  3. Working gateway ?
Working gateway ?
13 Posts 3 Posters 4.0k Views 2 Watching
  • F Offline
    F Offline
    Fabien
    I buy 5 sensebender cards and NRF24L01+ modules (from electrodragon) and 1 NRF24 amplfied
    With my UNO and amplified or not version it doesn't work well (lot of st:fail).
    I had capacitor (10uF) on each NRF Board, try external 3.3V but it always working bad.
    So I try with Pro micro (5V 16Mhz Version) but It doesn't work. Controller try a "Get version" but no answer from ProMicro. I change CE an CS pin to 2/3 on ProMicro (I read on some forums it doesn't work with 9/10) and change init code but doesnt work too ... Any advice ?
    • rvendrameR Offline
      rvendrameR Offline
      rvendrame
      @Fabien, regarding the 'st:fail' . How are you powering UNO and Radio? Some very cheap phone chargers may introduce a lot of noise on power that even a big capacitor can not handle...
      ESP8266 GW + mySensors 2.3.2
      Alexa / Google Home
      • F Offline
        F Offline
        Fabien
        So i try with 2 AA battery for powering radio on gateway. Same about 50% of st:fail. Powering arduino from 2A power supply. At oscilliscope, using spectrum analyzer nothing to report on 3.3V and 5V. Pehaps dupont cable ?
          rvendrameR Offline
          rvendrame
          How far are the node from the gateway? Any wall or obstacle in between?
          Alexa / Google Home
          • F Offline
            F Offline
            Fabien
            about 2 meters with no obstacle :(
              rvendrameR Offline
              rvendrame
              Do you have different radios to try with?
              Alexa / Google Home
              • F Offline
                F Offline
                Fabien
                yes with 5 radios and 1 amplified version !
                • tbowmoT Offline
                  tbowmoT Offline
                  tbowmo
                  are those 5 radios from the same batch?
                  have you seen this forum thread
                  Might be cheap NRF24 clones you've got..
                  • F Offline
                    F Offline
                    Fabien
                    Ok so where can I buy good nrf ?
                    Actually all my componment and modules comes from electrodragon without any problem.
                    • F Offline
                      F Offline
                      Fabien
                      Ok I try now with only few centimeters and PA_LOW on gateway and it doesn't work well....
                      • F Offline
                        F Offline
                        Fabien
                        Now I just try with another sensebender with radio directly solder on board and it work fine with no st:fail. radio was previously tested on the first board with lot of st:fail. I will chek the first board, perhaps bad solder or problem with adaptater.
                        • tbowmoT Offline
                          tbowmoT Offline
                          tbowmo
                          I bought the latest batch of NRF modules from itead, together with my sensebender pcb's. It should be genuine NRF chips they use.
                          • F Offline
                            F Offline
                            Fabien
                            ok for my next xenebender batch I will buy NRF together. And now I confirm the problem with bad contact (with my finger it works fine !!!. I will directly solder NRF to sensebernder tomorrow. Strange, my solders seems to be fine and I made it all one mmore time but same problem.
                            I will let the new sensbender online all the night. I will check tomorow my grafana input !
                            11.8k
                            113.2k
