  3. Working gateway ?
Working gateway ?
13 Posts 3 Posters 4.9k Views 2 Watching
  • F
    F
    Fabien
    So i try with 2 AA battery for powering radio on gateway. Same about 50% of st:fail. Powering arduino from 2A power supply. At oscilliscope, using spectrum analyzer nothing to report on 3.3V and 5V. Pehaps dupont cable ?
    • rvendrameR
      rvendrameR
      rvendrame
      How far are the node from the gateway? Any wall or obstacle in between?
      ESP8266 GW + mySensors 2.3.2
      Alexa / Google Home
      • F
        F
        Fabien
        about 2 meters with no obstacle :(
        • rvendrameR
          rvendrameR
          rvendrame
          Do you have different radios to try with?
          Alexa / Google Home
          • F
            F
            Fabien
            yes with 5 radios and 1 amplified version !
            • tbowmoT
              tbowmoT
              tbowmo
              are those 5 radios from the same batch?
              have you seen this forum thread
              Might be cheap NRF24 clones you've got..
              • F
                F
                Fabien
                Ok so where can I buy good nrf ?
                Actually all my componment and modules comes from electrodragon without any problem.
                • F
                  F
                  Fabien
                  Ok I try now with only few centimeters and PA_LOW on gateway and it doesn't work well....
                  • F
                    F
                    Fabien
                    Now I just try with another sensebender with radio directly solder on board and it work fine with no st:fail. radio was previously tested on the first board with lot of st:fail. I will chek the first board, perhaps bad solder or problem with adaptater.
                    • tbowmoT
                      tbowmoT
                      tbowmo
                      I bought the latest batch of NRF modules from itead, together with my sensebender pcb's. It should be genuine NRF chips they use.
                      • F
                        F
                        Fabien
                        ok for my next xenebender batch I will buy NRF together. And now I confirm the problem with bad contact (with my finger it works fine !!!. I will directly solder NRF to sensebernder tomorrow. Strange, my solders seems to be fine and I made it all one mmore time but same problem.
                        I will let the new sensbender online all the night. I will check tomorow my grafana input !
