  2. Announcements
  3. 1.4 Beta
1.4 Beta
1.4betahelp
129 Posts 18 Posters 124.1k Views 4 Watching
  • DammeD Damme
    Additional comment on config;
    I think it should be request config, response config messages.
    I also think its a bit odd that the actuator reports as
    gw.present(2, S_LIGHT);
    but requests as
    if (message.type==V_LIGHT) {
    V_LIGHT != S_LIGHT (2 vs 3)
    I think the def should follow as much as possible.
    hope any of my thoughts are somewhat useful
    @Damme there's a lot of Vera legacy in there... This forum had a discussion going on about decoupling from Vera, but I'm afraid that got lost in the crash...
    • DammeD Damme
      I've tried the lib for a while now and found the following:
      Then using ack=1 the returned message is exacly the one I sent. No way of knowing if its a request or an ACK.
      example:
      Client sends
      3;255;3;6;0 (Give me configuration 0 (btw, why not leave config as a byte 0-255 instead of hardcoing it? I could have plenty of uses for configuration-values.)
      Gateway responds: 3;255;3;6;M and requests ack
      client sends
      3;255;3;6;M
      my software tried to lookup config id 'M' (Not a big deal for letter, but what if its a number?)
      maybe ACK should be some sort of incremental number in return in special message type. I dont really know what is best.
      It would be great if GW resends the messsage automatically a couple of times (configurable) if ACK = 1.
      I've also noticed during DEBUG enabled that the message gets overwritten by old one, i.e.
      send: 3-3-0-0 s=255,c=0,t=18,pt=0,l=15,st=fail:1.4b1 (18848a2)
      send: 3-3-0-0 s=255,c=3,t=11,pt=0,l=4,st=ok:test1 (18848a2)
      send: 3-3-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:2.0t1 (18848a2)
      (message 2: test1, message 3: 2.0)
      Edit; One more thing
      Do I really need one gw.process(); before each gw.send(..); in the loop? I seam to loose messages if I dont do like that.
      // gw.sleep(SLEEP_TIME); //Seems to break recieing message, loosing ~75%
      DammeD
      DammeD
      Damme
      Code Contributor
      me just dumb here, delay(SLEEP_TIME); works. gw.sleep puts radio in sleep I guess.
      hekH 1 Reply Last reply
      • DammeD Damme
        gw.sleep() puts both Arduino and radio to sleep.
        • YveauxY Yveaux
          @Damme Other wireless protocols usually have a counter which is increased with each message. Returning the counter as an ack would be sufficient to correlate the ack and the original message.
          Returning the whole message seems like overkill indeed...
          The send-methods could e.g. return the Id counter of the message sent, and an app waiting for an ack on that message should check for this value in any ack received (using some timeout)
          That mean you might have to rememeber the original message. The idea is to have all the information necessary in the callback.
          In my example sketches (e.g. RelayActuator) the ack message actually changes the relay status when the ack comes back from gateway. If not full message came in you would have to keep buffers with sent messages and start matching counter-values. Much more complicated.
          But a message counter will probably be necessary if/when we start encrypting messages to prohibit replay attacks.
          @Damme
          I actually thought about having a bit in the message header which says if the message is an ack or not. With that implemented you would just call a msg.isAck() to determine if the incoming message is an ack message. Would that be ok?
          You shouldn't need to call gw.process() after each send. It is only necessary in the loop() section if you expect incoming messages or have enabled repeater mode.
          I don't understand what you mean with messages getting overwritten with DEBUG enabled. Could you explain it a bit more (with an example?).
          YveauxY DammeD 2 Replies Last reply
            wrote on last edited by hek
            #24
            @Yveaux
            To pick up the discussions about existence or not of getTemp().
            A better solution would probably be to create a MySensorsATMega328-subclass of the library which contains AtMega specific stuff such as sleep() and potentially getTemp().
            This class should also implement the EEPROM specifics.
              @Damme
              You have to remember it anyway when you regard the message as lost after some time without an ack and you decide to send the message again. Only for a simple sensor node which sends a sensor value with ack, waits for an ack reply and then continues with the next sensor value this wouldn't be necessary. When a single node has multiple messages with ack 'in flight', you definately need message buffering.
              This is independent from the ack message format IMHO.
              I also think message buffering and retrying, when implemented, should be part of the MySensors library.
              This improves realiability even more than with the NRF24 ack's enabled and avoids putting the retry-burden on the clients of the library.
