  3. Which are the *best* NRF24L01+ modules?
310 Posts 42 Posters 339.4k Views 37 Watching
  • Moshe LivneM Moshe Livne
    @NeverDie I do not use capacitors but I have noticed that the quality of the power supply is important but USB from a computer should have very little noise so that is not the reason.
    If you happen to have capacitors, would be interesting to see how they effect the results.
    @hek (or anyone else who knows what they are doing), as this seems to be a universal problem, why don't you start a github sketch with simple regression results that will evolve with time? we can also start a google drive spreadsheet to collect the results so we can record who we bought it from, include a photo and the results. Although the Chinese merchants can be fickle with they supply chain, at least on aliexpress you can verify beforehand with them that you are getting specific things and if you get something else you just don't pay. It is possible to establish good and reliable supply with them if they see that it brings them consistent returns and rating - I have done that with components for my LED lights. But we need a simple way of telling what we get....
    I'm thinking about a simple sketch, based of the nRF24 Sniffer's code, which connects two radios and checks on air how a radio communicates. This should allow detecting the inverted NO_ACK bit (see Jay Tyzzer's comment here) to immediately quilify a module as fake when detected.
    Of course this doesn't mean it's genuine when doesn't have the bit inverted, but the sketch could also dump register settings to be able to detect a pattern.
      Great pictures! What microscope are you using?
      I can't see anyone having the hole in the +-sign...
      This one. It's sold under various names/brands (e.g. Oitez e-scope).
      I really needed it to hand-solder those QFN's ;-)
        #40
        Yup, so they're all genuine... PROBABLY NOT!
        Ehhrrmmm fake probably...
        • YveauxY Yveaux
          Moshe LivneM
          Moshe LivneM
          Moshe Livne
          @Yveaux wonderful! Even if fake, ones with correct ack bit will probably work better so its a step in the right direction
          • YveauxY Yveaux
            An overview of the module I have lying around (origin is unclear, as I don't really keep track of where they come from)
            The chip close-ups were taken using a microscope, so they have far higher resolution then shown in the table (right-click & show image to view at native resolution) .
            Datecode YYWWLL Module top Module bottom Closeup Fake/Genuine
            0830AE 2015-07-27 18.59.21.jpg 2015-07-27 18.59.32.jpg 20150727_0005.jpg Genuine? Datecode 0830 indicates production wk30 2008. nRF24L01+ was launched in 2008
            1242AF 2015-07-27 18.53.12.jpg 2015-07-27 18.53.28.jpg 20150727_0006.jpg Known counterfeit, according to this
            1331AF 2015-07-27 18.56.26.jpg 2015-07-27 18.56.34.jpg 20150727_0008.jpg Known counterfeit, according to this
            1408AF 2015-07-27 18.54.33.jpg 2015-07-27 18.54.41.jpg 20150727_0002.jpg Probably fake (identical to left one bottom of the page
            FWIW, the 0830AE date code is only a little earlier (4 weeks?) than the 0834AF datecode on the chip above in Hek's post where Hek alleges the module is genuine.
            • YveauxY Yveaux
              How hard would it be to desolder a bogus NRF chip and then solder a known good NRF24L01+ (purchased either directly from Nordic, if Nordic does that, or else from a trusted distributor like Digikey) in its place? Perhaps in this way the modules can be given a second life of sorts.
                #44
                @Yveaux: Those are wonderful photos! Thanks so much for posting them. :smile: Did you use the microscope for the module shots also, or just the NRF chip closeups?
                Since you have a nice module collection that spans different NRF chips and also different module types, have you noticed whether any of your modules stand out head-and-shoulders above the others as having clearly better performance?
                • DwaltD
                  DwaltD
                  Dwalt
                  wrote on last edited by Dwalt
                  #45
                  Lol, I just checked all of my radios from Alice1101983 and they are all dated 1242AF - FAKES! I have 20 from two orders of 10 radios each placed about six months apart (10/14 & 4/15) and they all have the same production date. They do work but I have occasional and random node hangup. This is an ongoing problem which I have been unable to troubleshoot. @hek, we might want to change the vendor in the MySensors store.
