  3. Low Power: How much current? [Solved]
109 Posts 10 Posters 88.4k Views 11 Watching
  • B
    B
    brolly759
    This is testing using the Binary Switch Sleep sketch.
    The switch is not active when its in its "open state" so there is no drain. I removed the resistor though and all the jumpes, I am still getting around 2.7-2.8uA is sleep mode without switch.
    In sleep mode with the NRF ONLY VCC unplugged I am getting 1.3uA - 1.5uA.
    In sleep mode with ALL cables unplugged from NRF I am getting a strange reading and not really sure which one is accurate but here are my numbers:
    With uCurrent in uA mode I am getting .4uA -.5uA
    With uCurrent in nA mode I am getting 110-120nA
    I checked on Gammon site using the reference code, the nA of 110-120nA is accurate and the uA mode is wrong when I go down that low. So in short, I am getting 110-120nA when nRF is unplugged completely.
    • scalzS scalz
      @Neverdie: ok. this is what I was thinking..ahah no problem. I think you have misunderstood me.
      First, I think Brolly knows how to get low power as he said he has studied Gammon sketch. have you?
      Then, at the beginning I give you links to achieve low power but you told me that you wanted an easy to do way (the link with coin cell) and told !scalz. So I thought you didn't want to know more.
      So, if you want to try these steps and check (this was my first steps):
      • arduino pro mini, remove led and voltage reg
      • upload sketch J from Gammon, so you will be sure the best you can achieve
      • check at your uCurrent you will be < uA
      • Mysensors part : make a function from this sketch J and use it for sleeping instead of gw.sleep which use lowpowerlab (very strange I had difference with it and didn't investigated more). but you will need to find something for your radio next...like mosfet but it is other things.
      But If you try it, you will see with your eyes now...
      Yes I have already some codes. but I told you I don't share as it is experimental, not clean, and a good lib will be released soon. So i don't want to spend more time for nothing.
      #27
      Sounds that way. Probably my fault, due to lack of sleep.
      Excellent!
      Next step for me: placing an order with Great Wall Electronics for 10x pro mini's, as that is now critical path. By the time it arrives (hopefully even sooner), l should have this figured out.
        #28
        BTW, while on Great Wall, I noticed these RTC functional knock-offs of the Chronodot are just $0.57/each.
        http://www.aliexpress.com/item/DS3231-AT24C32-IIC-Module-Precision-Clock-Module-DS3231SN-for-Arduino-Memory-module-Free-Shipping/32346088222.html
        It might make sense to use one of them to wake up an arduino just once, when it needs to be woken, instead of every 8 seconds, as when using the Watchdog Timer. The current consumed by a genuine ChronoDot is: 200uA (active), 840nA (timekeeping) I don't have amp figures for the Great Wall knock-offs. I have a couple of the genuine chronodots, and they keep pretty accurate time.
        • B
          B
          brolly759
          We really need a separate section just on power consumption, what each person gets per each configuration and instructions lol.
          I have never played with the Chronodot or any time stamp stuff. Is is easy to program?
          It does make sense to remove the watchdog timer: 7uA current with this but, who wants to do the math? What is the rise/fall time of the Chronodot? Depending on the duration of the rise time and frequency of waking up the arduino, we may not be saving much power. (Algebra was never my strong suite. Never went to college lol)
          On a side note, I am working with Gammon on figuring out why the nRF takes so much power: 2.4uA in sleep mode. Though I don't have any hardware at home so we must wait until tomorrow for that. In theory Arduino = 100+- nA + 800-900nA(NRF) = 1uA in sleep mode with an interrupt. That is what we all need to be aiming for, or at least I am.
            I think I spoke too soon. For battery applications, probably by now there are better options.
            • B
              B
              brolly759
              @NeverDie Trust me, there is never the perfect option... every time you think you have the right part and use it, another one that is better comes out... cant work fast enough anymore lol
              • B
                B
                brolly759
                Look at this one:
                http://ambiqmicro.com/am18xx-ultra-low-power-rtc
                14nA !!!! haha
                  #33
                  Wow! Good find. LOL. I was just about to post the following, as a "for instance," but you already found something that's 2-7x better.
