  3. Safe In-Wall AC to DC Transformers??
431 Posts 71 Posters 595.0k Views 69 Watching
  • Moshe LivneM Moshe Livne
    @tbowmo @petewill @didi @ServiceXp I think I found the perfect one!!!!
    http://www.jameco.com/webapp/wcs/stores/servlet/Product_10001_10001_2155823_-1
    http://www.mouser.com/ds/2/260/GS05U-USB-spec-33533.pdf
    it is made by meanwell, so not flimsy. has all protections. 8$ at jameco and mouser and I am sure my meanwell supplier on aliexpress can get it for me at half price... it is a shame that they do not sell the inside separately but nothing is perfect.
    the only problem might be breaking it apart. Meanwell really make sturdy enclosures.
    let me know what you think...
    RJ_MakeR
    RJ_MakeR
    RJ_Make
    I think that one would be a good candidate for some testing.
    RJ_Make
    RJ_MakeR 1 Reply Last reply
    • petewillP
      petewillP
      petewill
      @Moshe-Livne @ServiceXp Cool, thanks! By testing, what sort of testing could I do to know it's safe? Also, would I be able to open it up or would I need to keep in in the packaging?
      My ultimate goal is to make a in wall switch similar to what I did with the "smart plug" (https://youtu.be/oNpMDN4QqD8). Do you see any other potential problems with putting those electronics in a wall? I want to make sure I don't do anything stupid before I attempt any of this...
      I am planning on using relays like this: http://www.ebay.com/itm/261099571172?rmvSB=true
      I would be powering lights so I shouldn't be anywhere near the 10A limit on these relays.
      Thanks for all the help!
      DidiD 1 Reply Last reply
      • petewillP petewill
        DidiD
        DidiD
        Didi
        I have ordered 5 of them and i will test them at full 600 ma for 4 weeks in a flush box and protocoll data.I think if they don´t smoke we can use them on pcb
        RJ_MakeR Moshe LivneM 2 Replies Last reply
        • RJ_MakeR RJ_Make
          RJ_MakeR
          RJ_MakeR
          RJ_Make
          @ServiceXp
          Testing as in:
          Ripple / Noise (if you don't have a scope just make sure the sensor does lock up on long run times at max load.)
          Measure the heat it generates during full load (find something that can draw 1 amp).
          Check to see if you can even fit it and the other components inside of a box that already has wire/switch run to it.
          Personally, I would want to crack one of these open and see how it was designed. Making sure it's Ok, the specs look good on it, but you never know....
          If the testing looks good, I would not have a problem using it (I would try and keep it in it's case if at all possible, or have one made that will house everything). I do think you are going to need a pretty deep box to fit it all.
          We really need a MySensors Micro solution here, but then there is the liability.....
          RJ_Make
          • DidiD Didi
            RJ_MakeR
            RJ_MakeR
            RJ_Make
            @Didi Would you mind pushing one to 1 amp for a while., and then 1.5 if possible. Just want to make sure the OCP activates before it goes up in smoke..
            RJ_Make
            • DidiD Didi
              Moshe LivneM
              Moshe LivneM
              Moshe Livne
              @Didi Would you mind testing the meanwell ones as well? I would have but being on a small island at the end of the world is a problem sometimes. Don't mind buying a few for you for testing - I really would like to have both a reliable wall charger and a power supply I could use in a box without too much worry and the meanwell looks so promising....
                petewillP
                petewillP
                petewill
                Do you have a link for this? I just tried searching and I couldn't find these one ebay or aliexpress.
                • rvendrameR
                  rvendrameR
                  rvendrame
                  Adding my two cents, I have dissected two devices (one zwave from GE and one unbranded, non zwave) and both used a capacitor-resistor power supply.
                  Very dangerous, as it is "transformerless" --- In other hand, cheap and small footprint. By using X2 capacitors the risk is a bit lower. It is in my list for prototype/testing over next weeks.
                  ESP8266 GW + mySensors 2.3.2
                  Alexa / Google Home
                  petewillP Moshe LivneM 2 Replies Last reply
                  • sundberg84S
                    sundberg84S
                    @rvendrame So did i on a 433mhz relay sold quite common here... it looked as this capacitor-resistor power supply as well.
