  3. Domoticz
  4. How to add a sensor to the serial gateway
25 Posts 6 Posters 28.1k Views 1 Watching
  • Moshe LivneM Moshe Livne
    @Bram81 domoticz with mysensors is awesome. However, the gateway is one arduino with nrf that is connected to the rpi and notify the controller what is happening. The sensor nodes are also arduinos with nrf and they are running the sensor sketch. Hope this clarified thing a bit...
    B
    B
    Bram81
    @Moshe-Livne Thanks for your reply! So if I understand correctly there is one Arduino with the serial sketch on it that acts as the gateway and I have to use another arduino to add sensors to. Will a second Arduino connected to the Rpi through USB and running my sensor sketch be picked up by the gateway automatically?
      Yes you can do that. For example, you can have a gateway and a node connected on your computer so you can serial debug each. But of course, one Gateway (gateway sketch) for n nodes (nodes sketch).
      B 1 Reply Last reply
      • scalzS scalz
        B
        B
        Bram81
        @scalz Ok, that is what I was hoping... Right now I have one Arduino Uno conncted through USB to my Rpi running the gateway sketch on port ACM0
        Another Uno which has a soil moisture sensor connected to it and running a sketch is also connected through USB to ACM1 port. Still I can't see any new devices in Domoticz...
        Would this be the way to go or am I doing something verry wrong..?
        • sundberg84S
          sundberg84S
          I think you have to add the gateway as hardware in domoticz. Then when the gateway recieve info from the node/sensor its transferred into domoticz. If you have connected the node/sensor through the GPIO i think you need to create some sort of virtual device and program this in domoticz, but then the gateway are not used. The best way is Domoticz -> Gateway -> Sensors.
          The MySensors use the radio to talk to the gateway... i dont know how to do that with a wire/usb.
          • B
            B
            Bram81
            Thanks for your post. Aha I thought that working without radio was the difference between serial and ethernet gateways. I've ordered some nRF24L01+. modules, probably getting them in a couple of days.
            So I'll have to connect one of those to the gateway and one to the arduino Uno holding my moisture sensors?
            • B Bram81
              Moshe LivneM
              Moshe LivneM
              Moshe Livne
              @Bram81 yes.... no way around it. the controller talks with the gateway through the USB (Serial)
              or Ethernet (Ethernet gateway) but the gateway communicates with the sensor nodes through the nrf modules.
                @Bram81
                You try using the serial gateway in this branch:
                https://github.com/mysensors/Arduino/tree/gateway-refactoring
                It allows sensors to be attached to the gateway itself. Note that it is still WIP (and I'm unsure if all controllers support this).
                • B
                  B
                  Bram81
                  Thanks everybody! Got the serial gateway working and it's being picked up by domoticz. Now another Arduino Uno is holding a moisture sensor, it's communicating with the gateway, but Domoticz sees the sensor as a lamp so it's not logging the sensor output. The sensor is a YL-38. Is there a way to fix this or is this type simply not supported by Domoticz?
                  • sundberg84S
                    sundberg84S
                    Hi!
                    Is the sensor presented correctly - what does the domoticz log say when you power up the sensor?
                    Do you see anything in the domoticz and or gateway log when sending temp-values?
                    • sundberg84S sundberg84
                      Hi!
                      B
                      B
                      Bram81
                      @sundberg84 Hey!
                      Domoticz log shows:
                      015-07-01 15:44:03.331 MySensors: Gateway Ready...
                      2015-07-01 15:44:28.776 Hardware Monitor: Fetching data (System sensors)
                      2015-07-01 15:44:41.187 (Gateway) Lighting 2 (Vochtigheid border)
                      2015-07-01 15:44:45.357 (Gateway) Lighting 2 (Vochtigheid border)
                      2015-07-01 15:44:58.920 Hardware Monitor: Fetching data (System sensors)
                      2015-07-01 15:45:28.298 MySensors: Node: 3, Sketch Name: Soil Moisture Sensor
                      2015-07-01 15:45:28.302 MySensors: Node: 3, Sketch Version: 1.0
                      Hooking up the gateway and node to a laptop to use the serial monitor shows data being send from the sensor and received by the gateway.
