  3. Door, Motion and Temperature Sensor
63 Posts 11 Posters 50.4k Views 4 Watching
    @robosensor
    Thanks and congrats! You've made your first contribution to the MySensors project. :)
    • CaptainZapC
      CaptainZapC
      CaptainZap
      wrote on last edited by CaptainZap
      #29
      Guys, I had some free time tonight and tried to apply this fix... I ended up re-installing the arduino IDE + downloading the latest version, which now is 1.4.1 as opposed to the 1.4 that I used to have ?
      Anyways I had to upgrade my ethernet gateway (ENC28J60) and it's no longer working now... any hints will be golden.
      LE: I was too tired to check the sketch... I forgot to include the correct library and went to all debugging first, reset router config to default, but in the end I did notice the issue :) So I learned a valuable lesson, never work on this if it's late or you're tired.
      • CaptainZapC
        CaptainZapC
        CaptainZap
        #30
        Hello guys,
        I really need an expert's opinion on this because I'm experiencing some trouble... I've tried to include suggestions from all you guys, except the delay part, but so far it works partially... in my original code the temperature worked, and now it doesn't. The rest works ok, sensor and motion, so I would be grateful if anyone could take a look at my code and help me with it... I kind of need to get it in place soon, as I intend to leave my house for some time.
        Thank you.
        //This sketch is for Door & Motion & Temp Sensor
        #include <OneWire.h>
        #define CLIENT_ID AUTO  // Sets MYSensors client id
        #define RADIO_CH 76  // Sets MYSensors to use Radio Channel
        #define TRIGGER	3	// used to connect motion sensor
        #define BUTTON_PIN  4 // used to connect door/window sensor
        //Temp Sensor bits
        #define ONE_WIRE_BUS 14 // Pin where dallas sensor is connected
        DallasTemperature DallasSensors(&oneWire);
        float lastTemperature ;
        #define CHILD_ID_T1 3 //CHILD ID for temp
        //Door/Window bits
        #define CHILD_ID_D1 1 //CHILD ID for door/window
        //Trigger Sensor Bits
        #define CHILD_ID_S1 2 //CHILD ID for Motion sensor
        boolean lastTripped = 0;
        Bounce debouncer = Bounce();
        int oldValue=-1;
        MyMessage msg(CHILD_ID_D1,V_TRIPPED);
        MyMessage triggerMsg(CHILD_ID_S1,V_TRIPPED);
        MyMessage tempMsg(CHILD_ID_T1,V_TEMP);
        	// Startup OneWire Temp Sensors
            DallasSensors.begin();
            DallasSensors.setWaitForConversion(false);
        	 gw.begin(NULL, AUTO, true);
        	gw.sendSketchInfo("Multi Sensor", "1.1");
        	gw.present(CHILD_ID_D1, S_DOOR);
        	gw.present(CHILD_ID_T1, S_TEMP);
        	gw.present(CHILD_ID_S1, S_MOTION);
        	// Setup the button
                pinMode(BUTTON_PIN,INPUT);
                // Activate internal pull-up
                debouncer.attach(BUTTON_PIN);
                debouncer.interval(5);
        	// Check for motion change value
        		boolean tripped = digitalRead(TRIGGER) == HIGH;
        		if (lastTripped != tripped ) {
        			gw.send(triggerMsg.set(tripped?"1":"0")); // Send new state and request ack back
        			Serial.println("Tripped");
        			lastTripped=tripped;
                        debouncer.update();
                      // Get the update value
                        int value = debouncer.read();
                        if (value != oldValue) {
                            // Send in the new value
                             oldValue = value;
            DallasSensors.requestTemperatures(); // no delay here
            gw.wait(750); // insert another value for non-12-bit resolution
            float tempC = DallasSensors.getTempCByIndex(1);
            if (lastTemperature != tempC && tempC != -127.00) {
              gw.send(tempMsg.set(tempC,1));
              lastTemperature=tempC;
        • BulldogLowellB
          BulldogLowellB
          BulldogLowell
          @CaptainZap
          what does the Serial output show during execution of the sketch?
          • CaptainZapC
            CaptainZapC
            CaptainZap
            @BulldogLowell Unfortunately I don't have a way to test that yet... I'm uploading the sketch using an arduino uno, and I have no idea how to do that with it. I do have an FTDI serial adapter but is not picked up by the IDE, it was at some point but no longer... probably fake :|
            • m26872M
              m26872M
              m26872
              I don't know what's the issue, but I'd still prefer a normal timing code instead of just the gw.wait(). The fetching of temperatures in every loop makes no sense to me.
              CaptainZapC 1 Reply Last reply
              • m26872M m26872
                CaptainZapC
                CaptainZapC
                CaptainZap
                @m26872 If you have time, could you please tell me how to do that, I know you've posted a link a few post back but I didn't do much with it :(
                R 1 Reply Last reply
                • CaptainZapC CaptainZap
                  R
                  R
                  robosensor
                  wrote on last edited by robosensor
                  #35
                  @CaptainZap You should not query dallas sensor temperature every 750 ms. This heats up sensor itself and quite useless.