                    • rvendrameR rvendrame
                      petewillP
                      petewillP
                      petewill
                      Interesting. Thanks for posting. I have very limited knowledge in this area so I'm learning a lot. I'm excited to get a good solution for this. It will be very useful for many things.
                        Moshe LivneM
                        Moshe LivneM
                        Moshe Livne
                        wrote on last edited by Moshe Livne
                        #50
                        @rvendrame very interesting. The link mention only 100ma at most but I guess that they are using SSRs so don't face the problems we have with our relays. I wonder why there is no "off the shelf" unit like that. I would be a bit scared to construct something like that.
                        • RJ_MakeR RJ_Make
                          @ServiceXp
                          Testing as in:
                          Moshe LivneM
                          Moshe LivneM
                          Moshe Livne
                          @ServiceXp @petewill @Didi here is another one! http://www.farnell.com/datasheets/606238.pdf
                          this one is reasonably smallish, has all the required protections. They are so well hidden....
                            DidiD
                            DidiD
                            Didi
                            And pice is ok
                            Found one at ebay:
                            http://www.ebay.de/itm/5V-550mA-switching-power-supply-module-MYRRA-47122-PCB-mount-/301663807573?pt=LH_DefaultDomain_3&hash=item463c906855
                            • rvendrameR
                              rvendrameR
                              rvendrame
                              @Moshe-Livne , I believe there is no off the shell as if you dig in the details, you will see that the impedance of the consuming circuit ( arduino + radio + relay in our case) direct influence the overall performance of the capacitor/resistor model.
                              Usually triacs consume less than relay (something between 10 and 50mA), and you can also control the bright of a light or speed of a motor, instead just turn them on or off.
                              The downside, you need a snubber circuit as well as a zero-cross detection circuit. The snubber is also recomended for relays, though.
                              So at the end you don't reduce the footprint or costs --- But triacs tend to last longer than relays, as no mechanical commutation occurs.
                              Alexa / Google Home
                              DrJeffD 1 Reply Last reply
                                DrJeffD
                                DrJeffD
                                DrJeff
                                @rvendrame I'm right with you on all of this have been trying to do this for a couple months with no time right now. Actually it has been longer I was originally building all this for another system using XBees and then found it better to use esp8266 then said better yet use Mysensors so here we are! Transformer less is key at least I think so! Only problem no off the self builds.
                                  I found an application notes from enocean regarding power supplies design. I think it could be helpful, and good to remember, so I share the link.
                                  http://www.enocean.com/fileadmin/redaktion/pdf/app_notes/AN101_POWER_SUPPLY_LAYOUT_2015.pdf
                                  • rvendrameR
                                    rvendrameR
                                    rvendrame
                                    I'm currently studying this doc STEVAL-ILL004V1 AN2263 AppNote .pdf. I should prototype something over next week if family allows.
                                    Alexa / Google Home
                                      Hi. interesting link, I will read it when I will have time. It looks like u2008 or u2010 which are obsolete now (I have some in stock, cheap on aliexpress) but I didn't know your ref. thanks
                                      • rvendrameR
                                        rvendrameR
                                        rvendrame
                                        @scalz, I'm trying to porting the capacitor-resistor power supply concept from that doc to our mySensor world. Specially for 1-wire dimmer, as described in chapter 3.1.
                                        Alexa / Google Home
                                          #59
                                          @rvendrame : I tried something similar once. I didn't remember exactly how all was connected but with triac, in one wire, even if I was not toggling anything, I had brown reset at start (maybe I could find my schem). With two wire, I had no problem but a little flickering (zero cross detection done by arduino). Maybe it was that which restarted. Next, I did another test with mosfet pwm, in one wire config again. This time, it started ok, and as I was increasing pwm it restarted for pwm = 170-200 (I don't remember exactly) .But I jumped onto another project I am finishing.
                                          I will follow your results with interest as your link is interesting , and at my home it is one wire too.
                                          12.5k