                    #46
                    Here's a module that is itself surface mountable. It seems like roughly half the footprint of typical modules.
                    Anyone have suggestions on how best to cheaply hook it up to an arduino? Not sure, but the pin pitch might be 1.27mm. I do have arduino prototyping shields, and there do seem to be 7 pin areas meant for soldering on something with surface mount (see SOIC area in upper left below):
                    Unfortunately, there are only 7 pads on the SOIC that I can solder it to, and the ground pin is on the end, with the IRQ next to it.
                    Not ideal! Should I try soldering a wire to the ground pin but solder the rest of the pins to the SOIC pads on the prototyping board? Seems like that may be the cleanest way to do it.
                    That might be fine if using an Uno, but what about if using a pro mini? How best to connect it then? Anyone here already doing it?
                    As a ghetto method I could also run jumper pins through each through-hole and solder into place, and then run each wire to the proper pin on the pro mini and solder into place, but... not very elegant. Are there better ways I'm not aware of?
                      Anyone know by what method Nordic prints the lettering on the chips? In looking at Yveaux's CSI-like photos, from chip-to-chip all of the letters have some amount of black mixed in, but on some they seem to be gaps left by air bubbles (so you're seeing through paint gaps to the black background) from the lettering being sprayed on, and on others the black seems like black dust or or something that was sprinkled on top after the lettering was applied. So, if you look closely through a microscope, some differences do seem to emerge. Under magnification, the lettering on the 1331AF is visibly sloppy, almost as if printed by a professional cake decorator from your local bakery.
                      Anyone know what some of the other lettering is supposed to mean? e.g. M, AF, EV, CH, A, 0, CL, AE, DQ, FJ, or FY? On Hek's genuine chip, it seems blank after the NRF, whereas that's not true for any of the other chips.
                      • SparkmanS
                        SparkmanS
                        Sparkman
                        My "regular" modules were bought from gc_supermarket and the NRF chips all have the following printing. There is no circle in the center of the +.
                        NRF  T
                        24L01+
                        1420JB
                        My LNA/PA modules were bought from alice11011983 and the NRF chips have the following printing. There is a circle in the center of the + on the first set, but not the second set.
                        NRF  M
                        24L01+
                        1431FC
                        NRF  O
                        24L01+
                        1417GP
                        I'll try to grab some pics this weekend.
                        Al
                          #49
                          Update: I provided Itead with my contact information, and they will try to arrange for a Nordic FAE to contact me.
                          As there's no telling how long the above might take to resolve, I decided to roll the dice again and ordered three of these modules:
                          I hope to receive them by later in the week. I'm hopeful, but only slightly optimistic. If there's interest, I'll post closeups after I receive and test them.
                          I also ordered more blob modules, but from a different source than the two I already have, so who knows what I'll actually receive. If it turns out blob modules from different sources are all about the same, I might standardize on that and simply move on. The two that I have work well enough that I wouldn't mind doing that, though it may put me on a fork from the rest of you. My only reluctance is that we'd all be more productive if we can find some way to leverage a common platform, so that remains my preference (and hope) for the long-term.
                            Only the chips were shot using my microscope. The field of view is simply too small to shoot the whole module.
                            Only > Since you have a nice module collection that spans different NRF chips and also different module types, have you noticed whether any of your modules stand out head-and-shoulders above the others as having clearly better performance?
                            No, but I had troubles mixing different modules in the past (even the NO_ACKs were involved iirr), so I'm very interested to know which ones are genuine.
                            • YveauxY Yveaux
                              Yes, it's in the data sheet. The date code is in YYWWLL which stands for year & week of production, an LL indicates wafer lot. The top right code indicates the production location (first letter) followed by optional letter indicating engineering sample.
                              Nordic is fabless so only they know what the location letters mean.
                              The text is normally written using a laser scriber, so no ink is involved.
                              Thinking of it, differences in font/thickness etc. can be caused by different laser scribers at different production facilities (or even within one facility) so I'm starting to doubt if it will help us in distinguishing fakes from genuine.
