  3. Safe In-Wall AC to DC Transformers??
431 Posts 71 Posters 590.5k Views 69 Watching
  • A
    Atomfire
    I have also bought the Hi-Link modules, 10 arrived today, they seem very well built, but I have yet to try them.
    • Q
      Q
      Qu3Uk
      I got some hi-link modules a while back on a "I might need these in the future" type deal.
      I was wondering though how to protect the connections. I got some fuses+pcb holders to add extra protection however there is going to be at least 4 points which will be exposed.
      Can I just cover the joints with hot glue to stop them from making contact with anything? Call me paranoid but I like to be extra safe.
      T J 2 Replies Last reply
      • Q Qu3Uk
        ThinkPad
        @Qu3Uk For covering solder connections you can use 'heatshrink'. Kind of 'plastic' tubes that you put around a wire, apply heat (keep a lighter/match underneath (not in the flame) for example) and it shrinks around the connection.
        See also https://en.wikipedia.org/wiki/Heat-shrink_tubing
        • Q Qu3Uk
          J
          J
          Jan Gatzke
          @Qu3Uk You could protect the high voltage part of the circuit by mounting a plastic plate under the pcb using some spacers and screws. This way it would be impossible to touch the dangerous spots. I would not recommend hot glue because you never know how well it isolates. I don't think you will find electrical specs for hot glue. ;)
          Q 1 Reply Last reply
          • J Jan Gatzke
            Q
            Q
            Qu3Uk
            @Jan-Gatzke Ah yeah that's probably a neater option as well I think. Sure I can find something suitable like that.
            I have heatshrink but I just figured it wouldn't 100% cover the solder joints on the PCB.
            Moshe LivneM 2 Replies Last reply
            • rvendrameR
              rvendrameR
              rvendrame
              @Qu3Uk , is a small plastic box a option? Maybe some 3D-printed, with some ventilation holes on two sides, as small as the PCB + components?
              ESP8266 GW + mySensors 2.3.2
              Alexa / Google Home
              • Q Qu3Uk
                Moshe LivneM
                Moshe LivneM
                Moshe Livne
                @Qu3Uk there is something called liquid tape. It's expensive.... Cool stuff though
                  @Moshe Livne. thank you for the trick. I didn't know this. it could be very useful sometimes.
                  • Q Qu3Uk
                    Moshe LivneM
                    Moshe LivneM
                    Moshe Livne
                    @Qu3Uk Also, worse comes to worse, use PU construction adhesive. very messy but they are rated for electrical conductivity and fire. if you ever want to take this off, you are in big trouble....
                    • rvendrameR rvendrame
                      Q
                      Q
                      Qu3Uk
                      @rvendrame Waiting on some boxes but I'm also wanting to protect the connections inside the box, figure it'll also be a little neater maybe.
                      • DidiD Didi
                        Powersupplies arrived :smiley:
                        Moshe LivneM
                        Moshe LivneM
                        Moshe Livne
                        @Didi Any initial results? curiosity is killing me....
                        DidiD 1 Reply Last reply
                        • Moshe LivneM Moshe Livne
                          DidiD
                          DidiD
                          Didi
                          Sorry Moshe no tests,i was in holidays with my kids
                          • DidiD Didi
                            Moshe LivneM
                            Moshe LivneM
                            Moshe Livne
                            @Didi :disappointed:
                            • B
                              B
                              Bertb
                              Last week I carried out an elektrical safety test on the HLK-PM01 to NEN 60101 (Dutch test for medical equipment) and it performed pretty well. I will try to post the file, after I removed some private information :-)
                              Furthermore I am building a automated load tester that relates variable loads to output voltages and surface temperatures, based on an Arduino Nano.
                              petewillP T 2 Replies Last reply
                              • B Bertb
                                petewillP
                                petewillP
                                petewill
                                @Bertb Great news! Looking forward to the results.
                                • DidiD
                                  DidiD
                                  Didi
                                  :+1:
                                  I can´t wait to see the results
                                  • B Bertb
                                    ThinkPad
                                    @Bertb Cool, always handy to have people like you on forums ;) I'm also looking forward to the results!
                                    • T
                                      ThinkPad
                                      Maybe the "Samsung ETAOU10EBE" phone charger is also an idea to use. I have one for my phone, and it is very small.
                                      I haven't opened it (i use it for my phone, dohhh), but the charger is small, so the PCB inside will be even smaller.
                                      It is 5V @ 700mA with a microUSB wire. I got a second one from eBay, which was being sold as 'genuine'. And to be honest, i really don't see any difference with the one that came with my phone. It is working fine for more than a year.
                                      • B
                                        B
                                        Bertb
                                        Well, here is the test file. I made it using test software named Ansur and a Fluke ESA640 tester in a Class II test setup.
                                        The only problem is that some test results are in Dutch.
                                        HLK-PM01 20150724 Fluke ESA620 IEC 60601-1 klasse 2.pdf
                                          For us none dutch talking people... Good or Bad? (Yes, I see the big PASSED text ;) )
