
                              i ordered my 5v step up regulators to support the PIR sensor.
                              although I hope adding the motion isnt going to kill the batteries.
                              • G
                                G
                                gbfromhb
                                wrote on last edited by gbfromhb
                                #163
                                @mvader
                                M 2 Replies Last reply
                                • G
                                  G
                                  gbfromhb
                                  @Hek
                                  Thanks, I saw the D3, but I'm new enough to this adventure that I was not sure if I should have assumed that it also had an interrupt like all the other boards.
                                  • tbowmoT
                                    tbowmoT
                                    tbowmo
                                    @gbfromhb
                                    I tried to keep the naming, and pins on the atmega, the same as an ordinary arduino :)
                                    • G gbfromhb
                                      @mvader
                                      mvader
                                      @gbfromhb said:
                                      @mvader
                                      wow.. nice.. thanks for the info! I will give this a go asap.
                                      • G
                                        G
                                        gloob
                                        I have one more question. Is it possible to power the micro from the ftdi pins? I would like to use jumper wires.
                                        • tbowmoT
                                          tbowmoT
                                          tbowmo
                                          @gloob
                                          Yes it's possible to power it from the FTDI pins, if you want to..
