  2. Announcements
  3. Sensebender Micro
Sensebender Micro
584 Posts 84 Posters 658.8k Views 35 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    @gbfromhb
    I tried to keep the naming, and pins on the atmega, the same as an ordinary arduino :)
    • G gbfromhb
      @mvader
      mvader
      @gbfromhb said:
      @mvader
      wow.. nice.. thanks for the info! I will give this a go asap.
      • G
        G
        gloob
        I have one more question. Is it possible to power the micro from the ftdi pins? I would like to use jumper wires.
        • tbowmoT
          tbowmoT
          tbowmo
          @gloob
          Yes it's possible to power it from the FTDI pins, if you want to..
          • G
            G
            gloob
            Are there any recommendations for a low power temperature, humidity sensor regarding the update cycle.
            Currently I plan to wake up the sensor each 10 minutes instead of each 1 minute to update the values. This should increase the duration of the battery. A complete update of all values if performed each 30 minutes as usual.
            • tbowmoT
              tbowmoT
              tbowmo
              I would probably choose 5 minutes interval instead.. I have updated the sensebendermicro sketch tonight (just waiting for @hek to approve it). so it holds of on the transmissions a bit. Now the temperature needs to change more than 0.5 degrees from the previous transmitted value. OR
              humidity needs to change more than 0.5, measured with a moving average. OR
              30 minutes since last transmission.
              • G
                G
                gloob
                wrote on last edited by gloob
                #171
                I found that when I power the micro from 2 batteries I get the following error:
                T: 23.21
                H: 50
                send: 104-104-0-0 s=1,c=1,t=0,pt=7,l=5,st=fail:23.2
                send: 104-104-0-0 s=2,c=1,t=1,pt=2,l=2,st=fail:50
                This does not happen when I power it from the FTDI programmer.
                Does anybody have any ideas?
                The batteries have a voltage of 3.25V
                I did not have this issues with my arduino nano sensors. and i did use the same radio modules.
                When I check the modules they seem to be real nrf24l01+ modules:
                STATUS		 = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
                RX_ADDR_P0-1	x00 = 0xe7e7e7e7e7 0xf0f0f0f0d2
                RX_ADDR_P2-5	x00 = 0xc3 0xc4 0xc5 0xc6
                TX_ADDR		 = 0xe7e7e7e7e7
                RX_PW_P0-6	x00 = 0x00 0x20 0x00 0x00 0x00 0x00
                EN_AA		 = 0x3f
                EN_RXADDR	x00 = 0x03
                RF_CH		 = 0x4c
                RF_SETUP	x00 = 0x07
                CONFIG		 = 0x0f
                DYNPD/FEATURE	x00 = 0x00 0x00
                Data Rate	 = 1MBPS
                Model		 = nRF24L01+
                CRC Length	 = 16 bits
                PA Power	 = PA_HIGH
                • F
                  F
                  Fabien
                  I have a batch of 5 sensebender and actually I build 3 and one of them doesn't work properly. Lot of st:fail when I put my finger on the board it works better so I try to make all solder one more time but it's not ok. I try with few radios and same radios work well on the others sensbender.
                  Any idea or way to exchange with Itead ?
                  • tbowmoT
                    tbowmoT
                    tbowmo
                    @Fabien
                    Where exactly do you put your finger on it, in order to get it working?
                    • tbowmoT
                      tbowmoT
                      tbowmo
                      @gloob
                      It's the same power rail (FTDI, and the battery connector). What do you supply the board with, thru the FTDI header?
                      • F
                        F
                        Fabien
                        @tbowmo difficult to answer this question. It seems to be on Atmega but after trying to resold it's not better. I resol capacitors, resistors ... I don't know what to do now ...
                        • tbowmoT
                          tbowmoT
                          tbowmo
                          @Fabien
                          Did you also resolder the atmega itself?
                          Could you try and measure supply current it uses?
                          • F
                            F
                            Fabien
                            current when powering on : 20 mA and during sleeping about 20uA (not very accurate).
                            • tbowmoT
                              tbowmoT
                              tbowmo
                              @Fabien
                              Have you tried to add an extra capacitor to the NRF module, on the one that's bad? (Could be your finger adds a bit more capacitance, I know it's a wild guess but just trying to think out loud)
                              • F
                                F
                                Fabien
                                Ok but wich value ? I just finish to solder my 4th sensebender and ok too.
                                  wrote on last edited by hek
                                  #180
                                  Does the failed messages reach their destination (gateway in your case)? As you might know it is the ack that never reaches the sensbender node which could be a result of power issues on the gateway side.
                                  • F
                                    F
                                    Fabien
                                    no, message are not recieve. I find someting :
                                    When I touch the NRF24 antenna (just a little it sifficient), it works. fine.
                                    Strange, same radio on other sensebender doesn't need this and other radio on this sensebender need to bo "touch".
                                    I try with 10uF additionnal on NRF but no change ...
                                      #182
                                      Do you use a socket or is the NRF module directly soldered onto the sensbender?
                                      (a bad connection in socket could be a problem... and when you press NRF module it has connection again)
                                      • F
                                        F
                                        Fabien
                                        Yes it's directly sold (and very hard to change with metallised hole). I will give a last try with another radio ...
                                        • F
                                          F
                                          Fabien
                                          Ok end of story ... sensebender card is dead ! 2 metallized hole were destroy by solder/unsoldering NRF modules.
                                          Hope my last Sensebender will work. And if there is a batch with light version I will reuse T/H sensor
