  3. Low Power shutdown mode?
13 Posts 3 Posters 5.7k Views 1 Watching
  • B
    B
    brolly759
    Okay, some more news on my front. I downgraded from the latest build of Arduino to 1.0.6 and now here are my numbers for BinarySwitchSleepSensor sketch:
    Sleep mode w/o switch engaged: 2.5uA !!!!!!
    Sleep mode w switch engaged: 98-100uA.
    Now I need to find a way to have the switch engaged use very little current. Any idea's?
      Maybe I'm getting confused with the LPC810 MCU, but doesn't Arduino also support both falling and rising edge triggered interrupts? If so, couldn't you set one of those and then go back to sleep?
      c.f. http://jeelabs.org/book/1517e/
      • B
        B
        brolly759
        Here is information pertaining to interrupts and Arduino:
        http://playground.arduino.cc/Code/Interrupts
        Here is the code from the library:
        #define SKETCH_MAJOR_VER "1"
        #define SKETCH_MINOR_VER "0"
        #define PRIMARY_CHILD_ID 3
        #define SECONDARY_CHILD_ID 4
        MySensor sensor_node;
          sensor_node.begin();
          // Setup the buttons
          // Activate internal pull-ups
          sensor_node.present(PRIMARY_CHILD_ID, S_DOOR);
          sensor_node.present(SECONDARY_CHILD_ID, S_DOOR);
          uint8_t value;
          static uint8_t sentValue=2;
          static uint8_t sentValue2=2;
          sensor_node.sleep(5);
          if (value != sentValue) {
             sentValue = value;
          if (value != sentValue2) {
             sentValue2 = value;
          Yup, "They are triggered equally on RISING or FALLING signal edges..." So, it should work. :smile:
          • B
            B
            brolly759
            Hate to act like the idiot here but can you explain what I should do? lol
            • AWIA
              AWIA
              AWI
              wrote on last edited by AWI
              The higher power with the engaged switch probably comes from the pull-up. There is a current through the switch when closed. You can increase the value to reduce consumption. If you use internally pull-up the value is between 20k and 50k which gives you around (ohms law I=U/R) I=3.3/20.000=165uA
              • B
                B
                brolly759
                I did increase the value of the resistance by 60K and 100K externally, both those values dropped the current consumption but my problem was that there was not enough to power to have the Arduino read that the switch was working. So I was getting nothing basically. I put the resistor in line between the switch. Even when I had that amount of Resistance used I was still drawing 34uA or greater, still above what I am trying to get.
                AWIA 1 Reply Last reply
                • B brolly759
                  AWIA
                  AWIA
                  AWI
                  @brolly759 you should remove /switch of the internal pull-up (digitalWrite). And conmect the external resistor from the Arduino pin to Vcc. 1 Mohm should be sufficient to drop current to the uA range.
                  • B
                    B
                    brolly759
                    @AWI
                    So Pin 2 -> 1Mohm Resistor -> VCC
                    and GND is the switch to Pin 2 ?
                    Is that a minimum current the Arduino needs to read a state change?
                    • AWIA
                      AWIA
                      AWI
                      Yes it is. The same configuration like with the internal pull-up. digital pins
                      • B
                        B
                        brolly759
                        SO an update, I connected a 10Mohm Resistor and my current draw is only 3.1-3.2uA when the switch is engaged and 2.7-2.8uA when the switch is removed. I think that is really livable numbers. So far not getting any false positives which is great. :)
