  3. Door, Motion and Temperature Sensor
63 Posts 11 Posters 50.4k Views 4 Watching
  • CaptainZapC
    CaptainZapC
    CaptainZap
    @BulldogLowell Unfortunately I don't have a way to test that yet... I'm uploading the sketch using an arduino uno, and I have no idea how to do that with it. I do have an FTDI serial adapter but is not picked up by the IDE, it was at some point but no longer... probably fake :|
    • m26872M
      m26872M
      m26872
      I don't know what's the issue, but I'd still prefer a normal timing code instead of just the gw.wait(). The fetching of temperatures in every loop makes no sense to me.
      CaptainZapC 1 Reply Last reply
      • m26872M m26872
        CaptainZapC
        CaptainZapC
        CaptainZap
        @m26872 If you have time, could you please tell me how to do that, I know you've posted a link a few post back but I didn't do much with it :(
        R 1 Reply Last reply
        • CaptainZapC CaptainZap
          R
          R
          robosensor
          wrote on last edited by robosensor
          #35
          @CaptainZap You should not query dallas sensor temperature every 750 ms. This heats up sensor itself and quite useless.
          Use something like this:
          unsigned long SLEEP_TIME = 30000; // Sleep time between reports (in milliseconds)
          unsigned long lastRefreshTime = 0;
          	gw.wait(100);
          	boolean bNeedRefresh = (millis() - lastRefreshTime) > SLEEP_TIME;
          	if (bNeedRefresh)
          		lastRefreshTime = millis();
          		DallasSensors.requestTemperatures();
          		gw.wait(750);
          		float tempC = DallasSensors.getTempCByIndex(1);
          		float difference = lastTemperature - tempC;
          		if (tempC != -127.00 && abs(difference) > 0.5)
          			gw.send(tempMsg.set(tempC, 1));
          			lastTemperature = tempC;
          • R robosensor
            	gw.wait(100);
            	if (bNeedRefresh)
            		gw.wait(750);
            CaptainZapC
            CaptainZapC
            CaptainZap
            @robosensor Thanks so much, I highly appreciate your comments. Will test this tomorrow, and hopefully, soon share my hardware designs :D
            • CaptainZapC
              CaptainZapC
              CaptainZap
              wrote on last edited by CaptainZap
              #37
              Just uploaded the new sketch to my nodes, one built on a pro mini, and one built on a nano (got one to view serial output), however both nodes have the same behavior when added to the Vera unit... the repeater node doesn't show up (is this somehow related to UI7 ?), and the weird thing is that temperature value is never populated.
              Regarding the repeater, looking into the user_data output I can see that a repeater node is created, but it's not used as a parent device for the sensors... as all sensors have as parent the gateway. I'm using this version of the plugin :
              This is the serial monitor output from the nano :
              repeater started, id 13
              send: 13-13-1-0 s=255,c=0,t=18,pt=0,l=5,st=ok:1.4.1
              send: 13-13-1-0 s=255,c=3,t=6,pt=1,l=1,st=ok:1
              send: 13-13-1-0 s=255,c=3,t=11,pt=0,l=12,st=ok:Multi Sensor
              send: 13-13-1-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.1
              send: 13-13-1-0 s=1,c=0,t=0,pt=0,l=0,st=ok:
              send: 13-13-1-0 s=3,c=0,t=6,pt=0,l=0,st=ok:
              send: 13-13-1-0 s=2,c=0,t=1,pt=0,l=0,st=ok:
              send: 13-13-1-0 s=1,c=1,t=16,pt=2,l=2,st=ok:0
              This is the updated sketch:
              //This sketch is for Door & Motion & Temp Sensor
              //rev3 - changed temp pin to 5 & temperature logic re-worked
              #include <OneWire.h>
              #define CLIENT_ID AUTO  // Sets MYSensors client id
              #define RADIO_CH 76  // Sets MYSensors to use Radio Channel
              #define TRIGGER	3	// used to connect motion sensor
              #define BUTTON_PIN  4 // used to connect door/window sensor
              //Temp Sensor bits
              #define ONE_WIRE_BUS 5 // Pin where dallas sensor is connected - on Rboard this is A0(D14)
              DallasTemperature DallasSensors(&oneWire);
              float lastTemperature ;
              #define CHILD_ID_T1 3 //CHILD ID for temp
              //Door/Window bits
              #define CHILD_ID_D1 1 //CHILD ID for door/window
              //Trigger Sensor Bits
              #define CHILD_ID_S1 2 //CHILD ID for Motion sensor
              boolean lastTripped = 0;
              Bounce debouncer = Bounce();
              int oldValue=-1;
              MyMessage msg(CHILD_ID_D1,V_TRIPPED);
              MyMessage triggerMsg(CHILD_ID_S1,V_TRIPPED);
              MyMessage tempMsg(CHILD_ID_T1,V_TEMP);
              	// Startup OneWire Temp Sensors
                  DallasSensors.begin();
                  DallasSensors.setWaitForConversion(false);
              	 gw.begin(NULL, AUTO, true);
              	gw.sendSketchInfo("Multi Sensor", "1.1");
              	gw.present(CHILD_ID_D1, S_DOOR);
              	gw.present(CHILD_ID_T1, S_TEMP);
              	gw.present(CHILD_ID_S1, S_MOTION);
              	// Setup the button
                      pinMode(BUTTON_PIN,INPUT);
                      // Activate internal pull-up
                      debouncer.attach(BUTTON_PIN);
                      debouncer.interval(5);
              	// Check for motion change value
              		boolean tripped = digitalRead(TRIGGER) == HIGH;
              		if (lastTripped != tripped ) {
              			gw.send(triggerMsg.set(tripped?"1":"0")); // Send new state and request ack back
              			Serial.println("Tripped");
              			lastTripped=tripped;
                              debouncer.update();
                            // Get the update value
                              int value = debouncer.read();
                              if (value != oldValue) {
                                  // Send in the new value
                                   oldValue = value;
                  gw.wait(100);
                  if (bNeedRefresh)
                      gw.wait(750);
              Any feedback will be appreciated. Thanks.