                @Damme
                DammeD
                DammeD
                Damme
                Code Contributor
                here is a serial output from one of my nodes
                repeater started, id 3
                send: 3-3-0-0 s=255,c=3,t=6,pt=1,l=1,st=fail:0
                send: 3-3-0-0 s=255,c=3,t=11,pt=0,l=4,st=fail:test1 (18848a2)
                send: 3-3-0-0 s=255,c=3,t=12,pt=0,l=3,st=fail:2.0t1 (18848a2)
                send: 3-3-0-0 s=0,c=0,t=7,pt=0,l=15,st=fail:1.4b1 (18848a2)
                send: 3-3-0-0 s=1,c=0,t=6,pt=0,l=15,st=fail:1.4b1 (18848a2)
                send: 3-3-0-0 s=2,c=0,t=3,pt=0,l=15,st=fail:1.4b1 (18848a2)
                send: 3-3-255-255 s=255,c=3,t=7,pt=0,l=0,st=fail:1.4b1 (18848a2)
                and the sketch has: gw.sendSketchInfo("test", "2.0");
                yes, I know they all failed, I'm using the microwave oven atm, it kills the channel 76 (usually uses 21 but forgot to change last time, works better for me here..)
                  Ahh.. The strings-payloads don't seem to be terminated correctly.
                    @Yveaux
                    I wouldn't restrict to the Atmega328. Quite some AVR's have this or simular behaviour and it would be nice to have a single library usable for all (e.g. using #ifdef's if absolutely necessary).
                    Seems like you're trying to move towards board- and cpu-support packages, like Linux does...
                    Another way to tackle it is to create a separate library to read the AVR's internal 'sensors' like the temperature sensor and e.g. the VCC voltage (as I did in https://github.com/Yveaux/arduino_vcc) and another one for persistent storage (EEPROM), and one for power management (sleep). This approach seems to follow the Arduino-way of creating a library for every 'function'.
                    It all depends on whether you think big and target different hardware (MPU) platforms or if you want to stick with the Arduino (or even only the ATmega328). When porting MySensors to the RPi it would be very nice if the MySensors library and examples would directly compile on both platforms.
                    This requires libraries to have a clear interface which doesn't limit portability to one platform or architecture.
                    • DammeD
                      DammeD
                      Damme
                      Code Contributor
                      Hello
                      I was looking in the nrf24l01 datasheet and found "Setup of Automatic Retransmission"
                      Is this something that mysensors use?
                      • DammeD Damme
                        Hello
                        @Damme at least in the 1.4beta release. I think it's disabled in 1.3
                          Yep, as @Yveaux says we use it it 1.4.
                          • L
                            L
                            lodewyk
                            Hi guys,
                            I just got relays working with but struggling requesting a variable value on Beta 1.4.
                            My set variable commands looks as follow.
                            Switching On - > 1;1;1;0;2;1 (work as expected)
                            Off -> 1;1;1;0;2;0 (work as expected)
                            Request variable for the same relay -> 1;1;2;0;2; (sets the relay to 0 ???)
                            Can someone confirm if my request variable command is correct and if not what should it be?
                            DammeD hekH YveauxY 3 Replies Last reply
                            • L lodewyk
                              Hi guys,
                              DammeD
                              DammeD
                              Damme
                              Code Contributor
                              wrote on last edited by Damme
                              #33
                              @lodewyk I use this:
                              void incomingMessage(const MyMessage &msg) {
                              if (msg.type==V_LIGHT) {
                              if (strlen(msg.getString())==0) {
                              gw.send(message.setSensor(msg.sensor).setType(V_LIGHT).set(digitalRead(msg.sensor-1+RELAY_1)?RELAY_ON:RELAY_OFF));
                              digitalWrite(msg.sensor-1+RELAY_1, msg.getBool()?RELAY_ON:RELAY_OFF);
                              gw.saveState(msg.sensor, msg.getBool());
                              (How do i use [code] ?? I start to hate this forum :P)
                              • L lodewyk
                                Hi guys,
                                @lodewyk
                                The relay example does not support requesting state. You must add some code in incomingMessage() to handle incoming request-messages (and reply to them).
                                To reply incoming request-command in incomingMessage for the RelayActuator-example do something like this (note I have not compiled/tested this)
                                if (mGetCommand(msg) == C_REQ) {
                                     mSetCommand(msg, C_SET);
                                     msg.setDestination(msg.getSender());
                                     msg.set(gw.loadState(msg.getSensor());
                                     gw.send(msg);
                                } else (
                                    // Do the normal stuff here
                                • L
                                  L
                                  lodewyk
                                  @DAMME and @HEK
                                  Thanks , very helpful.
                                  I got so occupied with the commands and never thought about the sensor code.
                                  • L
                                    L
                                    lodewyk
                                    • L
                                      L
                                      lodewyk
                                        This forum uses markdown. If you need help, press the little questionmark-icon in the compose window. http://daringfireball.net/projects/markdown/syntax
                                        To decorate your codeblock use 4 spaces or one tab character first on each line.
                                        • L lodewyk
                                          Hi guys,
                                          @lodewyk hey man, you've got -2 posts.... How's that possible?
