  3. Vera
  4. Multiple Ethernet Gateways?
9 Posts 5 Posters 5.6k Views 1 Watching
  • C Offline
    C Offline
    clippermiami
    Right now I'm using a Serial Gateway on my Vera Lite but I have hope to eventually move to a Ethernet Gateway for location reasons. I'm curious if it is possible to use multiple Gateways merged to a single logical Gateway?
    H 1 Reply Last reply
    • C clippermiami
      H Offline
      H Offline
      @clippermiami
      No, you must create one plugin-device per gateway. And also keep them on different channels.
      C greglG 2 Replies Last reply
      • E Offline
        E Offline
        epierre
        @hek I saw a guy yhat did a lib to put two nrf24 on tbe same arduino to make it transceove orders, would that apply to the configuration discussed above ?
        z-wave - Vera -> Domoticz
        • H hek
          @clippermiami
          C Offline
          C Offline
          clippermiami
          @hek Thanks
          • H hek
            @clippermiami
            greglG Offline
            greglG Offline
            gregl
            @hek said:
            @clippermiami
            Does this mean its possible to have multiple gateways on a Vera??
            If so..can u run a 1.3 and 1,4beta at the same time???
            • H Offline
              H Offline
              Yes
              No
              Y 1 Reply Last reply
              • H hek
                Yes
                No
                Y Offline
                Y Offline
                No
                Why not? If running on two different gateways and you know what you're doing it should be possible...
                • Y Yveaux
                  No
                  H Offline
                  H Offline
                  @Yveaux
                  Yes, but for the vera plugin you really have to know what you are doing. That is rename device files and select new device types.
                  • H hek
                    @Yveaux
                    Y Offline
                    Y Offline
                    @hek AH, OK. I know nothing about Vera (and like to keep it that way :-) )
                    12.2k
