  3. Introducing MySensors on nRF24LE1
myscontrollernrf24le1soc
37 Posts 18 Posters 34.9k Views 18 Watching
  • tekkaT
    tekkaT
    tekka
    wrote on last edited by tekka
    First impression of MySensors running on nRF24LE1. Reporting temperature / humidity from DHT22, VCC voltage and millis() timer.
    This SoC has many interesting features (SPI, 2-Wire, Serial, GPIO, ADC, RNG, AES accelerator, etc. ) and sub uA sleeping modes - without the need to solder a RF module. However, flash size limited to 16kB - still more than enough for many (peripheral) sensors... :)
    Readings in MYSController:
    Compiling with SDCC and nRF24LE1 SDK.
    Source (Proof of concept/POC, non-optimized) here.
    A Y 2 Replies Last reply
      Wow! Great work.
      • YveauxY
        Awesome man! :+1:
        • Z
          Z
          Zeph
          wrote on last edited by Zeph
          Great work indeed!
          However, the source link (at this time) fails...
          tekkaT 1 Reply Last reply
          • Z Zeph
            Great work indeed!
            tekkaT
            tekkaT
            tekka
            @Zeph goo.gl changed the ToS. link updated. thanks
              impressive work. very good idea!
              • Ivan ZI
                Ivan ZI
                Ivan Z
                What is the current in transmition and idle mode?
                Did you realize sleep?
                • tbowmoT
                  tbowmoT
                  tbowmo
                  hmm 8051 instruction set.. Now that's an old mcu then.. Remember them from back in the beginning of the 90's
                  Thought they where long forgotten, and dead, now that there are newer (and probably more efficient) mcu cores available.
                  Actually, just found my final exam project I made 20 years ago based on an 80535. An EPROM burner, that could program up to 27c512 :) And one had to use UV lamps to erase the chips again (Getting all nostalgic here :))
                  • G
                    G
                    gbfromhb
                    This looks very cool. I understand the concept, and I'm more of a software guy then an electronics guy, but I have not done anything like this. Would you be able to provide a step by step or point me to something that could get me from code to getting it onto the chip. Thanks great idea.
                    • Ivan ZI Ivan Z
                      tekkaT
                      tekkaT
                      tekka
                      You may find the information in the product specs.
                      No, not yet.
                      • G gbfromhb
                        tekkaT
                        tekkaT
                        tekka
                        Since everything is pretty much POC at the moment, no time so far to compile a doc. However, uVision Keil is the official IDE supporting those MCUs (compiler, simulator, flashing, and debugging). You will also find some information (e.g. SDK, open-source programmer, etc.) by simply searching for "nRF24LE1" ...
                        More to follow...
                        • Z
                          Z
                          Zeph
                          Checking aliexpress:
                          http://www.aliexpress.com/item/NRF24LE1-NRF24L01-MCU-Wireless-Transceiver-DIP-Wireless-Communication-Module-nE/32230173245.html
                          At those sizes and prices, this could be a very interesting option. Looking forward to hearing about your progress.
                          • G
                            G
                            gbfromhb
                            wrote on last edited by gbfromhb
                            Thank you tekka. I suspect you given me the clues I need.
                            • tekkaT tekka
                              alexSV
                              @tekkaYou can follow any responses to publish libraries (MyMessage.h MyMessage.cpp, ...) adapt to the SDCC compiler?
                              • A alexSV
                                tekkaT
                                tekkaT
                                tekka
                                For the example above the standard MyMessage.h library was used. All other dependencies can be found in the nRF24LE1 SDK from nordic.
                                A 1 Reply Last reply
                                • tekkaT tekka
                                  alexSV
                                  wrote on last edited by alexSV
                                  @tekka sdсс not support __attribute ((packed)). Or do you use a different compiler?
                                  sdcc --model-large --std-sdcc99 -Iinclude -I../SDK/_target_sdcc_nrf24le1_32/include -I../SDK/include -I./aes/include -c src/main.c -o "obj/"
                                  include/MyMessage.h:308: syntax error: token -> '(' ; column 18
                                  make: *** [obj/main.rel] Ошибка 1
                                  (attribute((packed));)
                                  and
                                  src/main.c:74: syntax error: token -> 'outMsg' ; column 16
                                  • A alexSV
                                    and
                                    tekkaT
                                    tekkaT
                                    tekka
                                    @alexSV remove __attribute ((packed)) from the .h file.
                                    A DwaltD 2 Replies Last reply
                                    • tekkaT tekka
                                      alexSV
                                      @tekka Thanks - works
                                      • tekkaT tekka
                                        DwaltD
                                        DwaltD
                                        Dwalt
                                        @tekka Nice project. This would be very useful for small, battery powered, binary sensors. What did you use to program the nRF24LE1?
                                        • DwaltD Dwalt
                                          tekkaT
                                          tekkaT
                                          tekka
                                          @Dwalt I used this programmer.
