  3. Safe In-Wall AC to DC Transformers??
431 Posts 71 Posters 583.3k Views 69 Watching
    @Moshe Livne. thank you for the trick. I didn't know this. it could be very useful sometimes.
    • Q Qu3Uk
      @Jan-Gatzke Ah yeah that's probably a neater option as well I think. Sure I can find something suitable like that.
      I have heatshrink but I just figured it wouldn't 100% cover the solder joints on the PCB.
      Moshe LivneM
      Moshe LivneM
      Moshe Livne
      @Qu3Uk Also, worse comes to worse, use PU construction adhesive. very messy but they are rated for electrical conductivity and fire. if you ever want to take this off, you are in big trouble....
      • rvendrameR rvendrame
        @Qu3Uk , is a small plastic box a option? Maybe some 3D-printed, with some ventilation holes on two sides, as small as the PCB + components?
        Q
        Q
        Qu3Uk
        @rvendrame Waiting on some boxes but I'm also wanting to protect the connections inside the box, figure it'll also be a little neater maybe.
        • DidiD Didi
          Powersupplies arrived :smiley:
          Moshe LivneM
          Moshe LivneM
          Moshe Livne
          @Didi Any initial results? curiosity is killing me....
          DidiD 1 Reply Last reply
          • Moshe LivneM Moshe Livne
            DidiD
            DidiD
            Didi
            Sorry Moshe no tests,i was in holidays with my kids
            • DidiD Didi
              Moshe LivneM
              Moshe LivneM
              Moshe Livne
              @Didi :disappointed:
              • B
                B
                Bertb
                Last week I carried out an elektrical safety test on the HLK-PM01 to NEN 60101 (Dutch test for medical equipment) and it performed pretty well. I will try to post the file, after I removed some private information :-)
                Furthermore I am building a automated load tester that relates variable loads to output voltages and surface temperatures, based on an Arduino Nano.
                petewillP T 2 Replies Last reply
                • B Bertb
                  petewillP
                  petewillP
                  petewill
                  @Bertb Great news! Looking forward to the results.
                  • DidiD
                    DidiD
                    Didi
                    :+1:
                    I can´t wait to see the results
                    • B Bertb
                      ThinkPad
                      @Bertb Cool, always handy to have people like you on forums ;) I'm also looking forward to the results!
                      • T
                        ThinkPad
                        Maybe the "Samsung ETAOU10EBE" phone charger is also an idea to use. I have one for my phone, and it is very small.
                        I haven't opened it (i use it for my phone, dohhh), but the charger is small, so the PCB inside will be even smaller.
                        It is 5V @ 700mA with a microUSB wire. I got a second one from eBay, which was being sold as 'genuine'. And to be honest, i really don't see any difference with the one that came with my phone. It is working fine for more than a year.
                        • B
                          B
                          Bertb
                          Well, here is the test file. I made it using test software named Ansur and a Fluke ESA640 tester in a Class II test setup.
                          The only problem is that some test results are in Dutch.
                          HLK-PM01 20150724 Fluke ESA620 IEC 60601-1 klasse 2.pdf
                            For us none dutch talking people... Good or Bad? (Yes, I see the big PASSED text ;) )
                              @hek I'm Dutch but I also have troubles interpreting the results...
                              But hey, I'm a software guy!
                              • DidiD
                                DidiD
                                Didi
                                i guess fluke can set to eng,thanks @Bertb for the results,think you don´t make it at home
                                • B
                                  B
                                  Bertb
                                  Sorry for the language thing. I will try to get some tests in English in the future.
                                  The tester used is designed for tests of medical equipment and this specific test proves that this specific HLK was safe. The problem is, however, that it does not prove anything with respect to the safety of other HLK's.
                                  In the mean time, the same HLK is feeding a load of 730 mA. It's output voltage is 5.08 volts and the case temperature is Temp C: 46.81 Temp F: 116.26105.
                                  @Didi. You are correct. I work in a hospital. I will try to setup the Fluke to English.
                                  • B
                                    B
                                    Bertb
                                    Wait Mike, there is more ...
                                    I sacrificed a device to the altar of success and opened it.
                                    That was not very difficult. After scratching away some gum stuff the following was revealed.
                                    I will try to remove the rest of the gum with acetone. I will also do some heat and burn tests.
                                    This is quite funny to do :-)
                                    IMG_20150728_214007.jpg IMG_20150728_214057.jpg IMG_20150728_214105.jpg IMG_20150728_214436.jpg
                                    • B
                                      B
                                      Bertb
                                      And I found the AP8012 chip inside. It has the following features:
                                      _1286955514_oj99d4.pdf
                                      YveauxY Moshe LivneM 3 Replies Last reply
                                      • B Bertb
                                        @Bertb Thanks Bert! Good digging!
                                        • B Bertb
                                          Moshe LivneM
                                          Moshe LivneM
                                          Moshe Livne
                                          @Bertb thanks! Good detective work! It seems the chip provide all the protections needed. That is very encouraging
