  3. Is this enough to get me started?
12 Posts 7 Posters 4.5k Views 1 Watching
  • Daniel LindbergD Offline
    Daniel Lindberg
    So I've never ever been much into electronics before, however I do have a fair amount of programming experience. I've been looking to buy a couple of humidity sensors for my house, that is until I stumpled upon this site and started reading. Now I realize that I can probably build them myself, and have some fun while doing so :-)
    I've read all the getting started guides and watched a couple of videos, however I'm still not really sure exactly what I need to buy to build my sensors. As my first project I would like to build 2 battery powered humidity/temp sensors.
    This is what I think I need:
    For the sensors
    • 2x Sensebender Micro (seems like a good fit with build in temp/humidity sensors)
    • 2x NRF24L01 (Looks like minimum to buy is 10?)
    • 2x 3V AA Battery holder
    • 1x FTDI USB to TTL Serial Adapter
    Gateway (based on petewill's video)
    • 1x Arduino Nano Compatible
    • 1x NRF24L01
    • 1x 4.7 uf capacitor
    Controller
    • 1x Rasberry PI 2, probably with OpenHab
    I guess I need some cables as well (no idea how to solder...)
    Female - Female Dupont jumper cables.
    Can someone please tell me if this is it, or did am I missing something in my list?
    Also, is Rasberry PI 2 with OpenHab a reasonable choice?
    Moshe LivneM D 2 Replies Last reply
    • H Offline
      H Offline
      Yep, that should get you started.
      • Daniel LindbergD Daniel Lindberg
        For the sensors
        • 1x NRF24L01
        Controller
        Moshe LivneM Offline
        Moshe Livne
        @Daniel-Lindberg don't rush into choosing a controller - play with them (it is hard without sensors). What I am actually saying - you need to find the controller that match your needs and there is sometimes a gap between reality and web sites, so keep an open mind and don't get fixated. Other than that.... I would suggest the nrf with external antenna for the GW and some enclosures.... and cables!!!!
        • greglG Offline
          greglG Offline
          gregl
          I would suggest you buy from itead their iBoard for your gateway - since you are buying from there anyway.
          http://imall.itead.cc/im120410001.html
          Its pretty easy to get going as an Ethernet gateway - you do need to make some temporary changes to deploy the sketch, but I think its well worth it and a very robust tidy solution....NO WIRES needed!! ;-)
          Grab a http://imall.itead.cc/im120525005.html to program it with..
          As Moshe said...no need to rush into the controller, but what you are thinking with the RPi2 and OpenHab is a sound decision - very powerful and cheap to do.
          I have Vera, but I forsee my future on OpenHab.
            For the sensors
            • 1x NRF24L01
            Controller
            Dwalt
            wrote on last edited by Dwalt
            @Daniel-Lindberg If you go with the Sensebender, you will have to solder on the radio and power.
            Daniel LindbergD 1 Reply Last reply
            • D Dwalt
              Daniel Lindberg
              Oh... I don't wanna go there. So what would I replace the sensebenders with, given I need a humidity/temp sensor and battery power? Arduino Pro Mini 3,3V and a DHT11/22? Do I need an step up/down regulator as well?
                Daniel Lindberg
                wrote on last edited by Daniel Lindberg
                Looking at the shop, the battery holders have the description .
                "3V AA Battery holder
                For powering 3.3V Arduino. Requires a step-up converter"
                The only step up converter I find in the shop says
                "DC-DC Step Up Boost Module
                Input 1-3V , 5V Output. Use this if you need to power 5V sensors from a 3.3V Arduino Pro Mini". Is this what I need for the battery holder? (it doesnt sound like it, but it's all I can find)
                EDIT: Perhaps this is what I need? http://www.aliexpress.com/item/8-pcs-Ultra-small-DC-DC-0-8-3-3V-to-DC-3-3V-Step-UP/32268496143.html
                  T Offline
                  T Offline
                  TD22057
                  I read that the same as you and couldn't figure it out. So I bought 5V mini's for now and figured I'd need to do research before trying some battery powered sensors. I'm glad it wasn't just me that couldn't understand those docs. I found this board which sounds similar and explicitly states it's useful for powering a mini from batteries:
                  https://www.sparkfun.com/products/10967
                  • H Offline
                    H Offline
                    wrote on last edited by hek
                    @Daniel-Lindberg said:
                    DHT11
                    I think the DHT11/22 can run from the 3v3 rail.
                    Hmm.. There used to be two step-up modules in the "store" earlier (3v3 and 5v). I will have a look at it.
                    EDIT: This step-up module was listed:
                    http://www.ebay.com/itm/291352631612?rmvSB=true
                    But the 0.8->3v3 is missing.. Will fix.
                      T Offline
                      T Offline
                      tbowmo
                      With dht11/22 and arduino micro/nano you actually end up with more soldering. Also dht11/22 requires 3.3v (if I remember right) which means you have to throw an step up converter into the picture as well.
                      Think that the sensebender is the simplest to get going.
                        Daniel Lindberg
                        Oh well, I placed my order yesterday evening. Have a friend who can help with soldering. Bought some mini pro 3v3, which should be enough to power the dht22?
                          Moshe Livne
                          @Daniel-Lindberg go wire wrap! Its the future! :smile:
                          12.1k