                  "For instance, Digikey now sells a$14.40 eval board with a newer RTC clock on it that consumes just 100na: http://www.digikey.com/product-detail/en/OM13512/568-11550-ND/4947022
                  That one uses SPI bus, but there's an I2C variant."
                  I'd really prefer that it be built into the MCU anyway. These things are just the bridge to that. If the WDT could have timed beyond 8 seconds to hours or days, we might not even be talking about it. Apparently it was meant for rebooting the MCU if the MCU got wedged, not for sleeping the MCU for hours or days. It illustrates how long overdue the arduino is for a major updating.
                  • B
                    B
                    brolly759
                    You may want to check how the mySensors library actually works. I barely know hardware and coding, I scrape by... lol but in all the sensor examples you have this code:
                    gw.sleep(SLEEP_TIME);
                    That is a 30 second duration for sleep. I haven't tried to increase that time yet but maybe they are looping through the 8 second limit? Dunno. Worth to check though how they do it.
                    My issue is that this sleep method uses 7.6-7.8uA. It would be nice to have it at like < 3uA.
                    • B
                      B
                      brolly759
                      I am digging around and looking at the code, I think it just cycles through 8 second batches.
                      We have an unsigned long, so thats 4,294,967,295 ms = 4294967.295 seconds = 71582.78825 minutes = 1193.046470833333 hours = 49.71026961805556 days.
                      So IF there is not a cap on the max duration of sleep in the Mysensors library, you can theoretically go to sleep for the max duration of the unsigned long which is about 49 ish days...
                        wrote on last edited by hek
                        #36
                        Actually the ATMega328 can only sleep in cycles of 8 seconds maximum:
                        This is where the virtual long sleep is generated:
                        https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/MyHwATMega328.cpp#L124
                          #37
                          I have some chronodots too. I thought about same thing (wake up with rtc) but I have not tested yet. And, anyway, i will stay with ulpnode. I have bought chronodots for another pcb I am working on; sort of low power Flower Power for outdoor more robust as I will do my inox ec/humidity sensors myself (I have a mini lathe at home) and with datalogging inside (so need rtc). And I will try to wake up with rtc (programmable hours).
                          For Atmega328, I agree with @Hek, and you can't do what you want with watchdog. WDT is already well implemented in Lowpowerlab/MYsensors. You can't do more than 8sec cycles. It is in datasheet.
                          So if you want to wake up each x min/hours or days. Best way I think is RTC. If you need smaller cycle, WDT or ulpnode power management sequence.
                          I have already done your research few months ago to see if if i could do something different Charles. Unfortunately for me, I had to reproduce ulpnode sequence as he already had the good idea for this I think..it was a good exercise for me :smiley:
                          Yesterday I found this https://www.kickstarter.com/projects/flutterwireless/flutter-20-wireless-arduino-with-half-mile-1km-ran It is opensource. Well designed I think.
                          Funny thing too, atsam3s1a is not bad and have rtc too.
                          • OitzuO
                            OitzuO
                            Oitzu
                            I see they using the CC1200. I don't want to hijack this thread, but any information if they really can achive the 1000m they promise with that?
                            • OitzuO Oitzu
                              TI did some youtube videos in Norway and South Africa showing huge outdoor range (tens of kilometers) if the conditions are ideal (line of sight, with one transmitter on a mountain, etc.). But you gotta ask yourself: why South Africa? I think probably because the noise floor is so low. It makes for a more seemingly impressive demo.
                              They have very high sensitivity, which is great. I'm told much of it might be wastedl in a home environment, where the noise floor tends to be higher.
                              OitzuO 1 Reply Last reply
                                OitzuO
                                OitzuO
                                Oitzu
                                Hm.. okay. I'm asking because i'm currently trying to build an outdoor high range / low power network.
