  3. How to update sensor relay from serial gateway
12 Posts 3 Posters 5.3k Views 2 Watching
  • B Offline
    B Offline
    beanl
    wrote on last edited by beanl
    i can't update my relay trhough serial ...
    My gateway is on : /dev/ttyUSB0
    My relay sensor is on : /dev/ttyUSB1
    both sketch are from mysensors sample code except i force sensor node to 1 for my sensor relay.
    This is what i read from gateway serial :
    0;0;3;0;9;read: 1-1-0 s=255,c=0,t=18,pt=0,l=3,sg=0:1.5
    1;255;0;0;18;1.5
    0;0;3;0;9;read: 1-1-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
    1;255;3;0;6;0
    0;0;3;0;9;read: 1-1-0 s=255,c=3,t=11,pt=0,l=5,sg=0:Relay
    1;255;3;0;11;Relay
    0;0;3;0;9;read: 1-1-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
    1;255;3;0;12;1.0
    0;0;3;0;9;read: 1-1-0 s=1,c=0,t=3,pt=0,l=0,sg=0:
    1;1;0;0;3;
    1;255;0;0;18;1.5
    1;255;3;0;6;0
    1;255;3;0;11;Relay
    1;255;3;0;12;1.0
    1;1;0;0;3;
    And on my relay sensor :
    send: 1-1-0-0 s=255,c=0,t=18,pt=0,l=3,sg=0,st=ok:1.5
    send: 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
    repeater started, id=1, parent=0, distance=1
    send: 1-1-0-0 s=255,c=3,t=11,pt=0,l=5,sg=0,st=ok:Relay
    send: 1-1-0-0 s=1,c=0,t=3,pt=0,l=0,sg=0,st=ok:
    What can i do to update my relay status ?
    i try :
    bash> echo "1;1;1;0;1;\n" >> /dev/ttyUSB0
    tx led blink but i have nothing in my serial :(
    • hekH Offline
      hekH Offline
      wrote on last edited by hek
      Is \n interpreted correctly as newline in echo? (I think echo adds newline automatically...)
      "1;1;1;0;2;1" should do the trick
      • B Offline
        B Offline
        beanl
        tried :
        echo "1;1;1;0;2;1" >> /dev/ttyUSB0
        without success :(
        • B Offline
          B Offline
          beanl
          I also tried using node.js ...
          I check if i receive serial data on my gateway using :
          bash> picocom /dev/ttyUSB1 -b 115200 -r -l --omap lfcrlf --imap lfcrlf --emap lfcrlf
          Terminal ready
          Here is my node.js script :
          const gwType = 'Serial';
          //const gwPort = 'COM4';
          const gwPort = '/dev/ttyUSB0';
          const gwBaud = 115200;
          //var SerialPort = require('/home/bxl/node-v0.12.0-linux-x64/lib/node_modules/serialport');
          var serialport = require('/home/bxl/node-v0.12.0-linux-x64/lib/node_modules/serialport');
          var SerialPort = serialport.SerialPort;
          gw = new SerialPort(gwPort,
                  { baudrate: gwBaud
                    ,parser: serialport.parsers.readline("\n")
                      gw.on('open', function() {
                                  console.log('connected to serial gateway at ' + gwPort);
                                  gw.write('1;1;1;0;2;1');
                                  console.log('Write done.');
                          }).on('end', function() {
                                  console.log('disconnected from gateway');
                          }).on('error', function() {
                                  console.log('connection error - trying to reconnect');
                                  gw.open();
          but nothing move on my serial gateway :(
          • hekH Offline
            hekH Offline
            Does not att newline (I think?)...
            • B Offline
              B Offline
              beanl
              I also try to put my gateway on a widows machine and on arduino ide :
              I send : 1;1;1;0;2;1
              But on my node :
              picocom v1.7
              port is        : /dev/ttyUSB1
              flowcontrol    : none
              baudrate is    : 115200
              parity is      : none
              databits are   : 8
              escape is      : C-a
              local echo is  : no
              noinit is      : no
              noreset is     : yes
              nolock is      : yes
              send_cmd is    : sz -vv
              receive_cmd is : rz -vv
              imap is        : lfcrlf,
              omap is        : lfcrlf,
              emap is        : lfcrlf,
              Terminal ready
              send: 1-1-0-0 s=255,c=3,t=11,pt=0,l=5,sg=0,st=fail:Relay
              • hekH Offline
                hekH Offline
                What does "Pas de fun de ligne" mean?
                K 1 Reply Last reply
                  K Offline
                  K Offline
                  korttoma
                  @hek acording to google translate "No end of line"
                  • Tomas
                  • B Offline
                    B Offline
                    beanl
                    yep it's the french version of arduino IDE :)
                    • hekH Offline
                      hekH Offline
                      Choose the option where it sends newlines then...
                      • B Offline
                        B Offline
                        beanl
                        i try with the option without success.
                        I also try to reset EEPROM & assigning Node ID with "MYScontroller" :
                        On my node :
                        Terminal ready
                        req id
                        send: 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,sg=0,st=fail:
                        repeater started, id=255, parent=0, distance=1
                        req id
                        req id
                        req id
                        I think my gateway don't really send message ...
                        Any idea why ?
                        • B Offline
                          B Offline
                          beanl
                          I used a mini pro whith FTDI :
                          It wasn't working the serial gateway don't send data.
                          I test with a nano and all is ok now ...
                          Terminal ready
                          req id
                          read: 0-0-255 s=255,c=3,t=4,pt=0,l=1,sg=0:1
                          read: 0-0-1 s=255,c=3,t=6,pt=0,l=1,sg=0:M
                          id=1
