  3. Trouble combining sketches for temp and motion control
24 Posts 6 Posters 10.9k Views 2 Watching
    The DHT11/22 sensor gives both temperature and humidity.
    @hek But I was hoping to use the DS18b20?
      Yep, I know. This was just an example how I combined them to help you a bit while exploring the wonderful world of embedded programming ;)
        I am gratefull ;)
        I will try to compare the sketches.
        • D
          davvvvvo
          Hek, tried your sketch. Motion works but not getting a temp reading on my Vera. Using the dht 22,sensor onto pin 6. Am I missing something? I'm using the same power that the motion uses on the nano.
          • sundberg84S
            sundberg84S
            Do you have a bare DHT that needs a resistor?
            link text
            What does the serial say?
            • D
              davvvvvo
              It doesnt give a reading for temperature or humidity. Sensor works. Yeah it's the solder free module dht 22 that has the three pronges
              DwaltD 1 Reply Last reply
              • D davvvvvo
                DwaltD
                DwaltD
                Dwalt
                @davvvvvo Did you re-include the node after changing the sketch? What controller are you using? Post your sketch using the </> tool.
                • DwaltD Dwalt
                  davvvvvo
                  @Dwalt yes I removed the node off Vera U7 and re added it as instructions say. Using Nana serial controller. The motion sensor works perfectly. I'm using hek sketch, I just cut and paste the sketch into to program and compiled and uploaded. Do I need a resistor with the dht 22 temp sensor because I don't have one on it at the moment.
                  • D davvvvvo
                    DwaltD
                    DwaltD
                    Dwalt
                    @davvvvvo If you used Hek's sketch above and your DHT is connected to pin 6 and the PIR on pin 3, it should work. How are you powering the DHT and PIR? You should be using the nano's 5v. You do not need a separate resistor on the DHT module (3 pins), it has one onboard the module. Are you seeing the temp and hum child devices in Vera? If so, try powering the node off-on and reloading the Vera page.
                    • DwaltD Dwalt
                      davvvvvo
                      wrote on last edited by davvvvvo
                      @Dwalt I'm powering both sensors off the 5v pin on the board so they are sharing the power. Temp is on pin 6. All three nodes added to Vera. I can arm or bypass the motion and this works, the temp and humidity node are on Vera but not showing any numbers. Temp is at 0 degrees and humidity is at 0%. I tried cycling the nodes off and on a few times. With no results.
                      • D davvvvvo
                        DwaltD
                        DwaltD
                        Dwalt
                        @davvvvvo If you eliminate any wiring mistakes, I assume you must have a bad DHT sensor. You could try it without the PIR and load up the basic temp/hum sketch to see if it works or see if you can see anything through the serial log.
                        • DwaltD Dwalt
                          davvvvvo
                          @Dwalt Just used the DHT sensor on its own and loaded the humidity sketch and it works perfectly. did try and load the dallas temp sketch and that didnt work on its own. Question will i need to upload if there is one someting like a dallas.JSON or or another XML onto vera for hek's sketch to work possibly?
                          • D davvvvvo
                            DwaltD
                            DwaltD
                            Dwalt
                            @davvvvvo The Dallas sensor is completely different from the DHT and does not factor into your setup. The DHT provides both temp and humidity. The Dallas temp sensor uses a separate library for pulling data from that particular sensor. Can you post your serial log from your sensor with both DHT and PIR connected using the sketch Hek provided above? That would tell us what is happening at the communication level between the sensor node and gateway.
                            D 3 Replies Last reply
                            • DwaltD Dwalt
                              davvvvvo
                              @Dwalt how do i go about gathering the serial log. Can i plug in the sensor and download the serial log with the arduino program
                              • DwaltD Dwalt
                                davvvvvo
                                • DwaltD Dwalt
                                  davvvvvo
                                  @Dwalt
                                  sensor started, id 2
                                  send: 2-2-0-0 s=255,c=0,t=17,pt=0,l=5,st=ok:1.4.1
                                  send: 2-2-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
                                  send: 2-2-0-0 s=255,c=3,t=11,pt=0,l=16,st=ok:Multi Motion+Hum
                                  send: 2-2-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
                                  send: 2-2-0-0 s=0,c=0,t=7,pt=0,l=0,st=ok:
                                  send: 2-2-0-0 s=1,c=0,t=6,pt=0,l=0,st=ok:
                                  send: 2-2-0-0 s=3,c=0,t=1,pt=0,l=0,st=ok:
                                  Tripped: 0
                                  send: 2-2-0-0 s=3,c=1,t=16,pt=0,l=1,st=ok:0
                                  Failed reading temperature from DHT
                                  Failed reading humidity from DHT
                                  Tripped: 0
                                  Tripped: 0
                                  • sundberg84S
                                    sundberg84S
                                    #21
                                    Its a problem with the DHT, the setup between Arduino and DHT sensor i think...
                                    -Tried another DHT-Sensor or bare DHT code?
                                    -Tried another inputpin on the arduino (i got this message when i didnt solder the pin properly)
                                    -Check/change wiring.
                                    Also try the delay(dht.getMinimumSamplingPeriod()); before the motion sensor code and see if this changes anything.
                                    • sundberg84S sundberg84
                                      davvvvvo
                                      @sundberg84 I have two DHT22 sensors which I have tried both. They both work when I run the humidity sketch on its own but not when I try this sketch. Having never written code before this "delay(dht.getMinimumSamplingPeriod());" I have no clue what this is. Also if I used pin 5 for example how would I go changing the code to represent this. Cheers everyone so far for your help fault finding what's wrong with my set up. I don't usually give up but this simple one is testing my patients to the point I might just run a temp sensor on its own.
                                      SparkmanS 1 Reply Last reply
                                      • D davvvvvo
                                        SparkmanS
                                        SparkmanS
                                        Sparkman
                                        @davvvvvo
                                        "delay(dht.getMinimumSamplingPeriod());" is used to not retrieve info from the DHT22 too often. The sensors don't respond if polled too frequently and this is a function in the DHT library. To change the sketch to use pin 5, change this line:
                                        #define HUMIDITY_SENSOR_DIGITAL_PIN 6
                                        to
                                        #define HUMIDITY_SENSOR_DIGITAL_PIN 5
                                        Is the sketch you are using identical to the one @hek posted? How are you powering your board?
                                        Al
                                        • SparkmanS Sparkman
                                          @davvvvvo
                                          to
                                          Al
                                          davvvvvo
                                          @Sparkman yes it's the same sketch hek uploaded word for word. Powering using a phone charger 5v 1amp. Im putting it down to I might have a faulty pin 6 or the sketch doesn't play well with Vera and the plugin. Does anyone have another sketch?
