  3. Vera
  4. Vera Arduino Plugin
Vera Arduino Plugin
23 Posts 9 Posters 17.8k Views 4 Watching
  • D
    Drcashman
    You have to install the files manually.
    All the links are on the controller page for the vera
    mntlvrM 1 Reply Last reply
    • mntlvrM mntlvr
      @YAW
      I have look on this page but It tell me how to install the plugin but not where I can find it or the actual name of the plugin, I have looked at the 3rd parties but found nothing for Arduino. perhaps the plugin has been pulled from MCV's site I even tried the Home page for getvera and looked under APPs
      Thank
      axillentA
      axillentA
      axillent
      @mntlvr said:
      @YAW
      Thank
      read the page through, all is where
      MySensors plugin is not yet registered in Vera appstore
      sense and drive
      • D Drcashman
        mntlvrM
        mntlvrM
        mntlvr
        @Drcashman
        What am I suppose to do with the LUA file ,I have downloaded all of the files like the instructions tell me to but I must be blind because I don't see what I do next to create the gw. I can see how to create a device but not gateway. I am running UI7.xxx I have read in the forum that other people have gotten this to work with UI7.
        axillentA 1 Reply Last reply
        • mntlvrM mntlvr
          @Drcashman
          axillentA
          axillentA
          axillent
          @mntlvr gateway is a separate thing
          you will need ethernet gateway because serial gateway has issues with UI7
          read here http://www.mysensors.org/build/ethernet_gateway
          after that you will need to build at least one sensor node
          read here http://www.mysensors.org/build/connect_radio for radio
          and for example for humidity sensor http://www.mysensors.org/build/humidity
          sense and drive
          • axillentA axillent
            mntlvrM
            mntlvrM
            mntlvr
            wrote on last edited by mntlvr
            Thank You that is the info I was looking for. I have the ethernet gateway built and one distance module. So if I read this correctly all I need to do is create a device in my Vera and they tell the device the IP address of my gw? Or is there more than what I have mentioned. If I understand what you are saying is I don't need the Arduino GW Plugin.
            I thank you for your advice and I hope I am reading this advice correctly.
            O 1 Reply Last reply
            • mntlvrM mntlvr
              O
              O
              olaeke
              wrote on last edited by olaeke
              @mntlvr
              1. If you are running UI7 then I recommend that you download newer files from GitHub ([https://github.com/mysensors/Vera/tree/UI7](link url) )
              2. Install **all **files (mentioned in the instruction not all files from GitHub) to Vera under Apps/Develop apps/Luup files (in UI7)
              3. Create the device as the instruction says
              4. Connect your Gateway
              5. Now hopefully your gateway will turn up as a device and with the text "Connected to: 192.........."
              mntlvrM ramoncarranzaR 2 Replies Last reply
              • O olaeke
                @mntlvr
                mntlvrM
                mntlvrM
                mntlvr
                @olaeke said:
                @mntlvr
                I am not having much luck with the "gateway" does it matter where you attach the gateway,ex does it need to be plugged directly into the port on the Vera 3 or at any point in your network. When I plug the ethernet gateway into my 16 port switch and then open up my router to look to see if the unit is connect to my network I can not find the mac address of the wiz 5100 or the IP that i setup in the UNO.
                What am I doing wrong or is this a problem with UI7?
                I have gone back to vera UI5.
                now the install page says to Installing the Vera Plugin
                "Once you have installed the Arduino Plugin, you will register your sensors with the Vera by using the Inclusion mode triggered by clicking on the Start button on the plugin. The default inclusion duration is one minute."
                now the question is where is this plugin to install?
                • greglG
                  greglG
                  gregl
                  Should work anywhere on your ethernet network ( unless you have multiple subnets) - you should be able to ping it from your pc if you are using the wiznet module.
