  3. We are mostly using fake nRF24L01+'s, but worse fakes are emerging.
47 Posts 17 Posters 68.1k Views 8 Watching
  • pit007P
    pit007P
    pit007
    wrote on last edited by pit007
    As I get my fakes I open a dispute and add this info - it war clear enough to get my money back ;-):
    So, the chips differ in the register number 09 (CD/RPD).
    • P
      P
      phil83
      wrote on last edited by phil83
      I just used the GettingStarted and got the following reply from a nrf24l01+ with antenna:
      RF24/examples/GettingStarted/
      ROLE: Pong back
      *** PRESS 'T' to begin transmitting to the other node
      STATUS = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
      RX_ADDR_P0-1 x00 = 0xe7e7e7e7e7 0xf0f0f0f0d2
      RX_ADDR_P2-5 x00 = 0xc3 0xc4 0xc5 0xc6
      TX_ADDR = 0xe7e7e7e7e7
      RX_PW_P0-6 x00 = 0x00 0x20 0x00 0x00 0x00 0x00
      EN_AA = 0x3f
      EN_RXADDR x00 = 0x03
      RF_CH = 0x4c
      RF_SETUP x00 = 0x07
      CONFIG = 0x0f
      DYNPD/FEATURE x00 = 0x00 0x00
      Data Rate = 1MBPS
      Model = nRF24L01+
      CRC Length = 16 bits
      PA Power = PA_HIGH
      So it's the same like @Magiske.
      • m26872M
        m26872M
        m26872
        Am I the only one missing references to earlier discussions in this subject? Like this one..
        • Pradeepa SenanayakeP
          Pradeepa Senanayake
          This is the first time I'm putting anything here. I also have been developing a C based library for one of the NRF24L01 (no plus) devices.. I used a Stellaris Launchpad to interface with the chip. Eventhough most of the functionality work correctly I saw the CD (Carrier Detect) is not functioning properly. Once it is high it is always high. To make it low I had to flush the RX buffer. It is really strange. I bought my sensors from e-Bay. So they must be clones :D. Can someone try this CD thing and see whether it is working properly?
            Has anyone here found a good vendor for modules that use genuine Nordic NRF24L01+ chips?
              You could buy your modules from Itead. They have promised us to only source genuine Nordic chips. They are a little higher in price/shipping but you could also take the opportunity to buy a MySensors Micro board to support the project :)
              The ebay/aliexpress shops is a bit of a chance-taking as they might switch sourcing partner at any time.
                Fair enough. I just now ordered some allegedly Itead NRF24L01+ modules from an Itead distributor, but I suppose there's a risk the distributor might get greedy and ship me something else. On a different thread, someone mentioned that the Itead modules each come in their own box. Would someone please post a photo of the individualized packaging for the Itead modles? If it's distinctive, it might serve as a kind of "certificate of authenticity." I realize that could be faked also, but it would make it a little harder for someone to fake, and so it's better than nothing.
                SparkmanS 1 Reply Last reply
                  Would the following might work as a way to separate good modules from bad modules, therefore also separate out the fakes?
                  1. Set up a looping ping-pong link between two "known good" modules and measure the % packet losses.
                  2. Unplug a reference module and then plug a test modules into the same setup. If the packet loss percentage is significantly worse, then the test module is either bad or a fake.
                    SparkmanS
                    SparkmanS
                    Sparkman
                    Here's an image:
                    http://imall.itead.cc/media/catalog/product/cache/1/image/1800x/040ec09b1e35df139433887a97daa66f/i/m/im120606002_2.jpg
                    Al
                    • SparkmanS Sparkman
                      Here's an image:
                      Al
                      #24
                      @Sparkman said:
                      Here's an image:
                      Al
                      Thanks! Pooling our information should reveal who the good vendors are.
                      After I receive the modules I ordered today, I'll post which vendor I purchased them from, the price, and whether or not I think they're real (i.e. what tests I ran to make that determination). I would encourage others to do the same.
                        Judging from the current banter on this other thread, it sounds as though if a module is powered directly from a fully charged battery pack (so that there's no voltage ripple) but it has fewer lost packets after installing a 10uF capacitor, then it's probably a fake.
                        I'm guessing you could make a test rig by soldering a capacitor across the Vcc and Ground legs of one of these:
                        Then just plug the module into it, and then it into the usual arduino socket that you'd ordinarily plug the module into.
                        Would that work?
                          Stric
                          I'm trying to get gc_supermarket to refund me or send working ones.. the nrf's I got from them, marked "GOOD QUALITY" has a range of a few meters in open space. Cap adds another meter or so.
                          I've ordered nrf's from itead too, hopefully good ones.
                          • sundberg84S
                            sundberg84S
                            Explaining to a electronic newbie, how do I test them?
                            All i can do now is prette much see if they work or not within my house.
                            I would be good if someone could create a little how-to so all can participate in these test.