                  Use something like this:
                  unsigned long SLEEP_TIME = 30000; // Sleep time between reports (in milliseconds)
                  unsigned long lastRefreshTime = 0;
                  	gw.wait(100);
                  	boolean bNeedRefresh = (millis() - lastRefreshTime) > SLEEP_TIME;
                  	if (bNeedRefresh)
                  		lastRefreshTime = millis();
                  		gw.wait(750);
                  		float difference = lastTemperature - tempC;
                  		if (tempC != -127.00 && abs(difference) > 0.5)
                  			gw.send(tempMsg.set(tempC, 1));
                  			lastTemperature = tempC;
                  • R robosensor
                    	gw.wait(100);
                    	if (bNeedRefresh)
                    		gw.wait(750);
                    CaptainZapC
                    CaptainZapC
                    CaptainZap
                    @robosensor Thanks so much, I highly appreciate your comments. Will test this tomorrow, and hopefully, soon share my hardware designs :D
                    • CaptainZapC
                      CaptainZapC
                      CaptainZap
                      #37
                      Just uploaded the new sketch to my nodes, one built on a pro mini, and one built on a nano (got one to view serial output), however both nodes have the same behavior when added to the Vera unit... the repeater node doesn't show up (is this somehow related to UI7 ?), and the weird thing is that temperature value is never populated.
                      Regarding the repeater, looking into the user_data output I can see that a repeater node is created, but it's not used as a parent device for the sensors... as all sensors have as parent the gateway. I'm using this version of the plugin :
                      This is the serial monitor output from the nano :
                      repeater started, id 13
                      send: 13-13-1-0 s=255,c=0,t=18,pt=0,l=5,st=ok:1.4.1
                      send: 13-13-1-0 s=255,c=3,t=6,pt=1,l=1,st=ok:1
                      send: 13-13-1-0 s=255,c=3,t=11,pt=0,l=12,st=ok:Multi Sensor
                      send: 13-13-1-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.1
                      send: 13-13-1-0 s=1,c=0,t=0,pt=0,l=0,st=ok:
                      send: 13-13-1-0 s=3,c=0,t=6,pt=0,l=0,st=ok:
                      send: 13-13-1-0 s=2,c=0,t=1,pt=0,l=0,st=ok:
                      send: 13-13-1-0 s=1,c=1,t=16,pt=2,l=2,st=ok:0
                      This is the updated sketch:
                      //rev3 - changed temp pin to 5 & temperature logic re-worked
                      //Temp Sensor bits
                      #define ONE_WIRE_BUS 5 // Pin where dallas sensor is connected - on Rboard this is A0(D14)
                      //Door/Window bits
                      int oldValue=-1;
                      	// Setup the button
                                      debouncer.update();
                                           oldValue = value;
                          gw.wait(100);
                          if (bNeedRefresh)
                              gw.wait(750);
                      Any feedback will be appreciated. Thanks.
                        All devices has the gateway as parent (Vera does not support a multi-level device hierarchy).
                        • CaptainZapC
                          CaptainZapC
                          CaptainZap
                          Can anyone share their thoughts ? I've been running two identical nodes, with no temperature output for a few days now :(
                          DwaltD 1 Reply Last reply
                            DwaltD
                            DwaltD
                            Dwalt
                            @CaptainZap Did you delete the original devices from Vera after you changed the code? I had something similar happen when I rewrote a sketch to modify battery monitoring and Vera would not show the new data. I deleted the node and child devices and reincluded them from scratch and then it worked.
                            • m26872M
                              m26872M
                              m26872
                              I think you have to redo inclusion of the sensors if you want them to use the repater in their routing. At least it looks like this when I setup my Vera and sensors.
                              • CaptainZapC
                                CaptainZapC
                                CaptainZap
                                @Dwalt @m26872 Thanks for the feedback, I did do that on the Vera unit. I've even removed the plugin files and re-did everything. I even, and this is a bit extreme, cleared the eprom on the gateway and reflashed it. None of it worked, I really have no clue what to do next. I'm open to every suggestion :D
                                  DwaltD
                                  DwaltD
                                  Dwalt
                                  @CaptainZap It your sketch you have this line:
                                  What pin is your Dallas sensor connected to?
                                  • m26872M
                                    m26872M
                                    m26872
                                    First make sure a pure repeater node is working. With only the gw.process() to run, it should be fast to enough catch any new inlusion before the gateway. With a proper range of course. Clear the sensors eeprom and Vera-device before reinclusion, but you should not need to do anything with the gateway.
                                    • DwaltD Dwalt
                                      CaptainZapC
                                      CaptainZapC
                                      CaptainZap
                                      #45
                                      One sensor is connected to A0(14) the other is connected to D5 as it can be seen in my last sketch. Temperature reporting worked on, in my original sketch, however the sketch wasn't perfect so I improved it based on feedback.
                                      @m26872 The sensor is on a breadboard 5cm from the gateway, and I'm not sure about the repeater part...
                                      • CaptainZapC
                                        CaptainZapC
                                        CaptainZap
                                        Well since nobody knew what the problem is I thought I would re-flash my first sketch which was working properly... however after doing it it no longer works... this is blowing my mind away. I don't understand why that would be, as the only changes I've done are listed in this thread, major one was that I upgraded lib to 1.4.1 from 1.4. Anyone has any ideas cause this is driving me crazy now :(
                                          Moshe LivneM
                                          Moshe LivneM
                                          Moshe Livne
                                          @CaptainZap would suggest to clear the eeprom
