  3. Windows GUI/Controller for MySensors
myscontrollermysbootloader
486 Posts 101 Posters 515.2k Views 73 Watching
    @rvendrame: I think it is ota. With MYSBootloader you can't use ftdi for uploading sketch.
    • rvendrameR
      rvendrameR
      rvendrame
      @scalz, thx. I will give it a try tonight.
      ESP8266 GW + mySensors 2.3.2
      Alexa / Google Home
      • rvendrameR rvendrame
        @tekka, just to clarify, in step 4 above - the 'upload GW sketch' should be OTA? Or via regular FT232 adapter?
        tekkaT
        tekkaT
        tekka
        I meant to update the Gateway node with the most recent Serialgateway sketch...
        • rvendrameR
          rvendrameR
          rvendrame
          Yep, I'm already on latest version on GW. My GW runs on a pro-mini, with standard bootloader --- I guess this is not a issue?
          Alexa / Google Home
          tekkaT 1 Reply Last reply
            tekkaT
            tekkaT
            tekka
            and MYSController is connected via USB/FTDI to the GW...?
            • rvendrameR
              rvendrameR
              rvendrame
              It is connected via USB/FTDI into a mac-mini running a TCP-to-serial SW. (so both Vera and MYSController can reach it using IP address). Works like a charm, I can see all nodes and messages, no connection issues so far.
              Is it required the GW running on MYSBootloader? I hope not...
              Alexa / Google Home
                tekkaT
                tekkaT
                tekka
                @rvendrame Sensor nodes with MYSBootloader (unless they are Sensebender boards) and GW with original bootloader. Curious to see your logs.
                • tekkaT tekka
                  @rvendrame said:
                  Yes, I connect the radio and start the node, but nothing happens --- No serial monitor, nothing in MYSController. Just the pin 13 led flashing randomly.
                  Just flashed MYSController.hex on my Arduino pro mini 3V3 and the fuses as mentioned in the boards.txt (L: 0xF7 E: 0x06 H: 0xDA), using USBasp and everything works smoothly...
                  Please keep in mind: There is no serial monitor for MYSBootloader and the 13 led flashing is normal
                  Can you try this (in the indicated order):
                  0) Update Arduino IDE to 1.6.5
                  1. burn the original bootloader and upload the clear eeprom sketch
                  2. burn MYSController, disconnect flasher and connect nRF24L01+ module
                  3. download the most recent MySensors 1.5 library and upload the GW sketch
                  4. launch MYSController 0.1.2.282, activate AutoID, Logging and connect to the serial GW
                  5. let it run for a few mins and upload the log-file here
                  rvendrameR
                  rvendrameR
                  rvendrame
                  wrote on last edited by rvendrame
                  #185
                  EDIT: @tekka, @scalz , after so many tries, I don't know why I decided to replace the nRF radio , and guess what?
                  Funny thing is that the previous radio is working with regular bootloader. Dam fake chips! But I will sort it out later, now I want to play with my OTA ;-)
                  Thanks a lot!
                  Alexa / Google Home
                    @rvendrame: so cool. I am happy for you!
                    See you soon
                    • FrancoisF
                      FrancoisF
                      Francois
                      @tekka do MYSBootloader also work with the RFM69 radios?
                        Thanks a lot!
                        tekkaT
                        tekkaT
                        tekka
                        @rvendrame excellent :)
                        • FrancoisF Francois
                          tekkaT
                          tekkaT
                          tekka
                          @Francois No, in it's current stage only nRF24L01+, but porting to RFM69 should not be too difficult...
                          • 5546dug5
                            5546dug5
                            5546dug
                            @tekka silly ?
                            But still last night changed from serial to Ethernet gw using iboard wiz5100 and the h/w changes.
                            No issues but for later problems do I ---use myscontroller by way of FTDI connector>usb or
                            -- continue to plug the original serial gw into laptop leaving Ethernet still in use ( plugged in).
                            • 5546dug5 5546dug
                              @tekka silly ?
                              tekkaT
                              tekkaT
                              tekka
                              @5546dug said:
                              @tekka silly ?
                              I'm not quite sure I understand your question. Are you having issues with the EthernetGW?
                              • 5546dug5
                                5546dug5
                                5546dug
                                @tekka No everything is ok now but there will be problems in the future to sort out if history repeats itself.
                                So it is just a learning question for troubleshooting later.
                                To "see" Ethernet gw in your gui use FDTI>usb>laptop (with gw still connected to the router) or use the serial gw I had from before connected remotely to laptop via usb..
                                As of now I use only Ethernet gw plugged into router and the serial gw is no longer plugged into my vera.
                                • C cdr
                                  @tekka I feel really, really, REALLY stupid;
                                  I changed the channel in the mysensors config.h to 77, this was the reason no node would ever show up since the default mysbootloader uses the default channel 76.
                                  D'OH
                                  Thanks for your patience and help, everything is working now and I'm really happy!
                                  :+1:
                                  N
                                  N
                                  NewFolk
                                  D'OH
                                  :+1:
                                  @tekka is there a way to change the default channel in MYSbootloader ?
                                  • P
                                    P
                                    Pendragon
                                    What ware the designed values for "type" in the fimware_config.csv?
                                    Can I use this variable for my sensor IDs?
                                    • rvendrameR
                                      rvendrameR
                                      rvendrame
                                      @tekka, I've being playing with MYSController and MYSBootloader over last days, I'm totally amazed by them ;-) Thank you so much for developing such nice tool!
                                      If you allow me, I have only one ask for the santa-claus list: Perhaps it is possible for MYSBootloader capture serial output from a node, allowing OTA Serial monitor via MYSController? I know you guys are doing a miracle within 2KB, but who knows...
                                      Again, thanks a lot!
                                      Alexa / Google Home
                                      • N NewFolk
                                        D'OH
                                        :+1:
                                        tekkaT
                                        tekkaT
                                        tekka
                                        Yes, but for that you'll have to re-compile it.
                                        N 1 Reply Last reply
                                        • P Pendragon
                                          tekkaT
                                          tekkaT
                                          tekka
                                          Yes, but this is only an internal reference and not being used for AutoFW assignment