                              • YveauxY Yveaux
                                Thanks for pointing that out. Looking at the version 1.0 spec sheet (available at http://www.nordicsemi.com/eng/Products/2.4GHz-RF/nRF24L01P), I see it covered in section 13.1 and 13.2.
                                Curiously, according to the spec sheet, the chips should be marked "nRF", not "NRF".
                                  Maybe they hoped the copycats would also copy this error, but unfortunately they didn't :facepunch:
                                  • SparkmanS Sparkman
                                    NRF  T
                                    24L01+
                                    1420JB
                                    NRF  M
                                    24L01+
                                    1431FC
                                    NRF  O
                                    24L01+
                                    1417GP
                                    Al
                                    NRF  T
                                    24L01+
                                    1420JB
                                    NRF  M
                                    24L01+
                                    1431FC
                                    NRF  O
                                    24L01+
                                    1417GP
                                    Al
                                    Hi Al,
                                    Funny that you happen to mention gc_supermarket, because just yesterday I was noticing that they had good pricing on blob modules. These visually resemble the two blob modules I have and which seem to perform quite well at 1mbps air datarate. Intriguingly, the listing title says "Power enhanced version Compatible NRF24L01" and in the description it says:
                                    "This module is design to solve the problem of small power in NRF24L01 module, its distance is far away than NRF24L01
                                    Please download the data in below link
                                    http://www.ai-thinker.com/forum.php?mod=viewthread&tid=411&extra=page%3D1 "
                                    It would be easy to dismiss this as gibberish or as a failed attempt at chinglish, except for the fact that my two blob modules do, in fact, seem to have much better range than any of the "regular" NRF24L01+ modules I've tried so far. So, whether deserved or not, that does seem to give gc_supermarket more credability in my eyes than a lot of other re-sellers. Also, whether by luck or intent, they referred to it as "NRF24L01", not "NRF24L01+", which is also closer to reality, as it doesn't support 250kbps. So, in my book they get some credibility points for that also.
                                    Have your transactions to date with gc_supermarket gone well?
                                    SparkmanS 1 Reply Last reply
                                      NRF  T
                                      24L01+
                                      1420JB
                                      NRF  M
                                      24L01+
                                      1431FC
                                      NRF  O
                                      24L01+
                                      1417GP
                                      Al
                                      Hi Al,
                                      SparkmanS
                                      SparkmanS
                                      Sparkman
                                      Overall yes. First shipment from them got lost, but they replaced the shipment right away without any argument and it showed up ok. The modules seem to be a good quality with nice soldering and the flux cleaned up properly. I haven't done any packet loss testing with them, but have had good range with them (@250kbps).
                                      Al
                                        #56
                                        Here's a link which lists chips similar to the NRF24L01+ (there are many more than I had supposed), and it also highlights some of their differences: http://sigrok.org/wiki/Protocol_decoder:Nrf24l01
                                        Especially useful is the mirror of the datasheets.
                                        I have a hunch that a simple way to differentiate among the various chips might be to measure the amount of current consumed in various modes (e.g. standby, powerdown, etc), because those numbers are also given in the datasheets. Anyone tried that?
                                          #57
                                          I just placed an order on Ali Express for four NRF24L01+ modules that look similar to the one Hek says is genuine: http://www.aliexpress.com/item/Free-shipping-Original-Genuine-NRF24L01-Wireless-Module-2-4G-wireless-communication-module-2-54mm-Interface-2/1781618813.html I mainly picked this seller because he will be sending by ePacket for only 4 cents extra, and that should mean much faster delivery (5 to 15 days). Also, the seller has decent feedback and is promising that the chips are "original" and "genuine." So, with shipping, the modules will be costing me an average of $2.82 each. I hope they're worth not just the money, but also the wait.
                                          I would have preferred to first receive and then test the modules I've already ordered to see if they are genuine, but given the shipping time from Asia, I'm doing parallel orders in the hope of getting at least one shipment of genuine NRF24l01+ modules up and working fairly soon. Doing the orders serially would have run the risk of the procurement process taking too long.