                      After plugging in the gateway to my pi running domoticz there was a new hardware detected right away, but only not as a sensor but as a lightning2 type lamp switch which I've named 'vochtigheid border'. The log of this 'switch itself shows:
                      2015-07-01 15:44:45 On
                      2015-07-01 15:44:41 Off
                      2015-07-01 15:41:02 On
                      2015-07-01 14:49:43 Off
                      2015-07-01 14:31:56 On
                      2015-07-01 14:31:56 Off
                      Does this make any sense to you...?
                      • B
                        B
                        Bram81
                        Oh and I'm using this sketc btw : http://www.mysensors.org/build/moisture
                        • sundberg84S
                          sundberg84S
                          Hi @Bram81
                          Looks good so far... i was just about to suggest the domoticz forum, but then i saw this: link text and i guess its you :)
                          In the link (Rain & Moisture scetch) it looks like the GW.present: gw.present(CHILD_ID, S_MOTION);
                          Does this mean its presented as a motion sensor? @hek ?
                          Anyhow - in the Domoticz code there is not any code for S_MOTION so you have to request this.
                          MySensorsBase.cpp
                          I dont know what happens if you try to present is a humidity sensor? Both humidity and soil is presented as % ??
                          Br
                            Hi @Bram81
                            MySensorsBase.cpp
                            Br
                            B
                            B
                            Bram81
                            Hi@sundberg84 Yes, that's me.. ;-) I saw that file too, but being still a newbie in Mysensors, Arduino and sketches I didn't really know how to use it. Do I have to put in my libraries folder and add a line #include <filename> in the gateway sketch..?
                            Right now the sensor is automatically seen as a certain device, within Domoticz there is no way to present it otherwise right?
                            • sundberg84S
                              sundberg84S
                              If you mean MySensorsBase.cpp - no thats the domoticz scourscode and you dont use that in the sensor/gateway.
                              Looking closer at the code shows also your sensors sends V_TRIPPED to domoticz, and thats why you get on/off.
                              I dont know it this works, but i would try to change:
                              to
                              MyMessage msg(CHILD_ID, V_HUM);
                              and
                              to
                              gw.present(CHILD_ID, S_HUM);
                              and upload the scetch to the Moisture sensor again...
                              It will present the sensor in domoticz as a Humidity sensor but as I said i hope both Moisture and Humidity presents its value from 0-100 %
                              Br
                              • B
                                B
                                Bram81
                                Hey, thanks for your help. The sensor presents itself as a Humidity sensor and shows a value of 1% even after adding water to the ground nothing changes, so it seems it's not being updated correctly.
                                Last week when I was just playing around for the first time with the arduino and sensor used this simple sketch:
                                int sensorPin = A0; // select the input pin for the potentiometer
                                int sensorValue = 0; // variable to store the value coming from the sensor
                                // declare the ledPin as an OUTPUT:
                                Serial.begin(9600);
                                // read the value from the sensor:
                                sensorValue = analogRead(sensorPin);
                                delay(1000);
                                Serial.print("sensor = " );
                                Serial.println(sensorValue);
                                Using the analog output on the sensor and analog0 on the arduino. The values are presented in number between 1-1200 (aprox.)
                                Even readings in just a number would be fine for me / can be easily transered to a % I guess, where a value of aprox 300 is liquid water and 1050 is the value read when the sensor is in the open air and not sticked in the soil.
                                Can you think of alike types of sensors with values presented in that range?
                                • sundberg84S
                                  sundberg84S
                                  Hi @Bram81
                                  Yes - the analog is 0 - 1023 and many use it to measure battery %.
                                  This can be converted to % pretty much by dividing it by 10 i think
                                  int sensorValue = analogRead(sensorPin);
                                  sensorValue  = sensorValue / 10;
                                  You can do much more with upper and lower limits... its just a matter of math and code.