                  • mntlvrM
                    mntlvrM
                    mntlvr
                    O.K. I have finally got the Ethernet gateway up and working in both my Vera lite and in my Vera Edge. I think perhaps a video would help many of us that are having issues with this. Thank for the help. Now to build the Sensors.
                    • B
                      B
                      Burtonian
                      Hi, I am just about to buy some Arduino hardware and then I too wish to add it to my Veralite. I believe that I am running U15 on my Veralite. Please can you give me any help that the more experienced members overlooked telling you because they possibly just presumed that you would know that step etc.
                      Also how have you got on with building your modules.
                      Regards
                      Burtonian
                      London UK
                      ramoncarranzaR 1 Reply Last reply
                      • B Burtonian
                        Regards
                        Burtonian
                        London UK
                        ramoncarranzaR
                        ramoncarranzaR
                        ramoncarranza
                        @Burtonian
                        Hi, I am new to arduino but not to Vera, have been using Veralite for a few years, I to wuould like to know how to add the gate to Vera, I find it very confusing, it would be ideal if a video was created r step by step instructions, I will be more than happy to donate via paypal, Thanks so much
                        M 4Crawler4 2 Replies Last reply
                        • O olaeke
                          @mntlvr
                          ramoncarranzaR
                          ramoncarranzaR
                          ramoncarranza
                          reply
                          • ramoncarranzaR ramoncarranza
                            @Burtonian
                            mvader
                            @Burtonian
                            have you looked at this page?
                            https://www.mysensors.org/controller/vera
                              @Burtonian
                              4Crawler4
                              4Crawler4
                              4Crawler
                              wrote on last edited by 4Crawler
                              @Burtonian
                              I made a video earlier this year about adding a serial gateway on a VeraLite:
                              https://youtu.be/rtsa-pN_R9M?list=PLpY2FP1a9tiurSiQTwhalz4KBxg_7db65
                              This was with the 1.5 library, I need to re-make that video with the new 2.0 version. PeteB also has a nice video on the subject, I think I have the link in my video description.
                              • 4Crawler4 4Crawler
                                @Burtonian
                                ramoncarranzaR
                                ramoncarranzaR
                                ramoncarranza
                                @4Crawler Thank you very much, your video is VERY helpful for Vera users, as I did not realize that the Arduino with the FTDI board was a must, and I had already purchased a different type, so I went ahead and got the right one, sucks because I was exited to build my gateway, now I have to wait a a week or longer since most of this stuff comes from China, but you saved me a ton of headaches had I not watched your video. Question I have though, can I still use the Arduino Nano with the CH340G board for my sensors since I already have a dozen of them?
                                Thanks again
                                4Crawler4 1 Reply Last reply
                                  Thanks again
                                  4Crawler4
                                  4Crawler4
                                  4Crawler
                                  Thanks again
                                  Yes, the CH340 Nanos work fine for sensors or for Ethernet gateways, just not serial gateways:
                                  https://youtu.be/doz9mEtw_8g?list=PLpY2FP1a9tiurSiQTwhalz4KBxg_7db65
                                    Thanks again
                                    ramoncarranzaR
                                    ramoncarranzaR
                                    ramoncarranza
                                    @4Crawler Thanks so much
                                      Thanks again
                                      ramoncarranzaR
                                      ramoncarranzaR
                                      ramoncarranza
                                      @4Crawler
                                      Hi, do you have any experience with this:
                                      https://forum.mysensors.org/topic/5265/window-blinds
                                        @4Crawler
                                        4Crawler4
                                        4Crawler4
                                        4Crawler
                                        @4Crawler
                                        No, have never looked into that. There are Z-Wave curtain modules available for under $20, like from Monoprice.
                                          @4Crawler
                                          ramoncarranzaR
                                          ramoncarranzaR
                                          ramoncarranza
                                          @4Crawler
                                          Was not aware of this module, most likely will need it is as well. I am looking to motorize my existing blinds, We have a ton of blinds at my place and would like to automate a portion of them.
