  3. Low Power shutdown mode?
13 Posts 3 Posters 5.6k Views 1 Watching
  • B Offline
    B Offline
    brolly759
    I am using the BinarySwitchSleepSensor sketch. It uses a pin interrupt on pin 2/3 connected GND to switch. When the switch is not engaged I am getting 23-24uA. When the switch is engaged I am drawing 117uA.
    How can I reduce these numbers even further? I know there is a powerdown/shutdown mode(Cant find how to do it) and maybe adding external resistors to lower the current draw but what does everyone else recommend?
    • N Offline
      N Offline
      Also, what's the lowest current draw for each mode that anyone is currently getting? That would help establish a target as to what's achievable.
      • B Offline
        B Offline
        brolly759
        Okay, some more news on my front. I downgraded from the latest build of Arduino to 1.0.6 and now here are my numbers for BinarySwitchSleepSensor sketch:
        Sleep mode w/o switch engaged: 2.5uA !!!!!!
        Sleep mode w switch engaged: 98-100uA.
        Now I need to find a way to have the switch engaged use very little current. Any idea's?
        • N Offline
          N Offline
          Maybe I'm getting confused with the LPC810 MCU, but doesn't Arduino also support both falling and rising edge triggered interrupts? If so, couldn't you set one of those and then go back to sleep?
          c.f. http://jeelabs.org/book/1517e/
          • B Offline
            B Offline
            brolly759
            Here is information pertaining to interrupts and Arduino:
            http://playground.arduino.cc/Code/Interrupts
            Here is the code from the library:
            #define SKETCH_MAJOR_VER "1"
            #define SKETCH_MINOR_VER "0"
            #define PRIMARY_CHILD_ID 3
            #define SECONDARY_CHILD_ID 4
            MySensor sensor_node;
              sensor_node.begin();
              // Setup the buttons
              // Activate internal pull-ups
              sensor_node.present(PRIMARY_CHILD_ID, S_DOOR);
              sensor_node.present(SECONDARY_CHILD_ID, S_DOOR);
              uint8_t value;
              static uint8_t sentValue=2;
              static uint8_t sentValue2=2;
              sensor_node.sleep(5);
              if (value != sentValue) {
                 sentValue = value;
              if (value != sentValue2) {
                 sentValue2 = value;
            • N Offline
              N Offline
              Yup, "They are triggered equally on RISING or FALLING signal edges..." So, it should work. :smile:
              • B Offline
                B Offline
                brolly759
                Hate to act like the idiot here but can you explain what I should do? lol
                • A Offline
                  A Offline
                  AWI
                  wrote on last edited by AWI
                  The higher power with the engaged switch probably comes from the pull-up. There is a current through the switch when closed. You can increase the value to reduce consumption. If you use internally pull-up the value is between 20k and 50k which gives you around (ohms law I=U/R) I=3.3/20.000=165uA
                  • B Offline
                    B Offline
                    brolly759
                    I did increase the value of the resistance by 60K and 100K externally, both those values dropped the current consumption but my problem was that there was not enough to power to have the Arduino read that the switch was working. So I was getting nothing basically. I put the resistor in line between the switch. Even when I had that amount of Resistance used I was still drawing 34uA or greater, still above what I am trying to get.
                    A 1 Reply Last reply
                    • B brolly759
                      A Offline
                      A Offline
                      AWI
                      @brolly759 you should remove /switch of the internal pull-up (digitalWrite). And conmect the external resistor from the Arduino pin to Vcc. 1 Mohm should be sufficient to drop current to the uA range.
                      • B Offline
                        B Offline
                        brolly759
                        @AWI
                        So Pin 2 -> 1Mohm Resistor -> VCC
                        and GND is the switch to Pin 2 ?
                        Is that a minimum current the Arduino needs to read a state change?
                        • A Offline
                          A Offline
                          AWI
                          Yes it is. The same configuration like with the internal pull-up. digital pins
                          • B Offline
                            B Offline
                            brolly759
                            SO an update, I connected a 10Mohm Resistor and my current draw is only 3.1-3.2uA when the switch is engaged and 2.7-2.8uA when the switch is removed. I think that is really livable numbers. So far not getting any false positives which is great. :)