                All devices has the gateway as parent (Vera does not support a multi-level device hierarchy).
                • CaptainZapC
                  CaptainZapC
                  CaptainZap
                  Can anyone share their thoughts ? I've been running two identical nodes, with no temperature output for a few days now :(
                  DwaltD 1 Reply Last reply
                    DwaltD
                    DwaltD
                    Dwalt
                    @CaptainZap Did you delete the original devices from Vera after you changed the code? I had something similar happen when I rewrote a sketch to modify battery monitoring and Vera would not show the new data. I deleted the node and child devices and reincluded them from scratch and then it worked.
                    • m26872M
                      m26872M
                      m26872
                      I think you have to redo inclusion of the sensors if you want them to use the repater in their routing. At least it looks like this when I setup my Vera and sensors.
                      • CaptainZapC
                        CaptainZapC
                        CaptainZap
                        @Dwalt @m26872 Thanks for the feedback, I did do that on the Vera unit. I've even removed the plugin files and re-did everything. I even, and this is a bit extreme, cleared the eprom on the gateway and reflashed it. None of it worked, I really have no clue what to do next. I'm open to every suggestion :D
                          DwaltD
                          DwaltD
                          Dwalt
                          @CaptainZap It your sketch you have this line:
                          #define ONE_WIRE_BUS 14
                          What pin is your Dallas sensor connected to?
                          • m26872M
                            m26872M
                            m26872
                            First make sure a pure repeater node is working. With only the gw.process() to run, it should be fast to enough catch any new inlusion before the gateway. With a proper range of course. Clear the sensors eeprom and Vera-device before reinclusion, but you should not need to do anything with the gateway.
                            • DwaltD Dwalt
                              CaptainZapC
                              CaptainZapC
                              CaptainZap
                              #45
                              One sensor is connected to A0(14) the other is connected to D5 as it can be seen in my last sketch. Temperature reporting worked on, in my original sketch, however the sketch wasn't perfect so I improved it based on feedback.
                              @m26872 The sensor is on a breadboard 5cm from the gateway, and I'm not sure about the repeater part...
                              • CaptainZapC
                                CaptainZapC
                                CaptainZap
                                Well since nobody knew what the problem is I thought I would re-flash my first sketch which was working properly... however after doing it it no longer works... this is blowing my mind away. I don't understand why that would be, as the only changes I've done are listed in this thread, major one was that I upgraded lib to 1.4.1 from 1.4. Anyone has any ideas cause this is driving me crazy now :(
                                  Moshe LivneM
                                  Moshe LivneM
                                  Moshe Livne
                                  @CaptainZap would suggest to clear the eeprom
                                  • m26872M
                                    m26872M
                                    m26872
                                    Did you ever get a repeater-only node to work in your mys network ?
                                    • CaptainZapC
                                      CaptainZapC
                                      CaptainZap
                                      @Moshe-Livne @m26872 : I did clear the eprom, I've tried everything I could think of... I'm not quite sure if the repeater works, so far everything is at the breadboard state, so I was pretty much prototyping.
                                        @AWI Yes I want all my nodes to be repeaters, and that's exactly what I want to do :) However I use a Vera as my controller, and there you are supposed to have a parent node for your arduino sensor, followed by child devices for sensors/relays etc. Right now I have 3 child devices for the My Sensors plugin which isn't right.
                                        m26872M
                                        m26872M
                                        m26872
                                        Why?
                                        Unless you plan expand your network in the near future, think the increased complexity just will give you trouble.
                                          Moshe LivneM
                                          Moshe LivneM
                                          Moshe Livne
                                          @CaptainZap did you clear the eeprom before loading the sketch that used to work?