                                  Edit:
                                  This is used in the battery when we want figures from 1.9 (VMIN)-3.3V (VMAX)... maybe it can help you somhow:
                                  int Pcnt = static_cast<int>(((Vbat-VMIN)/(VMAX-VMIN))*100.);```
                                  • sundberg84S
                                    sundberg84S
                                    Doing some fast math here: Vbat = your analog read value (say 500 as example), VMIN = 300 VMAX = 1023 gives us
                                    500 - 300 / 1023-300 = 200/ 723 = 0,27 = 27%
                                      B
                                      B
                                      Bram81
                                      @sundberg84 Hi, I've been trying to modify the sketch
                                      But it gives me errors I cant resolve... Got to a point where the node send back info to the gateway:
                                      683
                                      send: 3-3-0-0 s=0,c=1,t=1,pt=2,l=2,st=ok:0
                                      682
                                      683
                                      682
                                      Also Domoticz was receiving info, log showed :+1:
                                      2015-07-02 10:31:24.898 (Gateway) Temp + Humidity (TempHum)
                                      2015-07-02 10:31:24.914 (Gateway) Temp + Humidity (TempHum)
                                      2015-07-02 10:31:24.929 (Gateway) Temp + Humidity (TempHum)
                                      2015-07-02 10:31:24.944 (Gateway) Temp + Humidity (TempHum)
                                      2015-07-02 10:31:24.959 (Gateway) Temp + Humidity (TempHum)
                                      2015-07-02 10:31:24.975 (Gateway) Temp + Humidity (TempHum)
                                      2015-07-02 10:31:24.990 (Gateway) Temp + Humidity (TempHum)
                                      2015-07-02 10:31:25.005 (Gateway) Temp + Humidity (TempHum)
                                      But still the humidity switch was showing either 0% or 1%.
                                      I guess that is propably because the values must be transfered into % in the sketch, but I am kind of stuck...
                                      • sundberg84S
                                        sundberg84S
                                        #21
                                        @Bram81
                                        I would try (not at home and cant try):
                                        int Analog_Input_Soil_Sensor= A0;
                                        int Analog_Input_Soil_Sensor = 0;
                                        as you wrote before, and not #define interrupt analog_input_soil_sensor -2
                                        Also you get only 0 and 1 because this is what you send to the gateway: gw.send(Msg.set(soilva... 0?1:0)
                                        Either you have to define what 0 and 1 is (say dry = 0 moist = 1) or if you want to send it as % use another gw.send code.
                                        • sundberg84S
                                          sundberg84S
                                          #22
                                          Here is an example of someone build a soil sensor using the light_sensor
                                          http://forum.mysensors.org/topic/1492/soil-moisture-analog-input-question
                                          If you remove the battery code this could be used if you connect to analog pin (Se code below)
                                          #define CHILD_ID_LIGHT 0
                                          #define LIGHT_SENSOR_ANALOG_PIN 1
                                          int lastLightLevel;
                                          gw.begin();
                                          gw.sendSketchInfo("Soil_Moist_Sensor_grb", "1.15");
                                          int lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
                                          Serial.println(lightLevel);
                                          gw.send(msg.set(lightLevel));
                                          lastLightLevel = lightLevel;
                                          if you want lightlevel in % with a Min and a Max then:
                                          #define MIN 300  // Liquid
                                          #define MAX 1023 // Air
                                          int lastLightLevel;
                                          gw.begin();
                                          int lightLevel = static_cast<int>(((analogRead(LIGHT_SENSOR_ANALOG_PIN)-MIN)/(MAX-MIN))*100.);
                                          I have read some more...
                                          About the digital pin and use (as you mentioned at first... )
                                          It looks like there is a switch/nob on the hardware you can turn.
                                          This will set the trigger point between dry and moist and send 1 or 0.
                                          I think thats why the scetches was using S_Motion... either its dry (untriggered) or wet (triggered).
                                          I dont know how to program or wire this though...
                                          Best of luck :) Hope i didnt just complicate things...
