  3. Safe In-Wall AC to DC Transformers??
431 Posts 71 Posters 595.0k Views 69 Watching
  • rvendrameR
    rvendrameR
    rvendrame
    @Moshe-Livne , I believe there is no off the shell as if you dig in the details, you will see that the impedance of the consuming circuit ( arduino + radio + relay in our case) direct influence the overall performance of the capacitor/resistor model.
    Usually triacs consume less than relay (something between 10 and 50mA), and you can also control the bright of a light or speed of a motor, instead just turn them on or off.
    The downside, you need a snubber circuit as well as a zero-cross detection circuit. The snubber is also recomended for relays, though.
    So at the end you don't reduce the footprint or costs --- But triacs tend to last longer than relays, as no mechanical commutation occurs.
    ESP8266 GW + mySensors 2.3.2
    Alexa / Google Home
    DrJeffD 1 Reply Last reply
    • rvendrameR rvendrame
      DrJeffD
      DrJeffD
      DrJeff
      @rvendrame I'm right with you on all of this have been trying to do this for a couple months with no time right now. Actually it has been longer I was originally building all this for another system using XBees and then found it better to use esp8266 then said better yet use Mysensors so here we are! Transformer less is key at least I think so! Only problem no off the self builds.
        I found an application notes from enocean regarding power supplies design. I think it could be helpful, and good to remember, so I share the link.
        http://www.enocean.com/fileadmin/redaktion/pdf/app_notes/AN101_POWER_SUPPLY_LAYOUT_2015.pdf
        • rvendrameR
          rvendrameR
          rvendrame
          I'm currently studying this doc STEVAL-ILL004V1 AN2263 AppNote .pdf. I should prototype something over next week if family allows.
          Alexa / Google Home
            Hi. interesting link, I will read it when I will have time. It looks like u2008 or u2010 which are obsolete now (I have some in stock, cheap on aliexpress) but I didn't know your ref. thanks
            • rvendrameR
              rvendrameR
              rvendrame
              @scalz, I'm trying to porting the capacitor-resistor power supply concept from that doc to our mySensor world. Specially for 1-wire dimmer, as described in chapter 3.1.
              Alexa / Google Home
                #59
                @rvendrame : I tried something similar once. I didn't remember exactly how all was connected but with triac, in one wire, even if I was not toggling anything, I had brown reset at start (maybe I could find my schem). With two wire, I had no problem but a little flickering (zero cross detection done by arduino). Maybe it was that which restarted. Next, I did another test with mosfet pwm, in one wire config again. This time, it started ok, and as I was increasing pwm it restarted for pwm = 170-200 (I don't remember exactly) .But I jumped onto another project I am finishing.
                I will follow your results with interest as your link is interesting , and at my home it is one wire too.
                • rvendrameR
                  rvendrameR
                  rvendrame
                  @scalz, with the 1-wire circuit , the maximum you can reach is like 80% - 90 % of light bright, as you need to keep the triac/mosfet "off" for a short period, in order to recharge the PSU capacitor. Maybe that explained why it re-started on your test at PWM 170-200. (and would also confirm that it works 'as designed', good to know)
                  Alexa / Google Home
                  • T
                    ThinkPad
                    I would be careful when stripping cheap USB-powersupplies and tucking them into a box in the wall. Read this page: http://www.lygte-info.dk/info/indexUSB UK.html and this page: http://www.lygte-info.dk/info/usbPowerSupplyTest UK.html to see how badly constructed some of these powersupplies are.
                    He also explains how he is testing those powersupplies: http://lygte-info.dk/info/usbPowerSupplyTestHow UK.html
                    Very informative i must say.
                    Moshe LivneM petewillP SparkmanS DidiD 4 Replies Last reply
                    • T ThinkPad
                      Moshe LivneM
                      Moshe LivneM
                      Moshe Livne
                      @ThinkPad Fascinating read.... If you read through the thread you will see that we actually go to the same conclusion. The meanwell charger should be good - they are respectable company and it has the 3 safeties we were looking for. It is not a very common charger - I have never seen it being sold before.
                      • T ThinkPad
                        petewillP
                        petewillP
                        petewill
                        @ThinkPad Thanks for posting. It's good to see how the tests are performed. Unfortunately I don't have the equipment or skill to know how to test. Hopefully we will be able to find a safe one that we can all use.
                        @Moshe-Livne have you been able to find the meanwell chargers from anywhere besides jameco?
                        YveauxY Moshe LivneM 2 Replies Last reply
                        • petewillP petewill
                          @petewill Mouser carries them, and also the european version (GS05E-USB). Please see here.
                          petewillP 1 Reply Last reply
                          • T ThinkPad
                            SparkmanS
                            SparkmanS
                            Sparkman
                            @ThinkPad Thanks for posting that. Great info there. Looks like you get what you pay for with the cheap power supplies.
                            Al
                            • T ThinkPad
                              DidiD
                              DidiD
                              Didi
                              Thanks for the information.The most powersupplies are horrible.
                              The engineers have developed them must go to jail.
                              Safety must be the major goal not the price.
                              • YveauxY Yveaux
                                petewillP
                                petewillP
                                petewill
                                @Yveaux Thanks. I was hoping there would be a cheaper way to get these. With shipping it's pretty pricey. Probably not as pricey as a fire though...
                                  Moshe LivneM
                                  Moshe LivneM
                                  Moshe Livne
                                  @petewill I have a supplier on ali that sells meanwell reasonably cheap. I used to buy all the power supplies for the LED lights I made from him. I will ask him for a quote. The downside is that he ships everything DHL.... still might be cheaper. where are you located?
                                  • Moshe LivneM Moshe Livne
                                    petewillP
                                    petewillP
                                    petewill
                                    @Moshe-Livne Ok, thanks! I live in Colorado, USA.
                                    • J
                                      J
                                      jemish
                                      so finally....plz...tell me which power supply is the best to put inside in the wall?
                                      I want required 5v for Relay, arduino mini, and radio.
                                        Moshe LivneM
                                        Moshe LivneM
                                        Moshe Livne
                                        @petewill My supplier is not selling these :-(
                                        apparently they are new
                                        @jemish It is still a work in progress. @didi will do some tests and we are trying to get some more for testing.
                                        Based on http://www.lygte-info.dk/info/indexUSB UK.html I would choose the apple one (http://lygte-info.dk/review/USBpower Apple USB power adapter UK.html)... But YMMV. I am not sure it has OTP
                                        • J jemish
                                          @jemish Be safe and buy something like: http://www.recom-international.com/pdf/Powerline-AC-DC/RAC03-SCR_277.pdf
                                          Live on the edge (having a decent fire insurance) and tear down a USB charger or buy one of the few $$ versions from China .
                                          J 1 Reply Last reply
                                          12.5k
