  2. Announcements
  3. Sensebender Micro
Sensebender Micro
584 Posts 84 Posters 658.8k Views 35 Watching
    Ah... there is a dot in the menu-image. Will update it. Thanks.
    RJ_MakeR 1 Reply Last reply
      RJ_MakeR
      RJ_MakeR
      RJ_Make
      @hek Interesting.. I didn't know this.. I used the standard Pro Mini 3v3 and it worked...????
      RJ_Make
      • G
        G
        gloob
        Received my Micros today. Luckily there was no custom and a lot of pins to solder. Can't wait to solder them on wednesday on work and test them.
        Is there any instruction how to solder everything? On which side the radio module needs to be soldered.
        tbowmoT 1 Reply Last reply
        • G gloob
          tbowmoT
          tbowmoT
          tbowmo
          #159
          @gloob
          This might help you out :)
          • G
            G
            gbfromhb
            I hope this question has not been answered already and I did not miss the answer. I was thinking about connecting a motion sensor to this and was hoping that one of the digital pins supports an interrupt. Is there an interrupt available?
              @gbfromhb
              • G gbfromhb
                mvader
                I'm planning to do the same thing.
                i ordered my 5v step up regulators to support the PIR sensor.
                although I hope adding the motion isnt going to kill the batteries.
                • G
                  G
                  gbfromhb
                  wrote on last edited by gbfromhb
                  #163
                  @mvader
                  M 2 Replies Last reply
                  • G
                    G
                    gbfromhb
                    @Hek
                    Thanks, I saw the D3, but I'm new enough to this adventure that I was not sure if I should have assumed that it also had an interrupt like all the other boards.
                    • tbowmoT
                      tbowmoT
                      tbowmo
                      @gbfromhb
                      I tried to keep the naming, and pins on the atmega, the same as an ordinary arduino :)
                      • G gbfromhb
                        @mvader
                        mvader
                        @gbfromhb said:
                        @mvader
                        wow.. nice.. thanks for the info! I will give this a go asap.
                        • G
                          G
                          gloob
                          I have one more question. Is it possible to power the micro from the ftdi pins? I would like to use jumper wires.
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            @gloob
                            Yes it's possible to power it from the FTDI pins, if you want to..
                            • G
                              G
                              gloob
                              Are there any recommendations for a low power temperature, humidity sensor regarding the update cycle.
                              Currently I plan to wake up the sensor each 10 minutes instead of each 1 minute to update the values. This should increase the duration of the battery. A complete update of all values if performed each 30 minutes as usual.
                              • tbowmoT
                                tbowmoT
                                tbowmo
                                I would probably choose 5 minutes interval instead.. I have updated the sensebendermicro sketch tonight (just waiting for @hek to approve it). so it holds of on the transmissions a bit. Now the temperature needs to change more than 0.5 degrees from the previous transmitted value. OR
                                humidity needs to change more than 0.5, measured with a moving average. OR
                                30 minutes since last transmission.
                                • G
                                  G
                                  gloob
                                  wrote on last edited by gloob
                                  #171
                                  I found that when I power the micro from 2 batteries I get the following error:
                                  T: 23.21
                                  H: 50
                                  send: 104-104-0-0 s=1,c=1,t=0,pt=7,l=5,st=fail:23.2
                                  send: 104-104-0-0 s=2,c=1,t=1,pt=2,l=2,st=fail:50
                                  This does not happen when I power it from the FTDI programmer.
                                  Does anybody have any ideas?
                                  The batteries have a voltage of 3.25V
                                  I did not have this issues with my arduino nano sensors. and i did use the same radio modules.
                                  When I check the modules they seem to be real nrf24l01+ modules:
                                  STATUS		 = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
                                  RX_ADDR_P0-1	x00 = 0xe7e7e7e7e7 0xf0f0f0f0d2
                                  RX_ADDR_P2-5	x00 = 0xc3 0xc4 0xc5 0xc6
                                  TX_ADDR		 = 0xe7e7e7e7e7
                                  RX_PW_P0-6	x00 = 0x00 0x20 0x00 0x00 0x00 0x00
                                  EN_AA		 = 0x3f
                                  EN_RXADDR	x00 = 0x03
                                  RF_CH		 = 0x4c
                                  RF_SETUP	x00 = 0x07
                                  CONFIG		 = 0x0f
                                  DYNPD/FEATURE	x00 = 0x00 0x00
                                  Data Rate	 = 1MBPS
                                  Model		 = nRF24L01+
                                  CRC Length	 = 16 bits
                                  PA Power	 = PA_HIGH
                                  • F
                                    F
                                    Fabien
                                    I have a batch of 5 sensebender and actually I build 3 and one of them doesn't work properly. Lot of st:fail when I put my finger on the board it works better so I try to make all solder one more time but it's not ok. I try with few radios and same radios work well on the others sensbender.
                                    Any idea or way to exchange with Itead ?
                                    • tbowmoT
                                      tbowmoT
                                      tbowmo
                                      @Fabien
                                      Where exactly do you put your finger on it, in order to get it working?
                                      • tbowmoT
                                        tbowmoT
                                        tbowmo
                                        @gloob
                                        It's the same power rail (FTDI, and the battery connector). What do you supply the board with, thru the FTDI header?
                                        • F
                                          F
                                          Fabien
                                          @tbowmo difficult to answer this question. It seems to be on Atmega but after trying to resold it's not better. I resol capacitors, resistors ... I don't know what to do now ...