                                I don't find any of these cc1200 available on the market, so i will stick to my way of testing some nrf24L01+ with high gain directional antennas. :)
                                NeverDieN SparkmanS 2 Replies Last reply
                                • scalzS scalz
                                  #41
                                  One of the JeeLabs articles said that with an external clock to do the wakeups, allowing WDT to be turned off, then the atmega328p sleep current (not counting the external clock) could be reduced to 100nA. At that point (and probably long before), the MCU's drain just isn't a signficant factor anymore. and other things become dominant. Things like current leaks through capacitors, then become, relatively speaking, a comparatively huge problem.
                                  [Edit: Found it: "With an ATmega328 powered by 3.3V, the lowest practical current consumption is about 4 µA – that’s with the watchdog enabled to get us back out of sleep mode. Without the internal watchdog, i.e. if we were to rely on the RFM12B’s wake-up timer, that power-down current consumption would drop considerably – to about 0.1 µA:" http://jeelabs.org/2012/06/23/low-power-uas-in-perspective/ ]
                                  • OitzuO Oitzu
                                    #42
                                    In that case, also keep an eye on the Sematech SX1272 and SX1276 radio chips. IIRC, they have an even bigger link budget. They're finally becoming more affordable. Or the Silicon Labs Si4463.is also geared to play in the same ISM narrowband space.
                                      #43
                                      Those radios have the potential to draw low currents. The RFM26 aspires to be one of them, but from what I gather, the libraries for it are still coming together.. I've heard comments that the SemaTech libraries are already pretty good though. So, possibly in the future, one of the above, or something similar, will get integrated with MySensors. If you live on a ranch, or maybe just a large parcel of land, perhaps they'd be quite handy. In the meantime, if you're attempting something ambitious outdoors, I'd pick the RFM69HW over the NRF24L01+. Compared to the RFM69HW, the NRF24L01+, at least without PA+LNA, is a weakling. Even then, I have some with the PA+LNA, and so far I've found them disappointing.
                                      • OitzuO
                                        OitzuO
                                        Oitzu
                                        @NeverDie Thanks for the recommendations. I already ordered a pair of NRF24L01+ with PA+LNA and i planed to test some double biquad antennas on them.
                                        If this is not sufficient engough, maybe i should try the RFM69HW.
                                        The use case are multiple sensor points in a forest powered by solar power.
                                          @Sparkman said:
                                          @5546dug @NeverDie One thing to be cautious of is that not all Mini's use the same board configuration so the instructions may need to be altered depending on exactly with Mini you have.
                                          Al
                                          At the moment I'm wondering whether different Pro Mini's might consume more power than others, even if setup the same. I followed the author's directions, but I'm getting 17uA of current in power-down sleep mode (forever), not the 4.5uA that the author claims to have measured on his. Maybe it has to do with the configuration differences you're referring to? Or, I suppose it could be measurement error (either mine or the author's or both). I'm using a uCurrent Gold in conjunction with a Fluke 87V to do my measurements. The author didn't say how he did his, so I sent him an email asking for the details of how he measured.
                                          I am pleased though at having gotten such a gigantic reduction by following such a simple 3 step process.
                                          #45
                                          @NeverDie said:
                                          Al
                                          For anyone who's still curious, I heard back from the author:
                                          "I used the Voltcraft VC-130, Digital-Multimeter (http://www.amazon.de/gp/product/B003A5TA8U?psc=1&redirect=true&ref_=oh_aui_search_detailpage ) Datasheet: http://files.voelkner.de/1000000-1099999/001090519-da-01-en-VOLTCRAFT_VC130_1_DIGITAL_MULTIMETER.pdf "
                                          I'm actually not as concerned as I was earlier in the thread, now that I understand both Scalz and Brolly759 have managed to get such great results from the pro mini platform. That means at least three different people independently arrived at ultra lower current results using the Pro Mini, and I take that as good confirmation that it's possible to do with at least some of the Pro Mini offerings, such as the ones from Sparkfun or from Great Wall Electronics.