                            Regards
                            Andreas
                            • sundberg84S sundberg84
                              Regards
                              Andreas
                              #28
                              Regards
                              Andreas
                              So far, I've mainly compared packet loss rates (as well as packet roundtrip times) for different types of modules. I think both are important, but if I had to pick just one or the other, I would pick packet loss rates.
                              I'm defining packet loss rate as: (# lost packets) divided by (total packets sent)
                              Anyone have ideas/opinions/thoughts/suggestions/recommendations as to whether there are better discriminating metrics to measure?
                              In terms of test setup, it would be ideal if the two arduinos running the test were screwed down to their test locations so that they couldn't be budged, so that almost the only thing that can change when testing different NRF modules is which NRF module is plugged into it. That way the antenna orientation will hopefully be effectively the same, or at least as close to that as we can hope to get without using an anachoic chamber--something which probably no one here would have access to.
                              Daniel OliveiraD 1 Reply Last reply
                              • S Stric
                                #29
                                That sounds awful. Have you tried other channels and locations and power supplies to rule out heavy interference or noise? If none of that makes any difference, would you please post a photo? Perhaps someone will notice something distinctively different that we can then all use to hopefully avoid a similar disappointment.
                                Also, I suggest ordering a minimum of 3 modules (from whomever you order), rather than only two, just to rule out the chance possibility that a botched module is to blame. This is what I did on my most recent order. It wouldn't rule out the possibility of getting 2 botched modules in the same order, but the odds of that should be very small if only random luck is involved.
                                • sundberg84S
                                  sundberg84S
                                  I also ordered those "good quality" from gc_supermarket. I havent made any test yet but on the chip it says NRF M, 24L01+ 1429AF
                                  On my other radios it says 1242AF.
                                    #31
                                    It's a manufacturing date stamp. 29th week of 2014
                                    Don't know what AF stands for. Anyone know?
                                      Regards
                                      Andreas
                                      Daniel OliveiraD
                                      Daniel OliveiraD
                                      Daniel Oliveira
                                      Regards
                                      Andreas
                                      Hi @NeverDie,
                                      As mentioned in another thread I'm (slowly) re-writing the RFToy code to use the MySensor lybrary instead. By doing so I believe that we can do a direct relation between MySencor configs and performance. (It will take a while as I'm waiting for the sensors to test the code)
                                      Anyway I would like to make some question to better understand the tests being made and the scenarios.
                                      Here it goes:
                                      • Does the RFToy code have the ACK messages activated?
                                      • It is possible to detect when an ACK is received? (RFToy or MySensor libraries)
                                      • How was defined the timeout of 8 micro seconds?
                                      At the moment my concerns with the current code are:
                                      • The value used for timeout (above mentioned 8ms)
                                      • The measure of the RTT (Round trip time), by it's definition if the ACK messages are used the RTT should be the time difference between the first bit of the message sent and the first bit of the received ACK message
                                      • The payload used being the max allowed of 32bit for one packet, does it not overflow? does this cause problems? (need to test)
                                      • Is useless to compare if the received message is equal to the message sent as this (most probably) is handled by hardware (CRC check?)
                                      • Is there a way to be sure that there is enough time for the receiver node to switch between modes (receiving/transmitting)?
                                      Sorry for the long post and for the possible inaccuracy of my statements but this is my first contact with arduino so far, so I just hope to help and to learn with it.
                                      Regards
                                      MySensors rules my home :)
                                      Z NeverDieN 2 Replies Last reply
                                      • Daniel OliveiraD Daniel Oliveira
                                        Regards
                                        Andreas
                                        Hi @NeverDie,
                                        Here it goes:
                                        Regards
                                        Z
                                        Z
                                        Zeph
                                        When ACK/autoretry (ESB mode) is enabled, the transmit is not indicated as complete until an ACK is received or all retries are exhausted.
                                        People could define RTT in several ways for different purposes. You describe one way one could define it. For the most part tho people are going to measure the times between two events that are visible in the chip registers. So if you want the RTT for a message with an ACK (and no retries), you might measure the time from when the transmit is triggered, to the time that the chip considered it complete (ack received), which will be shortly after the last bit of the ACK is processed.
                                        Another way to define RTT would involve a software ACK at a higher network level being received - master uC sends to slave uC, slave parses and sends a new packet to the master uC. Again, it's going to tend to be measured via the visible registered (from transmit fired to packet received).
                                        The nRF24L01+ has a maximum payload of 32 bytes (a protocol layered on top of that, like MySensors, may have it's own smaller maximum payload at that level, after its own protocol overhead). Not sure what you are asking but maybe NeverDie will.
                                        If you are using hardware ACK, that switchover (primary transmitter into receive mode temporarily for receiving the ACK, primary receiver into transmit mode temporarily for sending the ack) is handled automatically, including the 130 uS or so needed to switch the radio. If you are using a software ACK, you would need appropriate delays and/or timeouts.
                                          Stric
                                          @NeverDie Yes, I've tried various things. The modules from gc_supermarket were crap. I ordered 10, so it's not an "oops, you got a bad one".
                                          1420JB.
                                          In the ebay shop, the module PCB had markings. The ones I got had none.
