  3. How to update sensor relay from serial gateway
12 Posts 3 Posters 5.4k Views 2 Watching
  • B
    B
    beanl
    wrote on last edited by beanl
    tried :
    echo "1;1;1;0;2;1" >> /dev/ttyUSB0
    without success :(
    • B
      B
      beanl
      I also tried using node.js ...
      I check if i receive serial data on my gateway using :
      bash> picocom /dev/ttyUSB1 -b 115200 -r -l --omap lfcrlf --imap lfcrlf --emap lfcrlf
      Terminal ready
      send: 1-1-0-0 s=255,c=0,t=18,pt=0,l=3,sg=0,st=ok:1.5
      send: 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
      repeater started, id=1, parent=0, distance=1
      send: 1-1-0-0 s=255,c=3,t=11,pt=0,l=5,sg=0,st=ok:Relay
      send: 1-1-0-0 s=1,c=0,t=3,pt=0,l=0,sg=0,st=ok:
      Here is my node.js script :
      const gwType = 'Serial';
      //const gwPort = 'COM4';
      const gwPort = '/dev/ttyUSB0';
      const gwBaud = 115200;
      //var SerialPort = require('/home/bxl/node-v0.12.0-linux-x64/lib/node_modules/serialport');
      var serialport = require('/home/bxl/node-v0.12.0-linux-x64/lib/node_modules/serialport');
      var SerialPort = serialport.SerialPort;
      gw = new SerialPort(gwPort,
              { baudrate: gwBaud
                ,parser: serialport.parsers.readline("\n")
                  gw.on('open', function() {
                              console.log('connected to serial gateway at ' + gwPort);
                              gw.write('1;1;1;0;2;1');
                              console.log('Write done.');
                      }).on('end', function() {
                              console.log('disconnected from gateway');
                      }).on('error', function() {
                              console.log('connection error - trying to reconnect');
                              gw.open();
      but nothing move on my serial gateway :(
        Does not att newline (I think?)...
        • B
          B
          beanl
          I also try to put my gateway on a widows machine and on arduino ide :
          I send : 1;1;1;0;2;1
          But on my node :
          picocom v1.7
          port is        : /dev/ttyUSB1
          flowcontrol    : none
          baudrate is    : 115200
          parity is      : none
          databits are   : 8
          escape is      : C-a
          local echo is  : no
          noinit is      : no
          noreset is     : yes
          nolock is      : yes
          send_cmd is    : sz -vv
          receive_cmd is : rz -vv
          imap is        : lfcrlf,
          omap is        : lfcrlf,
          emap is        : lfcrlf,
          Terminal ready
          send: 1-1-0-0 s=255,c=3,t=11,pt=0,l=5,sg=0,st=fail:Relay
            What does "Pas de fun de ligne" mean?
            korttomaK 1 Reply Last reply
              korttomaK
              korttomaK
              korttoma
              @hek acording to google translate "No end of line"
              • Tomas
              • B
                B
                beanl
                yep it's the french version of arduino IDE :)
                  Choose the option where it sends newlines then...
                  • B
                    B
                    beanl
                    i try with the option without success.
                    I also try to reset EEPROM & assigning Node ID with "MYScontroller" :
                    On my node :
                    Terminal ready
                    req id
                    send: 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,sg=0,st=fail:
                    repeater started, id=255, parent=0, distance=1
                    req id
                    req id
                    req id
                    I think my gateway don't really send message ...
                    Any idea why ?
                    • B
                      B
                      beanl
                      I used a mini pro whith FTDI :
                      It wasn't working the serial gateway don't send data.
                      I test with a nano and all is ok now ...
                      And on my relay sensor :
                      Terminal ready
                      req id
                      read: 0-0-255 s=255,c=3,t=4,pt=0,l=1,sg=0:1
                      read: 0-0-1 s=255,c=3,t=6,pt=0,l=1,sg=0:M
                      id=1
