  2. Announcements
  3. Sensebender Micro
Sensebender Micro
584 Posts 84 Posters 658.8k Views 35 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    I would probably choose 5 minutes interval instead.. I have updated the sensebendermicro sketch tonight (just waiting for @hek to approve it). so it holds of on the transmissions a bit. Now the temperature needs to change more than 0.5 degrees from the previous transmitted value. OR
    humidity needs to change more than 0.5, measured with a moving average. OR
    30 minutes since last transmission.
    • G
      G
      gloob
      wrote on last edited by gloob
      #171
      I found that when I power the micro from 2 batteries I get the following error:
      T: 23.21
      H: 50
      send: 104-104-0-0 s=1,c=1,t=0,pt=7,l=5,st=fail:23.2
      send: 104-104-0-0 s=2,c=1,t=1,pt=2,l=2,st=fail:50
      This does not happen when I power it from the FTDI programmer.
      Does anybody have any ideas?
      The batteries have a voltage of 3.25V
      I did not have this issues with my arduino nano sensors. and i did use the same radio modules.
      When I check the modules they seem to be real nrf24l01+ modules:
      STATUS		 = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
      RX_ADDR_P0-1	x00 = 0xe7e7e7e7e7 0xf0f0f0f0d2
      RX_ADDR_P2-5	x00 = 0xc3 0xc4 0xc5 0xc6
      TX_ADDR		 = 0xe7e7e7e7e7
      RX_PW_P0-6	x00 = 0x00 0x20 0x00 0x00 0x00 0x00
      EN_AA		 = 0x3f
      EN_RXADDR	x00 = 0x03
      RF_CH		 = 0x4c
      RF_SETUP	x00 = 0x07
      CONFIG		 = 0x0f
      DYNPD/FEATURE	x00 = 0x00 0x00
      Data Rate	 = 1MBPS
      Model		 = nRF24L01+
      CRC Length	 = 16 bits
      PA Power	 = PA_HIGH
      • F
        F
        Fabien
        I have a batch of 5 sensebender and actually I build 3 and one of them doesn't work properly. Lot of st:fail when I put my finger on the board it works better so I try to make all solder one more time but it's not ok. I try with few radios and same radios work well on the others sensbender.
        Any idea or way to exchange with Itead ?
        • tbowmoT
          tbowmoT
          tbowmo
          @Fabien
          Where exactly do you put your finger on it, in order to get it working?
          • tbowmoT
            tbowmoT
            tbowmo
            @gloob
            It's the same power rail (FTDI, and the battery connector). What do you supply the board with, thru the FTDI header?
            • F
              F
              Fabien
              @tbowmo difficult to answer this question. It seems to be on Atmega but after trying to resold it's not better. I resol capacitors, resistors ... I don't know what to do now ...
              • tbowmoT
                tbowmoT
                tbowmo
                @Fabien
                Did you also resolder the atmega itself?
                Could you try and measure supply current it uses?
                • F
                  F
                  Fabien
                  current when powering on : 20 mA and during sleeping about 20uA (not very accurate).
                  • tbowmoT
                    tbowmoT
                    tbowmo
                    @Fabien
                    Have you tried to add an extra capacitor to the NRF module, on the one that's bad? (Could be your finger adds a bit more capacitance, I know it's a wild guess but just trying to think out loud)
                    • F
                      F
                      Fabien
                      Ok but wich value ? I just finish to solder my 4th sensebender and ok too.
                        wrote on last edited by hek
                        #180
                        Does the failed messages reach their destination (gateway in your case)? As you might know it is the ack that never reaches the sensbender node which could be a result of power issues on the gateway side.
                        • F
                          F
                          Fabien
                          no, message are not recieve. I find someting :
                          When I touch the NRF24 antenna (just a little it sifficient), it works. fine.
                          Strange, same radio on other sensebender doesn't need this and other radio on this sensebender need to bo "touch".
                          I try with 10uF additionnal on NRF but no change ...
                            #182
                            Do you use a socket or is the NRF module directly soldered onto the sensbender?
                            (a bad connection in socket could be a problem... and when you press NRF module it has connection again)
                            • F
                              F
                              Fabien
                              Yes it's directly sold (and very hard to change with metallised hole). I will give a last try with another radio ...
                              • F
                                F
                                Fabien
                                Ok end of story ... sensebender card is dead ! 2 metallized hole were destroy by solder/unsoldering NRF modules.
                                Hope my last Sensebender will work. And if there is a batch with light version I will reuse T/H sensor
                                • G
                                  G
                                  gloob
                                  @Fabien it seems that you have the same problem as me. I ordered a new set of radio modules to test if it is the fault of the radios. I will give feedback here about my progress.
                                  I aleady tried to add capacitors on the radio module but this did not help.
                                  There is also no difference if I power the micro from the FTDI or the battery connector.
                                  • tbowmoT
                                    tbowmoT
                                    tbowmo
                                    @Fabien
                                    Unfortunately I don't think there will be a light edition coming out at the moment. Currently the savings is way too small (I'm estimating a savings of 4-5$ compared to the full sensebender edition).
                                      @Fabien
                                      Here are some quite nice repair guides
                                      http://www.circuitrework.com/guides/guides.shtml
                                      More specifically
                                      http://www.circuitrework.com/guides/5-1.shtml
                                      • F
                                        F
                                        Fabien
                                        @gloob it's not a radio problem. Same radio works on the others boards.
                                        @hek I will try to repair the board ...
                                          mvader
                                          wrote on last edited by mvader
                                          #189
                                          looking for some help programming this thing.
                                          I had a pl2303 usb programmer, but it had no DTR, so i orders a new usb programmer
                                          this one is a cp2102 with a DTR line.
                                          but still the same problem. it never uploads the code.
                                          i have the right board, processor and port chosen.
                                          i have tried all the programmers in the IDE but none work.
                                          it just says "uploading" and then eventually errors out.
                                          any suggestions?
                                          EDIT: nm i read something about switching tx and rx and i figured what the heck and surprise it worked..
                                          sketch uploaded..
